06-22-2015, 11:05 PM
#31
Real Name: Rich
Real Name: Rich
Originally Posted by mharding
Finally got the parts in from Toyota $107.00 pretty pricey. Here they are, I'll be installing it this weekend.
Hey Mharding, Greetings from the otherside of Carolina! Do you know the part number for the black mast you got??
Thanks man.
06-22-2015, 11:34 PM
#32
From what I have read on another thread.
Non Power Antenna to Tacoma Whip
Parts
Antenna Assembly: 86300-35090 (list price $36.94)
Tacoma Whip antenna: 86309-AA040 ($27.38 at my dealership)
Please note that the Tacoma Whip Antenna is not picture above. If you want the Tacoma black whip antenna, buy part no. 86309-AA0400 and NOT 86309-35100 or 86309-32011. Also, I've received some feedback that the part numbers may have changed. If so, just ask for the non-motorized antenna assembly for a 4runner and a black whip antenna for the Tacoma.
06-23-2015, 06:56 PM
#33
Originally Posted by marmotan
Can anyone verify that the black whip antenna gets better reception than the silver one (which is really just a metal rod, not what I would call a "whip") that comes with the antenna assembly? Some folks have suggested just painting the silver one black, but I wonder if comparing the function of the two styles is really apples-to-oranges. I ask because I live in the mountains and need maximum reception to hear FM radio.
When I ordered my black mast the toyota rep told me that back in the day some customers had trouble getting AM channels so they added the black antenna option (it comes with an additional wire rapped around the rod for better reception).
I personally noticed a very noticeable increase in reception, sound quality, and a few more usable channels that would previously cut in and out. However this change was from my old power antenna and not the tacoma silver rod.
09-23-2015, 10:54 PM
#34
Just Finished the Taco Antenna Mod
I have owned my 1999 4Runner Limited for one week, and I love it. When I bought it the antenna was broken and the previous owner gave me a brand new, still in the package replacement. It was the white gear strip and the antenna.
Unfortunately, there was some nasty metal and plastic stuff mangled up in the tube. So I removed everything and took apart the tube and motor and cleaned it out as well as I could, but when I put it back together the antenna would not return all of the way into the tube. I tried long and hard... and gave up.
I went to the two local dealerships and they did not have the parts for the Taco Mod, but they'd be happy to order them... for godawful sums of money. No, I don't care to support local businesses that steal from me.
So I got the two pieces from Camelback -- they were right in there on price, within a dollar or two from the cheapest, but their shipping was by far the best... like so much less than anyone else.
So, the process was simple. Remove two screws, peel back the wheel well lining, disconnect the motor from the electrical connector, remove one bolt from the antenna motor mount... then take the round nut off the top of the tube where it tightens against the fender. Now the motor just drops out.
Pull out the trim panels around the radio and climate controls... very scary at first but then then come out so easily. Remove four bolts holding in the radio. Pull it out gently. Pull out the larger antenna connector (the smaller one is for the rear antenna) and here's the trick, tie a string to it. Now have a friend pull on the antenna cable from outside while you watch its path inside.
You'll have to remove the glove compartment about now. It's easy, just open it and press the two back ends toward the middle and the glove compartment flops forward, dumping all the contents on the floor. But, you're now able to see the cable move around the vents.
Pull it out through the fender and the motor is free to remove. Untie the string from the old antenna cable and now attach it to the new one. A knot below the antenna connector and a clove hitch around the tip kept it in a straight line and allowed me to pull it through the fender, behind the glove compartment and to the back of the radio.
Plug it in, reassemble the radio and the panel and go outside.
Push the antenna holder up through the hole in the fender, place the rubber grommet into the hole around the antenna and screw the nut onto it nice and tightly. Now put the old bolt through the holder and tighten it down. Push the antenna cord grommet to the fender hole, pushing it in halfway to keep the outside, outside. Now put the wheel well lining back into the slot you pulled it out of, reinstall the two screws and you're done down there.
Now just screw in the mast. Toyota provides a nice little plastic wrench for the purpose. Put it in a handy place so you can remove the mast when you go into a car wash.
It was easy and gave me a good sense of accomplishment.
Thanks for all of the advice.
Joe
Grand Rapids Michigan
09-28-2015, 11:59 AM
#35
I have been running my '00 Limited 4Runner with no antenna now for almost 2 years now. I mostly listen to my iPod anyways. Well, I decided last week to give it a shot, since the previous owner had given me a new mast and I had nothing better to do. I found it very simple to remove the motor. Two square clips on the fender well, peel it back, then voila! After the removal, I discovered that the mast was broken into bits and that the electrical motor itself was almost completely worn out. It has never clicked or done anything since I bought it. After a bit of thinking I chose my free, alternate path. I cleaned out all of the broken mast, then clipped the remaining white nylon strip-gear from the bottom of the antenna. I then put it all back together the way it was. After it was all put back together, I manually raised the antenna with my hand. I grabbed my needlenose pliers and very gently squeezed every expansion joint, so the antenna couldn't simply retract on its own. Now I have an antenna that I can manually raise and retract without spending a dime. The reception is crystal clear...problem solved!!
