Old 10-21-2010, 01:34 PM #1
jahahai jahahai is offline
jahahai is an unknown quantity at this point
Angry Power Steering Rack Center Bolt
I just can't seem to find a way to break loose the center bolt on the power steering rack. I am replacing the bushings with ones I got from Wheeler's. Does anyone have any suggestions??
Thanks in advance.
jahahai is offline   Reply With QuoteReply With Quote
Old 10-21-2010, 01:42 PM #2
brian2sun's Avatar
brian2sun brian2sun is offline
brian2sun will become famous soon enough brian2sun will become famous soon enough
brian2sun's Avatar
What have you tried so far? I broke mine loose with a breaker bar without too much trouble. If you're trying to break it loose with a normal wench or ratchet it probably won't budge very easy and may break a ratchet. Did you spray it down with PB Blaster and let it sit for a day or so?
1997 4Runner 4x4 SR5 - Geared, Locked & Armored
**CLICK FOR '97 BUILD THREAD**
2021 Tacoma 4x4 TRD Off Road Double Cab Short Bed (my DD)
2017 4Runner 4x4 Limited (the wifeís)
brian2sun is offline   Reply With QuoteReply With Quote
Old 10-21-2010, 01:50 PM #3
It's only been sitting in PB Blaster for half a day. I've tried using a normal wrench and a breaker bar. I tried by going through the passenger wheel well, but I just don't have enough clearance to make it budge. I've even removed my sway bar but still no luck.
Old 10-21-2010, 01:52 PM #4
Diagram14's Avatar
Diagram14 Diagram14 is offline
Diagram14 is on a distinguished road
Diagram14's Avatar
x2 on the breaker bar. I needed some extra leverage becuase of the tight quarters. The hinged head gets you away from other parts as well so you can feel more comfortable in leaning on the bar without fileting your knuckles on them. I hate when that happens...
2000 SR5 Sport 4x4. Head Gasket mod. Rear Axle Seal mod. Functioning 4x4 mod. SOLD
2004 DC Tacoma TRD. Same guts, different skin, e-locked.
Diagram14 is offline   Reply With QuoteReply With Quote
Old 10-21-2010, 01:55 PM #5
brian2sun's Avatar
brian2sun's Avatar
You're talking about the 22mm one, right? You may need to put the truck up on a lift or tall stands so you have more room to get the leverage you need with the breaker bar. I have a lift so it was easier to get a turn on the bar under the truck.
Old 10-21-2010, 01:59 PM #6
It's the 19mm one. The one that's behind the rack if you were looking from the rear. You have to get it from the top and there's very limited clearance.
Old 10-21-2010, 02:05 PM #7
brian2sun's Avatar
brian2sun's Avatar
Ok, I know which one you mean. Got air tools? You may try an impact ratchet or butterfly with a universal on it and just hold it on there till it breaks it loose.
Old 10-21-2010, 02:18 PM #8
I don't have any air tools
Old 10-21-2010, 02:35 PM #9
It is the center 19mm bolt
Power Steering Rack Center Bolt-steeringrackbolts-jpg
Old 10-21-2010, 03:59 PM #10
quicksilvr's Avatar
quicksilvr quicksilvr is offline
quicksilvr is on a distinguished road
quicksilvr's Avatar
I'm getting ready to do this on my truck as well, and was wondering how everyone gets the center bolt as well...there's not really room on top of the rack to fit an impact wrench up there.....
2001 SR5~Thundercloud Metallic~3.4L Auto~4x4~260k miles~TRD 2gen black Supercharger~URD AFR Calibrator~B&M 70264~Bilstein Adjustable w/ tall '99 fronts~ProComp 3" rear springs~Nitto Ridge Grappler 285/70R17's on 17x9 Enduro's~Yakima RailRider w/48" bars~ScanGauge II
quicksilvr is offline   Reply With QuoteReply With Quote
Old 10-21-2010, 04:59 PM #11
Gerdo's Avatar
Gerdo Gerdo is offline
Gerdo will become famous soon enough
Gerdo's Avatar
It's all about a long lever. Hit it with some PB and use a breaker bar. If needed add a pipe to the bar.
Also try to tighten a little then loosen.
And now the obvious. Lefty loosey. Go the right way.
2000 4runner Sport, ~4"/5" lift, full armor Gerdo's Build Thread
Real Fuel Tank Skidplates for sale Lil' Skip's OffRoad
Rear control arm mount skids and Hi-Lift adapter for sale Lotus Development
Gerdo is offline   Reply With QuoteReply With Quote
Old 10-23-2010, 06:50 PM #12
I managed to get it. I used a 24" breaker bar coming up the miđdle from the rear...
Old 11-29-2017, 02:34 PM #13
Dezerts10 Dezerts10 is offline
Dezerts10 is on a distinguished road
Reviving an old thread cause now I have another question...
I changed my rack bushings and my center bolt and nut came out. I did use my cordless impact on the nut and a wrench on the bolt to hold it. it all came out. Did I break the weld? I did notice the nut isn't a standard tall nut with a lot of surface area on the nut and did almost ruin the nut and need to replace it now so ill probably just get a flange nut and run it. But just curious if they are actually welded on.
Dezerts10 is offline   Reply With QuoteReply With Quote
Old 11-29-2017, 04:15 PM #14
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has a spectacular aura about octanejunkie has a spectacular aura about octanejunkie has a spectacular aura about
If you got the vertical bolt AND nut off then yes, you broke the weld. I imagine this is not the end of the world, but it is one more point of vibration/movement, however slight it might be.
1999 Toyota 4Runner SR5 Sport 2WD, V6 Auto ->My 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 11-29-2017, 04:47 PM #15
Yup, it all came out / off. Chalk it up to another oops I guess. Iíll get a new nut and make sure itís tight as hell.
bushings , steering , wheeler's
Power steering 97 Vs 98 Houston 3rd gen T4Rs 5 09-06-2009 05:36 AM
Power Steering Pump Question wb2fcr 4th Gen T4Rs 2 08-05-2009 05:35 PM
Power Steering help phantom 4runner Classic T4Rs 1 12-26-2008 12:00 AM
power steering fluid?? MD4Runner014 4th Gen T4Rs 4 12-22-2008 09:34 PM
Strange sound from power steering? Red Classic T4Rs 8 06-04-2008 05:18 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
