09-24-2010, 11:40 PM
Help Me Please.....Pics inside
What did I break?
‘14 SR5 in white
Front: King ext travel 2.5 w/ adjusters, TC UCA/LCA
Rear: King 2.5 shocks w/ adjusters, Dobinson’s 3” Icon Billet lowers, Icon tubular uppers, PCK
Wheels/Tires: SCS SR8’s w/ Toyo MT 35x12.50x17
Full RCI skids
09-24-2010, 11:47 PM
looks to me like your cv boot ripped and threw the grease everywhere, and it also had water in it.... best i can figure...
13 Tacoma TRD OR Double Cab. Old man Emu lift, 285 Duratracs, Spidertrax wheel spacers, custom sliders, snugtop, CB, rem 870 express, lots of knives, and loaded for a week in the woods--- (his ride)
99 porsche 996 C2 Fabspeed exhaust, and Brey-Krause harness bar, tow hook, fire ext, camera mount, deep sump oil kit. (our ride)
14 SR5 Premuim 4x4 with duratracs (her ride)
09-24-2010, 11:49 PM
My other question is how long can I drive on this before i need to repair it? (its my DD)
‘14 SR5 in white
Full RCI skids
09-24-2010, 11:53 PM
u can continue to drive it, but you will lose that cv joint... not that big of a deal beacuse its the front and you dont need it for street driving... however, if you use 4wd you will need to replace it asap... might get away with just a boot and a repack of the grease.. but once grit gets in there it will die fast.
09-25-2010, 01:04 AM
Starting to sound like its not a cheap fix
‘14 SR5 in white
Full RCI skids
09-25-2010, 01:12 AM
naaa... a cv joint is not too bad...... maybe 300 never replaced them on a 4 runner so thats a rough estimate...
09-25-2010, 01:18 AM
I'm really not that mechanicaly inclined, even if I was, I've not no tools here and no where to work on it. You guys think its better to replace just the boot or do the half shafts from autozone?
‘14 SR5 in white
Full RCI skids
09-25-2010, 01:34 AM
how much do u use 4wd? if seldome.. i would do the boot... just clean it real well.... if alot, i would go the half shaft route... try a search and see f there is a dyi here.
09-25-2010, 02:58 AM
That boot doesn't look ripped from what I can see of it.....that goo looks more like oil and water.
The OP should maybe check the radiator for goo and his oil for more goo.
Isn't cv grease usually dark green/blackish?
2001 M. Silver 4WD SR5 5VZ Love Machine
3rd Gen FAQ Here
09-25-2010, 03:19 AM
agreed.. however the grease in the cv will turn that color w water same as oil and water will.... and its right in the cv area........ but check these things too.
09-25-2010, 03:41 AM
ill be in albany this wednesday for a few days visiting my mom if you want to drive this way ill help you replace it
98 4runner sr5 3.4L 5spd 4x4 e-locker sold 10/2/11
07 tundra 5.7L 4x4 limited dc was my moms r.i.p 3/19/11
Oregon Toyota Owners Club
09-25-2010, 03:59 AM
also i got my cv axles from oreilly's
09-25-2010, 04:09 AM
That might just work. I have Thursday off and will be headed towards salem
‘14 SR5 in white
Full RCI skids
09-25-2010, 04:25 AM
well there you go get the cv and stop on by it takes a hour or soo ..also pick up a little bottle of blue thread lock at the parts store
09-25-2010, 04:27 AM
Alright I will go check in the morning to see if anyone has them in stock or can get then here before thursday. Now i'm worried its something else like others have mentioned
‘14 SR5 in white
Full RCI skids
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
