Thread Tools Rating: Thread Rating: 12 votes, 4.33 average. Display Modes
Old 08-20-2010, 09:46 AM #31
Nelsonmd's Avatar
Nelsonmd Nelsonmd is offline
Nelsonmd is on a distinguished road
Nelsonmd's Avatar
Man, I tried this on my 2000 SR5 multiple times and it wouldn't work. I bought the car with 1 remote with a dead battery. I replaced the battery and it actually locked and unlocked the doors a couple times, and opened the rear window, but then it quite working. It was after this that I tried the programming instructions to no avail.
TSand, the different number of times you turn the ignition is supposed to enter the car into different modes, only one of which is rewrite (Programming) mode. I don't remember the details, but google it and you should be able to find it.
Anyone got any tips for me? I know I was completing each cycle in less than 40s. Is there some special rhythm I should follow? Do I need to wait between numbered steps, or just plow through the whole thing?
Thanks, I am really tired of turning around and walking back to the car to lock it.
Nelsonmd is offline   Reply With QuoteReply With Quote
Old 01-18-2011, 07:42 PM #32
azcat90's Avatar
azcat90 azcat90 is offline
azcat90 is on a distinguished road
azcat90's Avatar
Valet OK?
All I have is the Valet key - does the key used for programming the remote (step 2) have to be the master?
azcat90 is offline   Reply With QuoteReply With Quote
Old 01-18-2011, 10:38 PM #33
durrell durrell is offline
durrell is on a distinguished road
Not that I know of. I have two valet keys and it worked for me.
2019 SR5 Premium 4x4 - Black - ReadyLift 3/2 - TRD Pro rims - 275/70R17's
Previous: 98 SR5 4x4, 05 SR5 4x4, 98 SR5 4x4
durrell is offline   Reply With QuoteReply With Quote
Old 01-30-2011, 03:57 PM #34
maxspeed96ct's Avatar
maxspeed96ct maxspeed96ct is offline
maxspeed96ct is on a distinguished road
after hours of tryin, a trip to walmart to buy a new battery I finally got my remote to work.
I was able to get the lock and unlock sequence down right, got the confirmation but couldnt get the damm remote to work.
I was ready to email the ebay seller for selling me a broken remote....
So after alot of trial and error. I took the remote apart again and it looked like the battery wasnt sitting in there right, what i did is I folded up some paper into a 1/4 x 1/4 size square, and placed it between the battery and the rear cover.
And that did the trick ! go figure !
99 4runner sold and missed
now shopping for a 2nd gen taco !
maxspeed96ct is offline   Reply With QuoteReply With Quote
Old 03-03-2011, 02:06 PM #35
js4runner js4runner is offline
js4runner is on a distinguished road
Originally Posted by Rockdawg84 View Post
I know this is an old thread but I thought I would put my update in. I have a 99 SR5 that only had one key fob when I bought it. The dealer wanted almost 200 for a new remote with programing so eBay to the rescue. $40 later I had a used remote that lookes better than the one that came with my runner. I found this thread and followed the directions exactly with no luck at all. I wasn't getting into programing mode. No auto lock and unlock after step 5. I tried about 10 times and no go. So I did a little research and found another set of instructions on the web that were exactly the same except that there was no step 4c. I tried it without 4c and sure enough worked like a charm. I don't know if the issue is because I don't have a limited or what but if one way doesn't work try the other.
Sam
DESPERATE!
Hi I have a 1999 Runner SR5 with the VIP RS3000 facory installed alarm. I purchased the HYQ1512Y alarm remote from Ebay and I am tryign to program.
I have followed the instructions that came with it and the one posted on this board. I can get into the programming mode, but I cannot add the remote. I keep getting the locks to cycle twice(unsuccessful) instead of once (successful) when I hold either the lock or unlock button for 2 seconds.
When I insert the key into the ignition, do I have to turn the key once, twice, three times, or ultimately 5 times? I am getting frustrated?!?!?!
Thanks in advance to all.
JS
js4runner is offline   Reply With QuoteReply With Quote
Old 03-03-2011, 02:28 PM #36
4ganger's Avatar
4ganger 4ganger is offline
4ganger is on a distinguished road
4ganger's Avatar
I did mine last night on my '00. Followed the insrtructions step by step and worked no problem. Turned key twice.
4ganger is offline   Reply With QuoteReply With Quote
Old 03-03-2011, 03:42 PM #37
So do u press the lock/unlock buttons as the locks are cycling or after?
Old 03-03-2011, 04:55 PM #38
4ganger's Avatar
4ganger's Avatar
After.... it took me a few tries to get it right. And one of my remotes needs a new battery so it was a no go.
"5. Within 3 seconds, the power door locks should cycle (automatically)
indicating successful entry into programming mode. Return to step 1
if the locks do not cycle at this point.
6. Perform these steps within 40 seconds:
a. Press BOTH the LOCK and UNLOCK buttons on the transmitter
simultaneously for 1 second.
b. Immediately after letting go of the lock and unlock buttons,
press the lock button by itself and hold for 2 seconds.
