Originally Posted by McDeth
I recently replaced the factory stock battery on my 96 4runner with an Optima Blue Top. The new battery is a lot smaller than the one it was replacing and I've noticed that there is a TON of play in the OEM battery tie-down system. Even with the nut screwed down all the way it doesn't even come close to holding the new Optima battery in place. Are there any manufacturers that make an aftermarket tray that would hold an Optima comfortably?
That's odd, I had exactly the opposite problem: When I replaced my battery the new one was about 3/4" taller than the old one so the battery clamp wouldn't fit. I resolved it by getting a longer screw for the front part of the clamp and then "shimming" it with about 6 washers. Now it works great.
If you're problem is just height, why not just set the battery on a peice of wood or plastic cut out to the shape of the battery? Should shim it up just fine.
