10-18-2010, 01:18 AM
rear differential fluid change
i want to do this sometime to my 98 2WD 4runner. my differential appears to have a little plug at the bottom and i was wondering if this was meant to drain the fluid out? or would i have to take the entire back plate off?
98 runner 2WD 2.7L manual
wouldnt want anything else!
Graphite painted rims
bilstien shocks and struts
future lift... message me if you have any good ideas for that
10-18-2010, 01:35 AM
Banned
Banned
the bottom one drains it, the top one fills it.
10-18-2010, 01:53 AM
is it as easy as it sounds? haha
10-18-2010, 01:57 AM
and what kind of oil do i replace it with?
10-18-2010, 07:37 AM
It is as easy as it sounds, but only if you follow the proper procedure.
Take the filler plug off first
This is the plug on the back side of the housing, behind the parking brake cable. If you take the drain plug out first, you may find you can't get the filler plug off, and you cant fill it, and you are screwed.
take the filler plug off, then take the drain plug off, let the oil drain, replace the drain, then fill it with some gear oil. I think 75W-90 or thereabouts is good.
technically you are supposed to use new crush washers when you do this. You have to get them from a dealer. They are not very expensive, but you should probably be able to reuse the old ones.
2000 SR5 3.4L V6 Automatic 4x4, e-locker, 175k Miles, Rust
Imp. Jade Mica with Oak Leather Interior, Field Monitor Unit - B&M Tranny Cooler - SG2 - New (to me) rear axle assembly - Goodyear Duratrac 265/75-16 - 1.8" Ironman Front Lift, OME 906/Procomp 9000 Shocks
http://www.toyota-4runner.org/3rd-ge...ld-thread.html
10-18-2010, 12:22 PM
Real Name: Robert
Real Name: Robert
How many quarts would be needed to do the front and rear diffs? I have a 95, but I would assume they would be the same.
My 4runner Build Thread 2000 Limited 4runner SOLD
My Tundra Build Thread 2006 Double Cab Tundra SOLD
My Humpty Dumpty 4runner Build Thread 1999 Highlander 4runner
10-18-2010, 12:40 PM
what are crush washers?
10-18-2010, 12:56 PM
Crush washers in this case are small rings or aluminum that get crushed in between the plug and housing to create a tight seal. They are considered non-reusable because to function properly they have to be deformed, and therefore won't work the same the second time you use them.
In reality you can reuse them once or twice, but you want to replace them when you can because they really do get damaged in use.
11-22-2011, 03:37 PM
Instead of creating a new thread I drummed up an old one. I cannot find the information im looking for here or through google. Does anyone know what they different torque ratings on the bolts for the front & rear differentials is? Also transfer case bolt torque ratings?
I'm trying to do this today but if I dont get a good answer today Ill wait til tomorrow. Thanks.
2000 Limited Sports Edition, 285-75-16, TOYTEC Adjustable Front Coilovers, OME 891 & Bilstein 5150's rear, TOYTEC 1' Differential Drop, E-Locker, 4X4, 4.56 Gear Ratio, Tundra 231 Brakes, All-Pro Apex Front Bumper, OL Rear Swing-Out, 4X Innovation Sliders, Savage Offroad Skids300K, JVC Radio, Tacoma Whip, CB Radio
11-22-2011, 03:39 PM
Tight enough... Seriously who puts a torque wrench on crap like this?
1996 4Runner Limited 4x4, 3.4L V6, E-locker, 210k miles and counting, fresh fill of Pennzoil Platinum 5w30
2005 Honda CRF250R
11-22-2011, 03:44 PM
11-22-2011, 03:50 PM
All the torques for every component on the vehicle are listed in the FSM. Check out the tutorial and documentation reference thread and read the FSM.
11-22-2011, 03:55 PM
FSM- Factory Scheduled Maintenance?
Sorry if that's a dumb question.
11-22-2011, 04:17 PM
Factory Service Manual
Toyota Factory Service Manuals (FSM) - all years - YotaTech Forums
85 Xtracab, 3Link Front, Marlin Dual Ultimate, Double Locked on 37s
11-22-2011, 04:19 PM
It's linked in the tutorial and documentation reference sticky thread. If you havn't visited that thread, then don't make another post until you do, because most everything you will ever need is there.