Within 3 seconds, the door locks should cycle ( LOCK then
UNLOCK) once-- indicating successful programming. If
the door locks don't cycle, or cycle twice. Repeat steps
6a and 6b--this remote has not been accepted.
Old 03-06-2011, 01:14 AM #39
So i tried using the 5 lock/unlock version of programming my remotes different ways......with doors open and doors closed. Before I was able to get into the programming mode,with the locks cycling 3 times to let me know I am in. BUT NOW IT WON'T.
I've also noticed that my power locks are out of whack! Sometimes they react to the lock/unlock buttons, sometimes they don't. Also I have noticed that when i try getting into the programming mode, the driver's side lock will not go up or down during the 2nd round of locking and unlocking.
Reading a prior post on here, is my driver side lock actuators shot? Or did I screw up some programming sequence. Anyway of resetting things (like unhooking the battery)??
HELP!!! Anyway I can get back at least into the programming mode???
Thanks,
JS
[email protected]
Old 03-07-2011, 11:48 AM #40
BruceB83 BruceB83 is offline
BruceB83 is on a distinguished road
I just picked up a 2001 SRD Sport without a key fob. I called Toyota to confirm it did come with the factory keyless entry. The parts man told me the FCC ID on the fob was HYQ12BBX. This seems odd to me because most of you guys all report using the 1512Y or 12BAN fob for the 97-2002's. The 12BBX is used on the 07-08 FJ's and 04+ 4Runners from what I can tell on ebay.
Does anyone else's 97-2002 use this 12BBX fob? They are much cheaper on ebay and I want to confirm this is the right one before buying one.
BruceB83 is offline   Reply With QuoteReply With Quote
Old 03-07-2011, 10:59 PM #41
4ganger's Avatar
4ganger's Avatar
Ok so I was able to get one to program the other day. Thought the battery was dead in the new one I got off ebay. Went to O'reily and they have a RF remote that tests the battery. Sure enough dead. Changed both remote bateries since they come in pairs.
The good one I got with the car still works. The ebay one... followed all the programming steps but can't get it to take. Everytime I hit both the lock and unlock buttons and then press and hold the lock button it just cycles twice. (vs. once). It's weird.
Hmmm.... has all the exact same markings on the back of the remote.
Old 03-08-2011, 02:54 PM #42
My remote isn't here yet but I tried the instructions to see if I could at least get into the programming mode. No dice. My actuator on the drivers door does slow down a little after slamming the locks back and forth but I even tried manually pulling it up while pressing the button and I still didn't get the locks to auto-cycle. This is frustrating...
Old 03-09-2011, 08:40 AM #43
I tried manually helping the lock go up and down again last night and it finally worked. I was able to get into the programming mode. Any of you guys who are having trouble getting into programming should try this. Can't wait for my fob to get here today or tomorrow!
Old 04-22-2011, 07:53 AM #44
Airgonzo Airgonzo is offline
Airgonzo is on a distinguished road
Keyless codes for LOTS of stuff
Free Keyless Remote Fob Entry programming instructions, procedures for all automotive vehicles
I did not compare the various instructions, but found this site as I was looking at some other stuff.
Airgonzo is offline   Reply With QuoteReply With Quote
Old 05-03-2011, 01:27 PM #45
Diagram14's Avatar
Diagram14 Diagram14 is offline
Diagram14 is on a distinguished road
Diagram14's Avatar
Just programed my 2000 SR5 with factory alarm using the sequence posted by OP and FCC ID: HYQ1512Y. I had to manually aid my locks because the actuators are nearly fried like several other's have. The site that Airgonzo posted is extra informative, referring to the On/Off cycling: 1 time is for original key fobs, 2 times is for new fob, and 5 times to clear all previous codes. It also helps with your Lock/Unlock timing saying to press once ever second: Lock one thousand, unluck one thousand, and so on. When I closed my door the last time my alarm went off. The remote didnt seem to respond at that point so I used my key to turn it off "unlock" and tested the remote's functions after and all seems to work normally. Super excited to have a remote now, one I got for free none the less.
2000 SR5 Sport 4x4. Head Gasket mod. Rear Axle Seal mod. Functioning 4x4 mod. SOLD
2004 DC Tacoma TRD. Same guts, different skin, e-locked.
Diagram14 is offline   Reply With QuoteReply With Quote
Keyless remote / keyless entry reprogramming question(s) Kimm 3rd gen T4Rs 8 11-25-2013 08:51 PM
Keyless remote / keyless entry reprogramming question(s) Kimm 3rd gen T4Rs 2 04-25-2010 12:42 PM
Want Remote and Privacy Screen alaskaman 4th Gen T4Rs 10 01-08-2010 09:18 PM
2004 key gsdpwd 4th Gen T4Rs 6 12-11-2008 11:50 PM
Programming Procedures for Keyless Entry Remote. MDT4RNR Engines / Suspension / Wheels / Tires / Audio / Accessories 4 12-20-2005 11:27 PM
