Originally Posted by NegroTundra
Bump. I have a 98 with 280k that I'm itching to bolt on the new Magnuson TVS1320. Seems counterintuitive to bolt on a potential issue to a motor that has been so good over the years. But damn, I'm hungry!
I've been thinking the same for a while and tbh it's just not a good idea. When I was looking up some accounts of people supercharging around the 300k mark I found some guy that added one between 300-350k and it didn't even last a year before it blew his head gaskets
If you did head gaskets recently it
might hold up a little better, but that also means the next weak link would be at risk, which would likely be piston rings or valvetrain. A compression test would give you a better idea on how strong those still are, but wouldn't tell you how much longer the trans will last from the major increase in hp/torque (don't forget a 7th injector is very commonly needed just to avoid pinging at lower elevations which would only boost the numbers higher)
People like to say "well you can always just take it off" but that doesn't do you very much good once the engine's been damaged or you've burnt up a gear in the trans
Ultimately it's your vehicle and your money but personally I find it to be extremely risky
Y2K Highlander
Millennium Silver 3.4L auto @ 320k and climbing
