06-11-2019, 04:05 PM
#16
Originally Posted by Smog-guy707
I have 325k on my 02 supercharged. It has been rebuilt once before , but this thing still runs as if it were brand new.
I have no 7th injector. Premium fuel only and I drive mostly highway with moderate traffic. I get 15 mpg on a good day
wow 325k with a SC. How long has the SC been on? have you had any engine issues? I'm debating on putting one on my rig.. I've got 280k
IG: @4runnerfiend- 1999 SR5: TRD Supercharger, ELocker, Wheelers T1 Coils-tundra 5100's, Built Right UCA's, LC 8 wraps-Fox 2.0 with CD adjuster, Rokmen lower links, Savage skids, Hot Metal Fab Front Tube bumper, Savage Rear tube bumper, TruckShopSD Sliders, DuroBumps, RidgeGrapplers, Doug Thorley Headers, yellow top, XRC 12k, ARB single compressor.
06-11-2019, 11:56 PM
#17
Real Name: Eddie
Real Name: Eddie
Easier on eyes.
Eddie
Originally Posted by Jaysen4runner
Just install mine 230k with sc!
2001 T4R SR5 - 180k miles and counting.
06-12-2019, 12:51 AM
#18
The sc has only been on for 25 k actually
I did a lot of maintenance prior to the supercharger to make sure I was going to be safe. Filters, fluids, plugs, timing belt, cooler thermostat, fixed all oil leaks. I have yet to run into any drivability issues. I only run premium fuel and synthetic oil and honestly it has never ran better. The daily drivability is still relatively the same. It’s awesome. I always told myself if the engine went out I am going to replace it so I threw the supercharger on. Feels way better
Loading....
06-12-2019, 12:54 AM
#19
Loading....
06-12-2019, 11:09 AM
#20
I'd imagine with the SC the 4R drives like it should have from the factory. It is pretty obvious that its fairly undertuned from the factory.
06-12-2019, 03:56 PM
#21
Originally Posted by APhelps
I'd imagine with the SC the 4R drives like it should have from the factory. It is pretty obvious that's its fairly undertuned from the factory.
Exactly. I thought the same thing
Loading....
06-12-2019, 04:52 PM
#22
Real Name: Jerod
Real Name: Jerod
I think basically everyone who's driven a SC'd 4Runner thinks this same way. Toyota was a little too conservative on power when they designed this engine. But then again, they were coming from that slug of a V6 the 3VZ-E. I hated that engine.
I had 221k miles of Supercharged fun on my engine before it blew. Not the supercharger's fault though.
06-17-2019, 03:42 AM
#23
Real Name: Drew
Real Name: Drew
I've been seriously considering supercharging mine as well. 238k on it currently. Do you guys recommend doing an engine refresh (rings, bearings, gaskets) before installing a supercharger or just bolt it on as is?
97 4Runner Limited, Desert Dune with Rear Locker
OME 881/891 springs with Bilstein 5100 shocks
Goodyear Duratracs LT265/75R16
06-17-2019, 11:32 AM
#24
Real Name: Eric
Real Name: Eric
Put mine on at 210k after purchasing it with 200k. Came out of an 01 with about 60k on the SC that I could guess at least.
Compression test tells lots. If your numbers are good, go for it. I did all the other maintenance I could while in there. Valve cover gaskets, PCV valve, etc
2000 Limited | e-locker | 33's | Skids/Sliders | TRD SC | Sold
2007 Limited | V8 | RCI | OME 884/895e | 255/75r17 | JBA's
06-17-2019, 12:24 PM
#25
Real Name: Jerod
Real Name: Jerod
Rings would be a bit too much. The biggest thing is to make sure your fuel system and ignition is up to the task. Make sure you have the right plugs and new wires if old/unknown. Make sure you have optimum fuel flow so an injector service of some sort, even if it's just multiple bottles of injector cleaners will help. Also replace the fuel filter if it's never been done.
Gaskets are not a big deal, the only two gaskets that will see boost pressure is the lower intake manifold gaskets (these are stout) and the head gasket, which handles boost fine.
06-17-2019, 02:07 PM
#26
204k on my rig with supercharger. installed at around 197k. no 7th inj but did
have to change out knock sensors. Also sent off the injectors to witchhunter
for cleaning, glad i did cause 4 of the 6 were not in good order. Runs way better
now and no issues.
06-17-2019, 10:19 PM
#27
Real Name: Drew
Real Name: Drew
I'm still doing all the research on the 7th injector, correct temp spark plugs, etc. Do you guys mostly send the injectors out to have them looked at or just buy a set of matched injectors?
03-11-2020, 10:52 AM
#28
'98 dealer installed SC, 265K still strong.
~15mpg
03-11-2020, 12:51 PM
#29
2000 Imperial Jade Mica 4runner, 3.4 auto, the workhorse
2000 Horizon Blue Metallic Tacoma, 3.4 ext cab 5-speed, the adventure build -
https://www.tacomaworld.com/threads/...#post-19751873
03-11-2020, 04:51 PM
#30
I have a 2003 Tacoma that had the supercharger installed at about 110,000 miles and now at 130,000 it’s had no issues at all.
2017 TRD Pro, Cement
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
