Old 09-10-2010, 09:57 AM #1
alp alp is offline
alp is on a distinguished road
alp alp is offline
Rear Coil Spring Spacer
Hi guys!
I have Daystar's rear spring spacers to install and I would appreciate to learn from you about installation tips. Should I have a coil spring compressor to do this job or I can manage to do it without it?
Thanks.
alp is offline   Reply With QuoteReply With Quote
Old 09-10-2010, 11:29 AM #2
cj80cruiser's Avatar
cj80cruiser cj80cruiser is offline
cj80cruiser is on a distinguished road
Originally Posted by alp View Post
Hi guys!
Thanks.
You can get them in there without needing any of that. Not my personal experience on a 4runner but what I've been told. I'll be doing mine soon and already did the research.
戦争イーグル
Cory J
Wheel converter,
cj80cruiser is offline   Reply With QuoteReply With Quote
Old 09-10-2010, 02:15 PM #3
alp alp is offline
alp alp is offline
Any practical advice how to remove/install a rear coil spring?
SR5 1999
Old 09-10-2010, 04:51 PM #4
Hope this helps. You shouldn't have to disconnect the rear panhard but def unbolt the swaybar.
Finally got my lift parts!
戦争イーグル
Cory J
Wheel converter,
Old 10-15-2010, 09:56 AM #5
bak3rme's Avatar
bak3rme bak3rme is offline
bak3rme is on a distinguished road
bak3rme's Avatar
I ran across a set of coil spacers that someone is selling. hes selling 2 sets. a 2.5'' and a 1.5 '' ....im total noob here so need some clarification.
i didnt get too much info from him other than that they were 2.5'' and 1.5''
can i buy both and use a set for the front and a set for the rear?
these are going to be on stock coils..lol
'99 SR5 3.4L 2WD
SOLD
Build Thread
2003 Nissan 350z Track/Autocross
2014 4runner SR5
bak3rme is offline   Reply With QuoteReply With Quote
Old 10-15-2010, 10:01 AM #6
xskydivingdudex's Avatar
xskydivingdudex xskydivingdudex is offline
xskydivingdudex is on a distinguished road
unless they are front and rear u cant bc the rear coils are wider then the front coils so if the spacers are both meant for the rear they will not fit properly on the front stock coils...
| G3 Projectors | OME/LC | 315/75 Kelly Safari TSR | Custom LC Rims | Rola Vortex Roof Rack | Gobi Ladder |
xskydivingdudex is offline   Reply With QuoteReply With Quote
Old 10-15-2010, 10:22 AM #7
bak3rme's Avatar
bak3rme's Avatar
thought so. lets say i got the 2.5 spacer and put in the rear. u think i get less than 2.5 '' or around 2.5? just wondering coz if i get under 2'' then i wont be getting the 1.5''
'99 SR5 3.4L 2WD
SOLD
Build Thread
2014 4runner SR5
Old 10-15-2010, 12:02 PM #8
ull prob get around 2.5" in the beginning but itll sag so ya i wouldnt get the 1.5" since its not much lift and itll look almost stock after a while.
Old 10-15-2010, 12:42 PM #9
quicksilvr's Avatar
quicksilvr quicksilvr is offline
quicksilvr is on a distinguished road
quicksilvr's Avatar
Hi guys!
Thanks.
I installed my 1.5" daystar spacers several months ago. It was a huge pain....but only for one reason: I didn't use a jack to jack up the opposite side of the axle that I was working on. Since I didn't do that, I had to use spring compressors, and have my dad stand on a drum and push down as hard as he could on the side I WAS working on to try and get the clearance to put them back in.
Take the lower shock bolts out, disconnect the sway bar and the panhard bar, and make sure you don't break the brake line. Other than that, it should be too bad.
2001 SR5~Thundercloud Metallic~3.4L Auto~4x4~260k miles~TRD 2gen black Supercharger~URD AFR Calibrator~B&M 70264~Bilstein Adjustable w/ tall '99 fronts~ProComp 3" rear springs~Nitto Ridge Grappler 285/70R17's on 17x9 Enduro's~Yakima RailRider w/48" bars~ScanGauge II
quicksilvr is offline   Reply With QuoteReply With Quote
Old 10-15-2010, 01:37 PM #10
bak3rme's Avatar
bak3rme's Avatar
after a while. how long lol a year or two? coz if its less than that ill just keep saving
'99 SR5 3.4L 2WD
SOLD
Build Thread
2014 4runner SR5
Old 10-15-2010, 01:48 PM #11
alp alp is offline
alp alp is offline
Should I disconnect both shocks and both panhard bars and do both springs in one shot or keep one side connected and work with another one? Confused.
SR5 1999
Old 10-15-2010, 02:17 PM #12
quicksilvr's Avatar
quicksilvr's Avatar
Disconnect all of it, so the axle is completely "free". Support the center under the differential with a jackstand, and then use your jack to lever the axle over the pivot point of the jackstand to free up room on each side at a time.
Old 10-15-2010, 02:53 PM #13
im not exactly sure how long before they begin to sag since i nvr owned spacers but i think its over like 3 or more years... My cousin had a grand cherokee and had spacer lift on it and we didnt notice any sag at all; he owned it for 4 years.
Old 10-15-2010, 03:21 PM #14
alp alp is offline
alp alp is offline
Thanks
SR5 1999
Old 10-16-2010, 01:31 AM #15
bak3rme's Avatar
bak3rme's Avatar
sweet! thats good. in 3 years..i think i'll have a different care. hopefully an is300 of is250. if not than a 4x4 3rd gen
'99 SR5 3.4L 2WD
SOLD
Build Thread
2014 4runner SR5
