Home Menu
Site Navigation
User Tag List
Reply
Thread Tools Rate Thread Display Modes
Old 10-28-2010, 05:40 PM #1
tns1 tns1 is offline
Junior Member
tns1 is an unknown quantity at this point
Junior Member
adding a remote and getting at the ecu
98 4runner ltd 4wd
I bought a remote that matches the ID of the working one I have (BAB237131-022).
I see two programming procedures for adding this remote. I tried this one here:
Programming Instructions for keyless entry remote?
Once I get to the step were I cycle the ignition on and off (either once or twice depending if you want to add or re-write) and remove the key, I am supposed to get one or two auto-cycles of the locks as an indicator that the dark gods were happy and I can proceed. Unfortunately this does not happen.
Maybe I am too slow in the earlier steps but I figured I would try the much simpler RS3000 instructions here:
RS3000 Toyota Vehicle Intrusion Protection
Problem is my ECU is not under the seat. It is behind the glove box. Before I dig it out, can anyone verify that my ECU is even going to have the push button? The button is pictured on the side which would mean completely removing the unit and I am not sure you can do this without unplugging it.
Anyone else with a 98 ltd who has added a remote?
tns1 is offline   Reply With QuoteReply With Quote
Old 10-28-2010, 07:19 PM #2
rjaudi rjaudi is offline
Member
rjaudi is on a distinguished road
Member
To be a RS3000 im pretty sure the box is under the seat. What does the box look like? The first link you posted is for a 99 and they used the RS3200. The remote you described is for the RS3000. What does the box look like behind the glove box? There should just be a button you use to program the alarm.
__________________
1997 4runner Limited 4wd- Purchased new by family 12/96
Factory 4.30 e-locker conversion, 265/75 BFG AT, FX-R Hid Retrofit, Kenwood Nav, 231mm Tundra brakes, Grey FJZ80 Wheels, Deckplate mod, ARB Bumper, Hella 4000 compacts, Sonoran Steel 7.2a, Scangauge 2, Extended Diff Breather, Custom Sway Bar Endlinks, Black No Rust Rear Bumper
rjaudi is offline   Reply With QuoteReply With Quote
Old 10-28-2010, 08:18 PM #3
Junior Member
Junior Member
Quote:
When you pull the glove box, you can see the end of the ECM, which covered with connectors and wire harness. There is no button. It is similar looking to the RS3000 picture - an aluminum box about 1.5" x 5" x 7" or so looking at the end - but that was just a drawing anyway, so I'm not sure how accurate it is. I cannot see either side of the ECM unless I remove it. Like I say, that may mean unplugging it, removing the box, plugging it in temporarily while its out, then reinstalling it.
Hard to believe your ltd would be so different from mine. Is there anything that tells me what box I am looking at?
Old 10-28-2010, 08:25 PM #4
KingMedicine KingMedicine is offline
Junior Member
KingMedicine is on a distinguished road
Junior Member
I just dealt with this same issue on my 2002 limited. Basically, i found out that the BAB237131-056 remote didnt work on mine, and i have to get a FCC ID#: HYQ1512Y. And it took a few times, but i got the key/doorlock/dooropen pattern to work but not accept the remote. I kinda have gave up and decided to just get an extra key. I searched high and low for the ECU without any avail.
KingMedicine is offline   Reply With QuoteReply With Quote
Old 10-28-2010, 08:45 PM #5
Member
Member
I'm pretty sure that the 99+ use a different system. Keyless was standard on those limiteds and then the alarm module was an add-on. On the 96-98 the dealer had to install the alarm with keyless. My alarm remote looks like yours. Do you have a Toyota security light installed near the parking brake lever? Do you have a black box under the driver seat zip tied to the carpet?
__________________
Old 10-28-2010, 09:54 PM #6
Junior Member
Junior Member
Yes, I have the Toyota Security light. I only see the seat motor under the drivers seat. How big is this box anyway? Is it plastic or metal? Is this the main engine computer (ECM) on your car or is it something else?
On my car, you can see a little of the ECM just above the top back edge of the glove box when it is open. It has 4 connectors from L to R, 2 fat ones, 1 narrow one, then 1 fat one. The connector size/arrangement is different than the pic for the RS3000.
Old 10-28-2010, 10:01 PM #7
Member
Member
The box looks like this:
RS3000 SECURITY SYSTEM ELECTRONIC CONTROL UNIT RS 3000: eBay Motors (item 260684138251 end time Nov-03-10 17:36:08 PDT)
__________________
Old 10-28-2010, 11:00 PM #8
Junior Member
Junior Member
Well that clears up one thing - this picture is definitely not the ECM I have been talking about. This plastic box looks no bigger than 3"x3" and looks like it has only one connector. When you look under the seat is this thing obvious or is it tucked way up under there?
Old 10-28-2010, 11:19 PM #9
Member
Member
It should be directly under the seat. They are supposed to zip tie the box to the carpet. The alarm, at least on my 97, was a dealer installed toyota accessory.
__________________
Old 10-28-2010, 11:21 PM #10
Junior Member
Junior Member
So its not actually attached to the seat at all, its on the floor under the seat?
Old 10-28-2010, 11:25 PM #11
Elton H's Avatar
Elton H Elton H is offline
Senior Member
Elton H is on a distinguished road
Senior Member
Elton H's Avatar
that one behind the glove box is for the engine
__________________
98 4runner sr5 3.4L 5spd 4x4 e-locker sold 10/2/11
07 tundra 5.7L 4x4 limited dc was my moms r.i.p 3/19/11
Oregon Toyota Owners Club
Elton H is offline   Reply With QuoteReply With Quote
Old 10-29-2010, 12:07 AM #12
Junior Member
Junior Member
I looked again under both seats - nothing but seat motors, and something like an air vent under the passenger seat. I did find the glass breakage sensor up under the dash. Kinda looks like the RS3000 but isnt. Electrical diagrams would help to locate it since it has to tie into the horn, lights and door lock circuits, but Haynes doesn't show any such thing. Any idea how the wiring harness for the RS3000 is routed inside the vehicle? Maybe mine is close by, like under the center console.
Old 10-29-2010, 12:18 AM #13
Member
Member
On this tacoma they installed it behind the kick panel.
http://www.parksoffroad.com/tacomamo...stallation.pdf
__________________
Old 10-29-2010, 12:32 AM #14
Junior Member
Junior Member
There is definitely a black box of some kind behind the kick panel. I'll check it tomorrow.
Old 10-29-2010, 10:44 AM #15
Junior Member
Junior Member
The driver side kick panel does have two ECU boxes one green and one black, but both are marked for 4wheel drive.
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Powered by vBadvanced CMPS v3.2.2
Copyright ©2000 - 2026, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2026 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2026 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2026 DragonByte Technologies Ltd.
Copyright © 2020
