Old 04-05-2010, 09:48 AM #1
topdown4runner's Avatar
topdown4runner topdown4runner is offline
topdown4runner is on a distinguished road
'99 coils installed on Easter day
I had a busy weekend...I installed the '99 tall coils & Tokico shocks on my Wifes '97 4Runner.
Was not as bad as I thought it would be. Of course, I am not in the "rust belt", so nothing was rusted on.
Overall, it would seem I gained an inch all the way around, as other people have reported for the '97 upgrade.
Pictures are Before and After, in order.
Measurement pictures are drivers side, rear.
The ride is much improved. The old shocks were totally worn out. Much smoother on the road, cornering is better, much less body roll, etc... The stance looks way better than the pictures can show. I noticed an improvement, but my Wife couldn't tell a thing had been done. Oh well
'99 coils installed on Easter day-before-lift-side-jpg  '99 coils installed on Easter day-after-lift-side-jpg  '99 coils installed on Easter day-before-lift-front-jpg  '99 coils installed on Easter day-after-lift-front-jpg  '99 coils installed on Easter day-before-lift-drivers-rear-jpg  '99 coils installed on Easter day-after-lift-drivers-rear-jpg
1987 4Runner SR5, 4x4, 5speed, 4.7 low, twin stick, Aussie locker
1997 T100 SR5, 4x4, automatic
1997 4Runner SR5, 4x4, automatic, '99 tall coils
1996 4Runner Ltd., 4x4, slight body damage Look in Classifieds Section for parts
1999 4Runner Highlander, E-locker, 3" OME springs, 1.25" Spidertrax spacers, ARB bumper, 285/75R16 Goodyear MTR
topdown4runner is offline   Reply With QuoteReply With Quote
Old 04-05-2010, 09:49 AM #2
Clemsonfan15's Avatar
Clemsonfan15 Clemsonfan15 is offline
Clemsonfan15 will become famous soon enough
What size tires are those?
Check out my garage.
Clemsonfan15 is offline   Reply With QuoteReply With Quote
Old 04-05-2010, 09:57 AM #3
I knew that question was going to be asked....let me look at the pictures again, maybe I can see the size 'cause I don't remember
Old 04-05-2010, 10:02 AM #4
Nope, can't see the size in the pictures.
I THINK they are 265/75 R 16
I meant to look while I was taking the pictures, but I forgot
Old 04-05-2010, 10:08 AM #5
Yeah, that's what I think they are too.
Looks good though.
It's funny. I'm sitting at 36" in the front and 36 1/2" in the rear.
Old 04-05-2010, 10:14 AM #6
Here's the fronts, before and after.
I have heard that the amount of actual lift does vary by a little bit.
Could also have something to do with actual tire diameter vs what is on the sidewall, which varies by tire brand and amount of wear / miles.
Your truck looks nice too by the way
'99 coils installed on Easter day-before-lift-drivers-front-jpg  '99 coils installed on Easter day-after-lift-drivers-front-jpg
Old 04-05-2010, 11:40 AM #7
hdoggie24 hdoggie24 is offline
hdoggie24 is on a distinguished road
hey topdown, do you have 2wd or 4wd? cause there is supposed to be some 2wd rear fix with the 99 coils, according to sonoran steel? and are you using the oem tokicos or tokico trekmasters?. it looks good btw
hdoggie24 is offline   Reply With QuoteReply With Quote
Old 04-05-2010, 11:43 AM #8
Rock Slide's Avatar
Rock Slide Rock Slide is offline
Rock Slide is on a distinguished road
Rock Slide's Avatar
Did you piece the kit together or buy the entire kit from SS?
2002 4Runner Sport 4WD
Headlight Adjustment
"Live life w/o Limits. Your imagination is not limited by time or distance, by logic or by scarcity. You can fill your imagination with whatever you choose."
Rock Slide is offline   Reply With QuoteReply With Quote
Old 04-05-2010, 11:47 AM #9
All my trucks are 4x4, guess I should update my sig to reflect that
I installed the Tokico Trekmasters. They ride great!
'99 coils installed on Easter day-after-rear-shock-spring-jpg  '99 coils installed on Easter day-after-front-strut-spring-jpg
Old 04-05-2010, 12:00 PM #10
did you use the factory bolt (not the tokico one) for the top of your front shock...read many things about them stripping and the oem is needed. i don't know if that has been changed thru tokico. what model # are your front and rears if you don't mind me asking of the trekmasters? how much and where did you get them through. when i do the 99 coils, i was thinking of adding a 10mm ome trim packer to the rear to give just a tad extra lift if you wanted that. im going to do it. thanks
Old 04-05-2010, 12:32 PM #11
This is the ebay ad for the shocks I bought. $235 shipped. Part #'s should be in the ad.
TOKICO SHOCKS TOYOTA 4RUNNER 4WD 96 - 02 : eBay Motors (item 400103637141 end time Feb-24-10 23:26:13 PST)
I had no problems with the Tokico nut on top of the shocks. I did not use the Toyota ones.
It is the Wife's 4Runner, and she did not want any more lift, or rake from the back.
Old 04-05-2010, 12:50 PM #12
so the trekmasters ride nicely in the street? can you say if they are a little firm or soft or maybe a mix. im looking for a smooth street ride since this will also be for the wife and kids. i don't want something too firm to jitter them around. no offroading for me strictly street. thanks. i was debating regular oem tokicos but if the treks are better for street then ill go that route. thanks
Old 04-05-2010, 01:05 PM #13
Hmmm....hard to say, since I was replacing completely worn out shocks that were installed by the previous owner. I replaced air shocks in back and SensaTrack struts up front. I don't know how stock Tokico's feel to be able to answer your question correctly.
I can say without a doubt that the ride softened up quite a bit with the Trekmasters. It did ride quite hard before.
BTW,
this is my Wife's truck, a daily driver. It never goes off road. That is not what I was after when I got her new shocks and springs.
She is only 5' 2", so a bouncy ride really throws her around.
Old 04-05-2010, 01:11 PM #14
thanks for info....i have 2wd. i think i found out that 2wd and 4wd rears are the same shocks but the front use different part #s for the treks.
Old 04-14-2010, 11:55 AM #15
JohnsD90's Avatar
JohnsD90 JohnsD90 is offline
JohnsD90 will become famous soon enough
JohnsD90's Avatar
How much were only the coils? Mine are pretty tired.
JohnsD90 is offline   Reply With QuoteReply With Quote
