09-27-2010, 01:23 PM
OME 890 rears to LC 7wraps?
I currently have the Toytec 881 front / 890 rear coils with the OME Sport shocks. The ride is too stiff for my needs. Rides great when the car is loaded up, but this only 1 day a week.
Looking to switch to some LC 7 wrap coils I think. Questions are:
Will this have the rear sitting higher than the front, if so how much? I have a slight rake now, and it does not bother me.
Can I still use the OME Sport Shocks in the rear or should I swap those out too?
Finally, I am doing this to improve ride comfort. Am I on the right path?? Thanks!
00 4runner
09-27-2010, 03:13 PM
Real Name: Johnny
Real Name: Johnny
oh boy. . . i have the 7 wrap LC's. one word: cadillac. dont plan on towing alot of tongue weight on the reg anytime soon though.
2000 4Runner SR5, 5vz-fe, 5speed, 246k miles, bfg 35's on stock 1985 4runner wheels
09-27-2010, 04:13 PM
Didn't really plan on towing anything, since everything that I would need to tow, the runner couldn't handle anyways.
Anyone have close to the setup I am thinking off? Would the LC 7 wrap coils work with the OME shocks?
00 4runner
10-11-2010, 05:18 PM
Anybody else with some info? Also, a couple of sources that people mentioned on the forum for LC coils have not even gotten back to me with a response. Any other sources for some LC coils? What shocks should I pair them with if keeping the front suspension OME. Thanks.
00 4runner
10-11-2010, 05:28 PM
If you have rake running the OME coils right now, you will have a bit more rake running the LC 7 wraps.
Sounds like a good fit for you, I would probably replace the rear shocks but they may work, Im not entirely sure cuz I dont know many that have run the OME sport shocks. not sure what they are valved for or how much lift they are capable of. Just remember that 7 wraps will give you prob another inch or two lift. I dont see a problem, Im running 5-6 inches of lift in the back with shocks only set for 2.5 inches of lift, so you SHOULD be ok, but I dont know for positive
10-11-2010, 05:51 PM
Real Name: Rob
Real Name: Rob
I'm pairing 7.5 wraps with some LC shocks, just bought them today for 48 bucks a piece from the dealership. Thanks to Rockdawg84 for the part number, here it is: 48531-69417
10-11-2010, 06:38 PM
Yes, you will be okay with the increased length spring with the OME shock. The shock will only limit how much downwards travel the rear suspension will get. Going to LC7 wraps will let you sit higher and softer in the rear then the 890's. Hope this helps
10-13-2010, 03:29 PM
Thanks for the help. I was hoping to not introduce anymore rake than I already have. Do they make LC 6 coil springs? Or maybe get the 7 wraps and cut a coil?
00 4runner
10-13-2010, 03:58 PM
7 is as low as they come
戦争イーグル
Cory J
Wheel converter,
10-13-2010, 04:11 PM
I am watching this thread with eagerness...
I have pretty much decided that the OME lift kit is the best kit for me, for what I want, but I won't be hauling weight most of the time, so softer would be good for me too. It seems that stock LC coil and shock absorber are pretty cheap, and would probably work for me (since it sounds like I want the same as you).
How do the front 881's in front feel to you?
2000 SR5 3.4L V6 Automatic 4x4, e-locker, 175k Miles, Rust
Imp. Jade Mica with Oak Leather Interior, Field Monitor Unit - B&M Tranny Cooler - SG2 - New (to me) rear axle assembly - Goodyear Duratrac 265/75-16 - 1.8" Ironman Front Lift, OME 906/Procomp 9000 Shocks
http://www.toyota-4runner.org/3rd-ge...ld-thread.html
10-13-2010, 04:13 PM
So are you pairing the rear LC shock with a front LC coil?
10-13-2010, 05:50 PM
Yeah, thats what you do. I read that thread and have a price quote on that shock as well.
戦争イーグル
Cory J
Wheel converter,
10-13-2010, 09:17 PM
Real Name: Rob
Real Name: Rob
yes rear LC shocks with front LC coils, the part number in my last post are rear LC shocks. Rockdawg84 has em on his runner, i've driven it and they are perfectly fine.
10-26-2010, 03:41 PM
Ok, so the hunt for the LC 7 wraps has begun. If all goes well I will have the rear OME springs for sale afterwards. I'll try the springs with OME shocks first, if they don't feel right I will be swapping and selling those too. The wheeling I will be doing probably won't make the suspension flex to it's limit.
00 4runner
10-26-2010, 04:52 PM
What about 9 wraps? How do those compare to OME 891?
4Runner Lifted/Locked/Armored/Blown
www.texaswheelin.com
