05-25-2011, 11:44 AM
#31
Originally Posted by Volley
daMicrowave - did they say why it needs replaced? Is it leaking? Inner tie rods bad? Or is it just because there is some play? If it is just because there is sme play I would definitely try the guide for $50 or so before spending $700!
If it's not leaking or creaking, I agree with just trying to take up some slop by adjusting the guide. My '97 has the non-roller. It had some play in it like the video. I took out the guide to inspect - looked good so I just put it back together.
Before dis-assembly, I had made some marks so I knew how tight it was vs. after re-assembly. I probably got the adjustment another 10-15° tighter eliminating the play.
'97 SR5 V6 4x4 | 5-speed | e-locker | 33's
05-25-2011, 07:11 PM
#32
Ok so on the boots of the rack you look for a leak. Got it
98 SR5, 5spd 4x4, 185k - My Fishing Beast!
Owner/Operator of www.ReelsAndTackle.com
Feedback 1
05-26-2011, 03:37 AM
#33
steering
Hey all....I seem to have a steering issue as well. I recently purchased a 98 limited with 177,000 miles. i find that when i find myself drifting, i correct left/right and the vehicle wants to keep veering in the corrected direction. It doesnt pull, doesnt shimmy, and it just seems like i have to "help" the wheel back to the straight position, not with strength, just a little nudge. And questions or suggestions please..
05-26-2011, 06:21 AM
#34
Maybe out of alignment?
2015 Gray SR5 Premium 4Runner - Toytec Ultimate - LR UCAs - ARB Fridge - Airaid CAI - Flowmaster - 255/75 Cooper ST Maxx
Gone: 1998 Desert Dune 4Runner - Toytec/Eibachs w/ LC 8 Wraps - Bilstein 5100s All Around
Gone: 07 Sunfusion FJ Cruiser - OME lift and a bunch of other stuff (I miss this one)
Gone: 05 Silver TRD Offroad Tacoma Doublecab - Toytec lift and other goodies
05-30-2011, 10:35 AM
#35
Ok been searching for the rod connector and HD and Lowes look at me like I'm crazy and I don't see it myself. Anyone know if that is what it's called officially?
05-30-2011, 11:17 AM
#36
Get a bolt and 2 nuts. Lock the 2 nuts together on the bolt and it will work. BTW, I think you are supposed to look for a rod coupler.
1997 4runner Limited 4wd- Purchased new by family 12/96
Factory 4.30 e-locker conversion, 265/75 BFG AT, FX-R Hid Retrofit, Kenwood Nav, 231mm Tundra brakes, Grey FJZ80 Wheels, Deckplate mod, ARB Bumper, Hella 4000 compacts, Sonoran Steel 7.2a, Scangauge 2, Extended Diff Breather, Custom Sway Bar Endlinks, Black No Rust Rear Bumper
05-30-2011, 01:23 PM
#37
HD sells rod couplers with the "all thread" (threaded rod). They usually are where the other bolts are sold. Sometimes also sold as parts for "make a bolt".
2000 4runner Sport, SAS/4wheel Underground 3 link, Diamond axle, 14" Radflo coilovers, double locked, Custom rear 3 link, 12" Fox shocks, full armor Gerdo's Build Thread
Real Fuel Tank Skidplates for sale Lil' Skip's OffRoad
Rear control arm mount skids and Hi-Lift adapter for sale Lotus Development
05-30-2011, 02:05 PM
#38
Thanks guys!
06-01-2011, 08:27 PM
#39
Can anyone add to this regarding effectiveness and any negative effects?
I've been reading and re-reading this thread about correcting some front-end vibration and slop. Seems plausible to just tighten the existing guide instead of buying a new one. Or, is it that the new one is better/more effective?
Dumb question alert: If the rack is leaking wouldn't you have to refill the PS fluid reservoir regularly?
1996 SR5 Anthracite Oxidized 2wd 260k+ mi, commuter.
2006 SR5 V8 4wd Driftwood Pearl. Spacer lift. Stock for now.
06-01-2011, 09:53 PM
#40
Real Name: Throws like a girl
Not a dumb question, it makes sense.
Having to refill the reservoir may mean a leak but it doesn't necessarily mean it's the rack itself that's leaking.
06-02-2011, 12:02 AM
#41
Tightening the rack guide took away a little bit of the slop for me, but very quickly that will start making the steering harder. I overtightened it to the point that the wheel wouldn't return to center on it's own. It felt nice and tight, but I backed it off of that until the tension felt good. It is easy enough to do by feel just driving around the block after each adjustment.
2000 SR5 3.4L V6 Automatic 4x4, e-locker, 175k Miles, Rust
Imp. Jade Mica with Oak Leather Interior, Field Monitor Unit - B&M Tranny Cooler - SG2 - New (to me) rear axle assembly - Goodyear Duratrac 265/75-16 - 1.8" Ironman Front Lift, OME 906/Procomp 9000 Shocks
http://www.toyota-4runner.org/3rd-ge...ld-thread.html
06-02-2011, 09:54 AM
#42
Only thing I can add is my rig was much more solid after install. I had the old style and it didn't seem like it had too much play but changing it out made a good bit of difference. It's cheap and quick...A+
06-14-2011, 06:48 PM
#43
Just changed the guide on my 99 and wow, I wish I would have done this before I did bushings and TRE's. The highway wandering and 60+ steering wheel shake are gone. Feels so much better than before.
1999 4Runner Limited- Lifted, Locked, Armored, 35's Build Thread SOLD 03/24/14
2012 Yamaha WR450F- Supermotard
06-14-2011, 07:24 PM
#44
Ok, reading all these symptoms I was leaning towards a bad rack. I even went so far as replacing the rack bushings first. But like I said, the rack isn't leaking (PS reservoir stays full, the fluid I was seeing on it is oil from a valve cover gasket leak).
I just got back from the dealership for a 3rd opinion (after going to two general mechanics) and surprise, surprise- he said the rack looked fine and that it was the front shocks that needed replacing, showing me where the oil was leaking from them.
While I was there, I got a proper balance and just that made quite a difference. So, perhaps the tires being out of balance combined with 230k mi original shocks gave me the same front end issues.
07-18-2011, 02:42 PM
#45
I just did this guide replacement and what a great repair. Easy too.
