10-18-2010, 05:21 PM
blinking red light on instrument panel ... engine won't start
Hi everybody,
I have a 1998 4Runner that recently won't start.
There's a red light on the instrument panel, right next to the Instrument panel light control knob, that won't stop flashing. (it's never lit before) According to the manual, that light is where the rear differential lock switch is supposed to be. Whether the key is in the ignition or not, the red light keeps blinking.
When I open any door, the tail lights and the front side lights switch on and off 15 times in a row, and then turn off... but that red light on the instrument panel continues to blink unless I disconnect the battery terminals.
Since the battery is still providing juice to power the lights, I'm assuming this isn't a battery issue. As far as I know, nobody has ever installed any alarm system on this car. When I try to start the car, it doesn't even sound like it's trying to turn over. It's as if the system is locked somehow. Does anybody have any idea what this red blinking light is telling me?
Thanks!
10-18-2010, 05:55 PM
Moderator
Real Name: James
Moderator
Real Name: James
Originally Posted by natrovert
Hi everybody,
Thanks!
No one has had an alarm installed? weird... I would say sounds like an alarm tripping balls...
IG: @jimharb | YouTube | '99 Limited 2WD |
'99 4Runner - 2.7L 3RZ-FE - TRD S/C - 4WD Conversion + R150F 5-Speed Swap - Imperial Jade Mica on Oak
'87 4Runner Turbo - 2.4L 22R-TE - CT-26 Supra Turbo - W56 5-Speed Swap - Red on Red
'90 4Runner 2-Door - 3.0L 3VZ-E - Auto to R150F 5-Speed Swap - Red on Gray
'94 Supra Turbo Targa - 3.0L 2JZ-GTE - Marlin Crawler R154 - Imperial Jade Mica on Black
'89 Supra Turbo Targa - 3.0L 7M-GTE - Marlin Crawler R154 - White Package on Blue
'89 Pickup DLX 2WD - 2.4L 22R-E - W55 5-Speed - White on Blue
10-18-2010, 06:23 PM
Def sounds like an alarm (lights flashing, engine start disabled, etc). No clue what else it could be. Pic?
I'd say look under the front seats and look good under the dash for an alarm box.
edit: Wait, the flashing light is on the dash next to the dimmer knob? Sorry, I must have mis-read that the first time. Sounds like the factory VIP RS3000 alarm to me...
“Engineers don’t idle well.”
'99 Limited 4WD
Upgrades: BFG AT T/A KO 265/75/16, Husky floor liners, WeatherTech window deflectors, Silverstar Ultra headlights, TaskLED Dome lights, Red & White LED maplights, LED tails & 3rd brake light, 35% tinted front windows, TrueFlow air fliter, hardwired V1, Scion T1807 HU w/ Aux input, Masterflow MF1052 in rear side storage
Mods: Deckplate/ISR, independent fog light control, rear diff breather, constant hot 12v outlets, seat-mounted LED Maglite
10-18-2010, 08:56 PM
Thanks for the replies!
I checked with the previous owner... it turns out they forgot that there was an alarm installed at one point. I checked under the dash and found 2 boxes that look like they could be an alarm box... one of them says "SAE PP-T20"... and it looks exactly like the pic in this link: Alarm Sensor?
I can't see the other, bigger box too well. I can read some text on the back... looks like it's describing what each wire is for:
black - ground
red black - door lock polariy
black green - not used
red - 12v
pink - aux out
org - siren
white - trigger
gray - led
20ga blue - switch 12v
green - unlock switch
Thanks for helping me figure out that much. Since I can't move this car, does anybody know how I can remove this alarm that I never knew I had? =P Or at least get it so that I can start the car again?
Thanks!
10-18-2010, 08:58 PM
Hmmm, that is kind of an important point...
2000 SR5 3.4L V6 Automatic 4x4, e-locker, 175k Miles, Rust
Imp. Jade Mica with Oak Leather Interior, Field Monitor Unit - B&M Tranny Cooler - SG2 - New (to me) rear axle assembly - Goodyear Duratrac 265/75-16 - 1.8" Ironman Front Lift, OME 906/Procomp 9000 Shocks
http://www.toyota-4runner.org/3rd-ge...ld-thread.html
10-18-2010, 09:02 PM
Follow the wires and see which is giving it power. Then cut the power wire. When all else fails... Cut the Muther F'er out! lol
'99 4Runner Limted 3.4l v6 4x4
10-18-2010, 09:41 PM
Sounds like the starter is disabled due to the alarm. Try this.
Close all doors, use your key, stick it in the drivers side door-lock and unlock 2 times (which is clockwise) This should reset the alarm.
