10-17-2010, 03:37 PM
seafoam
which line do i suck up the seafoam with? i have the 4 cylinder and i have no idea which one it is. If someone can post a pick that would be awesome! thanks
98 runner 2WD 2.7L manual
wouldnt want anything else!
Graphite painted rims
bilstien shocks and struts
future lift... message me if you have any good ideas for that
10-17-2010, 05:58 PM
I don't want to give you the wrong info but I used the vacuum line that ran to my brake booster. Thats what a mechanic friend of mine suggested but it wasn't for the 4cylinder. Can't imagine it would be any different though.
戦争イーグル
Cory J
Wheel converter,
10-17-2010, 06:39 PM
Moderator
Real Name: James
Moderator
Real Name: James
I used the same one for some BG44k on my 4 cyl a while back,
Here's a few pics but make sure you feed it in slow, don't let the engine stall.
IG: @jimharb | YouTube | '99 Limited 2WD |
'99 4Runner - 2.7L 3RZ-FE - TRD S/C - 4WD Conversion + R150F 5-Speed Swap - Imperial Jade Mica on Oak
'87 4Runner Turbo - 2.4L 22R-TE - CT-26 Supra Turbo - W56 5-Speed Swap - Red on Red
'90 4Runner 2-Door - 3.0L 3VZ-E - Auto to R150F 5-Speed Swap - Red on Gray
'94 Supra Turbo Targa - 3.0L 2JZ-GTE - Marlin Crawler R154 - Imperial Jade Mica on Black
'89 Supra Turbo Targa - 3.0L 7M-GTE - Marlin Crawler R154 - White Package on Blue
'89 Pickup DLX 2WD - 2.4L 22R-E - W55 5-Speed - White on Blue
10-17-2010, 06:41 PM
Same here. Brake booster vacuum line.
10-17-2010, 07:28 PM
The guy told me to pour it in until it stalled. I poured as fast as I could and it never did stall. smoked like hell though
戦争イーグル
Cory J
Wheel converter,
10-17-2010, 07:35 PM
just did it. waiting to start it back up. gotta wait 30 minutes right? and yeah i was told to make it stall too and mine just wouldnt give up. i was pouring really fast too. hahah finally turned it off after a bit.
10-17-2010, 07:47 PM
Just wondering how that worked for you I ask because I see the line you used is right above the 2nd cylinder port looks to me like the line that comes off of the top at the throttle body valve would be a better location to get the sea-foam or what ever you use to all 4 cylinders instead of just the first 2
just my observation but I have done this kind of thing only on older carborated motors so you just dump it straight down the carb.
2000 4RUNNER SR5 TRD Supercharger, OME 882's w/ topout's and n91sport strut up front.OME 851's w/ cones and trekmaster LC shocks in the rear. R.I. LED lighting, retrofit E locker, 1" diff drop, 315/75/16 cooper discoverer STT, 2" R.B. body lift, rear disc brake conversion, Ingen intake, Spectre cone filter, Fitch fuel cat, Cobra LTD29 CB, custom front, and rear bumper, smittybuilt 8000 # winch, 66" 4xinovations rock sliders w/kickout, lil skip's gas tank skid. Custom skid plates. My build thread is @ http://www.toyota-4runner.org/3rd-ge...ld-thread.html
10-17-2010, 09:02 PM
Moderator
Real Name: James
Moderator
Real Name: James
I definitely experienced a positive difference, but I bet the other two didn't get the cleansing the others did.
10-17-2010, 09:43 PM
Just something to think about. Also when I did this it was because I had a stuck valve and I used a mixture of 50%ATF, 25%STP, 25%5w-30 total one quart get engine to running temp then pour in slowly at first at about 2000rpm then dump it in till it died let set over night a HOLLY SMOKE CLOUD the next morning but worked great thing ran like a champ afterwords. The thing smoked so much I,m sure they would arrest you here in So Cal.
10-17-2010, 09:45 PM
"Pour it in till it stalls?" Sure sounds like a recipe for a hydrolock!
2000 4runner Sport, SAS/4wheel Underground 3 link, Diamond axle, 14" Radflo coilovers, double locked, Custom rear 3 link, 12" Fox shocks, full armor Gerdo's Build Thread
Real Fuel Tank Skidplates for sale Lil' Skip's OffRoad
Rear control arm mount skids and Hi-Lift adapter for sale Lotus Development
10-17-2010, 09:50 PM
That was my thought but the old guy that told me to do this had never steered me wrong before and it did work for me a side note this was on a 75 scoutt 2 no smog anything.
10-17-2010, 11:00 PM
^ x3.
2021 Tacoma 4x4 TRD Off Road Double Cab Short Bed (my DD)
2017 4Runner 4x4 Limited (the wife’s)
10-27-2010, 04:44 PM
Just used seafoam in my '95 for the 1st time today. WOW! That was a lot of smoke. I only let it sit for 5 minutes though. Should I do it again and let it sit longer next time? I also poured the rest of the bottle in the gas tank. Hopefully I'll see a MPG improvement in the next few tanks. Right now I'm getting around 14-16 mpg.