2000 4Runner Limited 4x4, 3" OME lift, 2nd Gen TRD supercharger. 282,000 miles - SOLD
2010 Jeep SRT8, 7.2 Arrington 440 stroker, 550 whp! - FOR SALE
2007 Jeep Wrangler Sahara...too much to list!!
2015 Ford F-250 Platinum Powerstroke 4X4
02-07-2016, 07:57 PM
#36
Originally Posted by cfranck1
If you want the Taco mod. You will need to buy the whole assembly (86300-35090)
That comes with a silver mast.
If you want a black mast "Like the Tacos have"
then you will have to buy (86309-aa040) also.
Just a note for anyone who is planning on doing this mod, the pn#: 86300-35090 does not come with a silver whip anymore. The parts site didn't mention it was part of the assembly so I'm not holding them responsible for missing parts, was just a pain to have to wait another week for the whip to arrive.
It also looks like 86309-0C020 replaces 86309-aa040 and is identified as a Mast for the FJ Cruiser.
1996 4Runner Limited - Evergreen Pearl
Front: Bilstein 5100\Toytec Eibach coilover kit
Rear: Bilstein 5100\ 8 wrap LC
02-08-2016, 12:23 AM
#37
Real Name: Hoodlm
Real Name: Hoodlm
Not sure what the "Taco Whip Mod" is but I disconnect the quarter panel and removed the motor and antenna. Then I installed this whip. Got sick of them breaking out in the woods.
2000 4Runner Limited, 2" ToyTec Body Lift, 255/85R16 Maxxis Big Horns, 3" Lift Bilstein 5100s front and rear, OME 891 rear springs, 4x Innovations Rock Sliders, Silencer MOD, Deckplate MOD, PlastiDip Guru, Total Chaos UCAs, ToyTec Adjustable Rear Lower Links and Panhard, Tundra Brake Upgrade
My Build Thread
02-11-2016, 08:34 PM
#38
I listen to a ton of AM radio so I hope to be doing this too. The non-Toyota antenna seems like a good option.
Does anyone else listen to AM radio and notice an improvement by getting rid of the powered piece?
'97 4Runner Limited 4x4 w/Locker, Grey (Red & Blue) Wire Mod, 2Lo Mod, Tundra DC Non-TRD front with stock Tundra Tokicos, Downey 3" rear lift with Monroe Reflex Shocks
Other project: BMW e34 540i/6
07-23-2019, 08:37 PM
#39
How's the reception with this small antenna? What is the model #?
07-24-2019, 02:29 PM
#40
Just finished this the other day too. Toyota base and a 15 inch whip. Looks much better and reception is great. I listen to am/fm and Bluetooth radio adapter (stock radio for now).
There's danger lurking around every corner, that's why I propose we make all of our buildings round.
I don't remember the time I was human that's why I don't understand anybody.
08-11-2019, 06:31 AM
#41
I'm in the same boat as the rest of you guy's and like this short whip you have used especially with your recommendation of great reception. Is this one a Toyota part or aftermarket one? Would appreciate the part number and where you found it? Also, how has the noise level been? Thanks for any help you can offer.
LMS
08-11-2019, 07:34 PM
#42
LMS
The I purchased both the base and whip from amazon.
Base:
Genuine Toyota (86300-35090)... https://www.amazon.com/dp/B00P2QI9M8...p_mob_ap_share
Whip:
AntennaMastsRus - 15 Inch Black... https://www.amazon.com/dp/B00KTFLX98...p_mob_ap_share
08-12-2019, 10:25 AM
#43
My solution to the power antenna mast being MIA, no radio frequency, and the power antenna motor driving me nuts.
This did not require any new wiring to the radio.
Theres 2 couplers with the edges ground down in the middle to make contact with the antenna wiring and the bottom/middle couplers tacked in place. Its a tight enough fit that I had to tap it into the sheathing with a hammer.
The result is an antenna mast that will take any 1/4x20 thread or adapter. Seems to work exceptionally well.
All in all... $2 for the allthread, $2 for the couplers, and $11 for the shorty antenna with adapters.
First photo was test fitting and checking reception. 2nd photo is of the allthread cut down and couplers tacked on place and after tapping with a hammer into place in the original tube.
Last photo is sideways, for no known reason
08-18-2019, 05:17 AM
#44
I did this mod Saturday and all things considered it wen't rather well!
I will have to pull it apart again when time permits as the bolt broke off
that supported the old / new antenna. The flange that holds the antenna
is just sheet metal so I guess I was lucky t have not broken it trying to
remove the old bolt. Maybe a consideration to order an extra one when
purchasing a the fixed whip setup. I was surprised the taped wire fit where
the snap holders were from original antenna wire mounted.
Thanks again 2TH4IST for the link to the short whip, as it sure looks better than the taller one from Toyota. FM has great reception and AM seems to be
not too bad either, but need to compare against a fixed radio and will let you
all know what I find today.
LMS
08-20-2019, 11:28 AM
#45
....I hate shipping costs
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