2001 4Runner SR5 3.4L V6 4x4 A/T Stellar Blue
265/70/16 Michelin LT M/S,
Deckplate Mod, K&N drop-in, 100km miles/
1999 Acura Integra Gsr Supersonic Blue
10-18-2010, 09:49 PM
that resets factory alarm?
I had to put key in ignition turn to on, hold down factory alarm reset button located on driverside kickpanel, still holding reset turn key back off and then back to on. Truck would start after sequence.
戦争イーグル
Cory J
Wheel converter,
10-18-2010, 10:18 PM
Yes, I have the RS3200 alarm, and that is how I reset the alarm. My FOB key blows up the taillight fuse everytime I would use it, so now I use the actual key to arm and disarm the vehicle.
08-30-2017, 09:39 PM
Hi everybody,
Thanks!
I know this is an old thread but I need HELP!! I recently just bought a 2000 and mine does the same thing, I found where someone had rigged some wires together behind the kick panel. I followed them around for a minute and the alarm just kept going and going so I just jerked all the damn wires out. Fixed the issue I thought...no more alarm going off when you open the door or anything like that but now the lights just flash on like 3-4 times every 2-3 minutes and the little red theft light on the dash blinks constantly when the door is closed, open the door and it stops and the lights won't flash on and off periodically. I work on cars every day but this damn thing really has me scratching my head.
08-04-2019, 08:24 PM
I hope it's okay to resurrect this old thread...
Our 1999 4Runner is having a similar issue with the security system. There's a red light to the left of the steering wheel (no button), and a small red button on the vertical kick panel (if that's what it's called?) to the left of the clutch pedal.
The red light was flashing (no alarm sound), and what worked to start the vehicle was to hold down the small red button while turning the key to on (the horn beeped at this point), then back to off, releasing the button, then starting the vehicle as usual (like in the post quoted below). However, after doing this, the red light stayed on (not flashing), and to start the vehicle again we had to do the same process, holding the small red button down etc. I've tried holding the button down while doing the on-off key turn three times, per some of the above-mentioned advice, but this didn't affect the red light.
I've read through various threads and haven't found anything regarding when the light is solid red. I'm also hesitant to try disconnecting the battery, as it appears this could cause an alarm to go off when reconnected?
Thank you in advance for any advice on this!
09-15-2019, 11:56 PM
Real Name: Ram Rod
Real Name: Ram Rod
Trying to bring this back as well...my girlfriend has a 1999 T4R with the same equipment (little red ******* light, kick panel button) we were at the car wash one day and when she went to start the truck it did literally nothing. The marker lights were flashing. We finished cleaning our rigs and still no start. I guess I got lucky somehow after sticking the key in the door locks and opening and shutting the hood and the truck fired right back up no problem. Jump forward to now and the marker lights will start to go off whenever you open the back door (nothing has to be locked), she occasionally has a problem with the engine immobilizer and her key fob does not/will not work.
2006 Limited V8 nautical blue purchased 2019 90k fresh timing belt and an unhealthy exhaust tick.
Independent fog light mod, rear pallet mod, gen 5 Powerstop brake calipers with z36 pads and GCX coated rotors all around.
09-16-2019, 02:12 AM
Take the car to an MECP-certified alarm installer and have the aftermarket alarm someone installed removed. These alarms often included a starter/transponder key bypass that will have to be removed and the original wiring will have to be reconnected, hence why you can't just yank the thing out and hurl it into the bin.
2000 4Runner Limited - 2WD, 3.4L V6, Automatic - Bilstein 4600/Moog 'Tall' Springs, Manik brush bar, PowerStop Tundra Brake Upgrade w/ Stoptech SS Brake Lines, KC Hilites 6" Pro-Sport HID Spread Beam Pair Pack System w/ KC Lexan covers, 4th gen 17" wheels w/ Spidertrax and Rugged Ridge 1.25" spacers, oEdRo LED headlight bulbs, BMW E92 seats, ScanGauge II, Prodigy TBC
03-10-2021, 08:44 PM
98 RS3000 factory installed orig owner
Gave my 19y/o this beast and he had dead battery during cold spell, and upon hooking up new DieHard horn sounds. Pulled fuse to horn, so now only electric that works is interior dome, headlights, and blinking red door open indicator on dash and security light near emergency break handle. All fuses are good--tested starter relay=good and have attempted locking/unlocking door with key(no electric to door locks) 5 times to on position in ignition, reset button on rs3000 box--all to no avail. Moved relays around-no help. Anyone have any idea what on earth killed this classic joy of a ride?
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
