Old 09-01-2010, 03:44 PM #1
Black02's Avatar
Black02 Black02 is offline
Black02 is on a distinguished road
Black02's Avatar
DRL disable question...
According to this thread
2002 4Runner: DRL Disable With On/Off Capability - YotaTech Forums
I can just cut the black/yellow stripe wire to disable the DRL's? I do not need or want to put a switch on them.
Can anyone please verify
Thank you
Black 2002 Sport Edition supercharged - 3" spacer up front.....890 ome in rear - Black Soft 8's - 285-75r16 - HID Conversion kit - 1" Body lift w/ bumper brackets - Pioneer double din w/12"sub
Black02 is offline   Reply With QuoteReply With Quote
Old 09-01-2010, 03:57 PM #2
cfranck1's Avatar
cfranck1 cfranck1 is offline
cfranck1 is on a distinguished road
cfranck1's Avatar
Thank you
Yup, That's it. I just did it to mine. Works like a champ.
Just put a little electrical tape on each end of the wire so nothing can accidental hit it. One side of that wire is still hot after you cut it.
cfranck1 is offline   Reply With QuoteReply With Quote
Old 09-01-2010, 06:25 PM #3
Black02's Avatar
Black02's Avatar
AWSOME thank you!
Old 09-03-2010, 09:13 PM #4
TJLong TJLong is offline
TJLong is on a distinguished road
My 2000 has DRL, the write up talks about 2001-2002... Can I do the same thing?
Thanks,
Tyler
TJLong is offline   Reply With QuoteReply With Quote
Old 09-03-2010, 10:03 PM #5
zcruiser's Avatar
zcruiser zcruiser is offline
zcruiser has a spectacular aura about zcruiser has a spectacular aura about
zcruiser's Avatar
Thanks,
Tyler
See this thread... Not another DRL thread
Regardless of the year, it should be a black wire with yellow stripe.
2000 - Pin 2
2001/2 - Pin 12
2012 4Runner Limited, Shoreline Blue Pearl / Beige leather, RCI skid, ext rear diff breather, Derale 13504 cooler, 110K
1993 300ZX Cherry Red Pearl with some bling, K&N intake, PowerTrix suspension, 130K
zcruiser is offline   Reply With QuoteReply With Quote
Old 09-03-2010, 10:06 PM #6
cfranck1's Avatar
cfranck1's Avatar
Thanks,
Tyler
I think the 2000s have a big relay in the engine compartment you can just unplug.
Should look something like this
2000 4runner drl relay image by tbox on Photobucket
Check next to battery - between battery and fender for a metal cage looking thing with a plug on it. If it's there then just unplug it and no more DRLs.
But not sure on 2000s. I'm sure someone on here will know and steer you in the right direction. But check for the cage thing next to battery first.
Old 09-03-2010, 10:16 PM #7
Y2KSR5 Y2KSR5 is offline
Y2KSR5 is on a distinguished road
Yep, could barely get my hand in there but I did and unplugged it. No more DRLs
2013 Black Trail/Destination AT/Leather/Grey TRD Pro wheels
Priors:
2011 Magnetic Grey SR5 4WD
2008 Shadow Mica SR5 4WD
2000 Desert Dune SR5 4WD
Y2KSR5 is offline   Reply With QuoteReply With Quote
Old 09-03-2010, 10:31 PM #8
Thanks Guys!
Old 09-03-2010, 10:35 PM #9
jreask's Avatar
jreask jreask is offline
jreask is on a distinguished road
jreask's Avatar
I tried this yesterday. I unplugged the wiring from the DRL box and found the black wire with the yellow stripe. I had already disconnected the negative battery cable. I clipped the wire with the side cutters and then taped the end of it to the rest of the nest of wires. I turned the truck on. put it in gear and released the E brake. No lights ! I turned the headlights on and guess what? No headlights either. I am now perplexed and cussed a little bit at whoever said that you could cut this wire and disable the DRL's. I FORGOT TO PLUG THE WIRES BACK INTO THE HARNESS, LOL. After I plugged them back in, no DRL and the headlights and high beams work perfectly.
Sometimes I am so dumb. LOL
jreask is offline   Reply With QuoteReply With Quote
Old 09-04-2010, 02:26 AM #10
Black02's Avatar
Black02's Avatar
LMAO...sounds like something I would have done! I'm glad everyone had success, I haven't had time to do mine yet.
Old 07-03-2012, 11:55 AM #11
Brian757's Avatar
Brian757 Brian757 is offline
Brian757 is on a distinguished road
Brian757's Avatar
Damn!! Thank you for this! That was perfect! Had to do this for my HIDs. Want them to live longer than a year :P
2002 "Stormtrooper" 4Runner
Tacoma Bilstein 5100s | Eibach/Toytec Springs (Front) | FJ Springs (Rear) | Tundra 13WL Brake Swap | Much More...
Brian757 is offline   Reply With QuoteReply With Quote
Old 09-09-2012, 11:52 AM #12
Jw205 Jw205 is offline
Jw205 is on a distinguished road
Cutting the wire is much easier than running a switch. Snip! It's done. Not sure why the other guy ran a switch unless it was a legality issue. Also, does anyone know if you can set up the fog lamps to come on with just the parking lamps?
Jw205 is offline   Reply With QuoteReply With Quote
Old 09-19-2013, 12:45 AM #13
01thunder's Avatar
01thunder 01thunder is offline
Real Name: Ivan
01thunder is on a distinguished road
01thunder's Avatar
Real Name: Ivan
definitely something to do. i am tired of seeing the lights on during the day. not to mention they will last longer not being on all the time.
2001 SR5,
thundercloud, tundra brake upgrade with 231's, 906's/billies rear, 5100's/stock coils on 4th groove front, ISR/deck plate mod, ford trans cooler mod, 99-00 grille swap, led conversion, 17" 2014 SR5 wheels wrapped with cooper AT3's, 265/70/17
01thunder is offline   Reply With QuoteReply With Quote
Old 03-30-2014, 12:56 PM #14
Neos281 Neos281 is offline
Neos281 is on a distinguished road
DRL Module
Just an update in case anyone comes across this thread in the future. The DRL box can be unplugged to deactivate the Daytime Running Lamps just like "Cfrank" said. I am not sure if this is only for a 2000 model or all 3rd gen's but below is a photo from my 2000 Limited since the previous one in this thread was removed.
Just unplug and you're good to go!
Untitled
Jared - '00 Toyota 4Runner Limited 4WD+Elocker. Natural White/Silver
Neos281 is offline   Reply With QuoteReply With Quote
Old 03-30-2014, 02:00 PM #15
nor_cal51501 nor_cal51501 is offline
Real Name: Shane
nor_cal51501 is on a distinguished road
Real Name: Shane
That's for 2000 and below I believe. I know for a fact 2001-2002 you cannot do that because the lighting system grounds through there and you will lose all lighting function.
'01 Sport: E-locked, 285/70/17's, TURD S/C, 200k club
My Build: http://www.toyota-4runner.org/3rd-ge...ld-thread.html
nor_cal51501 is offline   Reply With QuoteReply With Quote
