Old 11-18-2012, 06:33 PM #1
smkd13's Avatar
smkd13 smkd13 is offline
Real Name: Ben
smkd13 is on a distinguished road
smkd13's Avatar
Real Name: Ben
what gear ratio
ok so i have a DD that will see trails. will be running a 33 to 34 in tire and wondering if i should go with a 4.56 or a 4.88?
smkd13 is offline   Reply With QuoteReply With Quote
Old 11-18-2012, 07:05 PM #2
GX4SEVEND's Avatar
GX4SEVEND GX4SEVEND is offline
GX4SEVEND has a spectacular aura about GX4SEVEND has a spectacular aura about
GX4SEVEND's Avatar
Stock is 4.10 or 4.30 depending on year and elocker. So going to a 4.56 wouldn't be worth the price tag. My vote would be for 4.88 or 5.29
‘14 SR5 in white
Front: King ext travel 2.5 w/ adjusters, TC UCA/LCA
Rear: King 2.5 shocks w/ adjusters, Dobinson’s 3” Icon Billet lowers, Icon tubular uppers, PCK
Wheels/Tires: SCS SR8’s w/ Toyo MT 35x12.50x17
Full RCI skids
GX4SEVEND is offline   Reply With QuoteReply With Quote
Old 11-18-2012, 07:09 PM #3
02SE 02SE is offline
02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold
Which engine and transmission?
02SE is offline   Reply With QuoteReply With Quote
Old 11-18-2012, 07:59 PM #4
smkd13's Avatar
Real Name: Ben
smkd13's Avatar
Real Name: Ben
Oh yeah sorry it would be a 2001 with a 3.4 and I believe a340 and no locker. Will be using an arb or zip in the rear. The stock tire on the tag is a 225.
Old 11-18-2012, 08:12 PM #5
downpour11's Avatar
downpour11 downpour11 is offline
Real Name: Rob
downpour11 will become famous soon enough
downpour11's Avatar
Real Name: Rob
Sounds like my stock tire size... You're prob geared at 3.9 right now. I'd vote 4.88's.
DOWNPOUR11's Build Thread
downpour11 is offline   Reply With QuoteReply With Quote
Old 11-18-2012, 09:02 PM #6
smkd13's Avatar
Real Name: Ben
smkd13's Avatar
Real Name: Ben
I have 265/75r16 right now and it seems sluggish as compared to where it should be so I am upping to a better ratio. So what would the adverse side of going 5.29 be?
Old 11-18-2012, 09:11 PM #7
RussToy's Avatar
RussToy RussToy is offline
Real Name: Russel
RussToy is an unknown quantity at this point
RussToy's Avatar
Real Name: Russel
If I'm not mistaken...2001 without a locker, you should have 4:10's from the factory. I'm in the same boat...I have 4:10's and I just put on a set of 33's. I'm been trying to decide what gears to go with also. At 65 mph, I'm only turning 2000-2050 rpm's. I'm thinking 4:88's will be good. I don't to low cause this is my DD too. I'm trying to find one of those charts that shows you which gears to run with what tires and at what rpm's. If I find it, I'll try and post it for you...
RussToy is offline   Reply With QuoteReply With Quote
Old 11-18-2012, 10:32 PM #8
smkd13's Avatar
Real Name: Ben
smkd13's Avatar
Real Name: Ben
I am right about at 2100 at 65 so that would make sense. I will probably go with 4.88. And that would be awesome and definitely helpful.
Anyone heard anything about zip lockers?
Old 11-19-2012, 12:30 AM #9
TheFatGuy TheFatGuy is offline
Real Name: Bryan
TheFatGuy is on a distinguished road
Real Name: Bryan
here is a link to gear chart hope it helpsLift Kits, Tires & Wheels by 4 Wheel Parts
TheFatGuy is offline   Reply With QuoteReply With Quote
Old 11-19-2012, 12:49 AM #10
smkd13's Avatar
Real Name: Ben
smkd13's Avatar
Real Name: Ben
That helped a ton. Thanks for the help bud
Old 11-19-2012, 08:47 AM #11
jitterbox's Avatar
jitterbox jitterbox is offline
jitterbox is on a distinguished road
jitterbox's Avatar
Hi, actually im doing the same. I have already decided for 4.88 by suggestion from trail-gear.com but im afraid of get the wrong parts (10000 km shipping), for the front diff overall.
I have 1KZ-TE engine, don´t know about transmission.
A friend told me the original gear its 4.1 for sure.
Can you help me?
El Seba
1998 SW4 Limited "La iguana"
jitterbox is offline   Reply With QuoteReply With Quote
Old 11-20-2012, 04:50 AM #12
smkd13's Avatar
Real Name: Ben
smkd13's Avatar
Real Name: Ben
What year? And you might check out ringpinion.com it is selectable by axle and as well inchworm (google it) is another good reference.
Old 11-20-2012, 05:01 AM #13
smkd13's Avatar
Real Name: Ben
smkd13's Avatar
Real Name: Ben
Ok so 86 through 95 the front uses a 7.5" standard rotation. 95 and up used a reverse rotation. Here is the like to yours http://www.ringpinion.com/b2c/Produc...nd_Pinion_Sets
And as far as the rear goes main thing is if it has a rear oem locker or not but for the most part it is a 8" and you'll end up with something like this.
Hope that helps
Old 11-20-2012, 01:35 PM #14
jitterbox's Avatar
jitterbox's Avatar
Thanks a lot, its a 1998 4runner, here in Argentina also called SW4 and the most popular engine was the 3.0 Tdi. Rear Diff its ARB and in the front sure it´s the 7.5" you told me. So i expect dont make a mistake, there shouldnt be such differents from yours.
Thanks for the links.
El Seba
Old 11-20-2012, 05:03 PM #15
smkd13's Avatar
Real Name: Ben
smkd13's Avatar
Real Name: Ben
Ok that helps a lot will check it out for u
Gear ratio? alejo2112 4th Gen T4Rs 6 12-05-2019 03:32 PM
gear ratio? lincolndriver Classic T4Rs 14 08-04-2010 06:53 AM
need help with gear ratio..... hdoggie24 3rd gen T4Rs 1 01-02-2010 02:53 PM
gear ratio 4runnerhyde 4th Gen T4Rs 1 08-31-2006 01:19 AM
Gear Ratio smccollamjr 3rd gen T4Rs 8 11-19-2005 10:10 AM
