01-15-2011, 08:50 PM
#46
Real Name: Casey
Real Name: Casey
Originally Posted by brian2sun
I've never hit it with my leg (and I'm 6') and don't notice it's even there. Mine has a bottom mounted speaker so I couldn't really put it in the dash or on the side of the hump where Elton mounted his and still be able to hear it well. This was really my only choice, but it worked out just fine.
How do you have it mounted up there? I bought some "Industrial Strength" velcro and it held for half the day!
'98 4runner | SAS'd | Locked F/R | Armored | Supercharged | URD Goodies |
My Build Thread
01-15-2011, 10:08 PM
#47
I bought a 4Runner this month and the previous owner had a CB installed:
I've removed it because my knee kept hitting it... and I have a cell phone.
97 SR5 4x4
Josh's World
01-22-2011, 04:40 PM
#48
Real Name: Michael Catarineau
Originally Posted by ADH8796
did you need a right angle adapter?
2000 SR5 3.4 V6 (White) - Cobra 18 WX ST II, 4' FireStik FireFly, 17" FJ Cruiser Rims, 265/70/17 BFG All Terrains, Deckplate mod, and that's all... for now!
03-08-2011, 10:17 PM
#49
Moderator
Real Name: Waldo
Moderator
Real Name: Waldo
Cobra WX ST II
I didn't have to use any kind of special adapters or brackets for it to work. I managed to secure it with the stock plate.
'99 Toyota 4Runner LTD - Dual Locked | Geared | Mid-Travel | 35s | Armored
03-12-2011, 05:51 PM
#50
Real Name: Jim
Real Name: Jim
Moved the Uniden to the ashtray and got a stereo pocket. Used the light from the ash tray to light said stereo pocket.
Cell pic.
'13 Tacoma TRD-OR: The Spruce Goose. BUILD
'02 Sport Ed.- V2.0: The better build. Totaled BUILD 2.0
'02 Sport Ed.- V1.0: The college build Sold BUILD
03-25-2011, 03:17 AM
#51
CURRENT 06: / 4Runner Limited http://www.instagram.com/foxyt4r/
SOLD:99/ 4Runner Limited/ 3.4Auto/ eLocker rear/ 265/75/16 Hankook Dynapro ATM RF 10/ Toytec DiffDrop/ LC 8 Wrap rear coils/ TRD Tacoma front strut/ coils+Toytec / Kenwood 6000EX NAV/ Dynamat Xtreme/ 20% tint/ '02 Grill/ Drifter33 mount/ Yakima racks/ Nat White/ SilverMetallic Cladding(k82)
SOLD:99/ Tacoma xCab/ 2.7 5spd/ Maxxis Bighorn/ Lifted/ Locked/ 4.88/ F&R Bumpers, Sliders, BudBuilt Skid+Bellypan/ / Diff Breather / OBA/ / Black(202)
06-25-2011, 10:14 AM
#52
What model
Cell pic.
Ripcord,
What model Uniden is that? I like how flush it mounts, does that head unit come ready to mount a PA?
Thanks
2000 SR5 Sport 4x4 5 Speed - Sonoran Steel Lift Kit System 1.2 - Front: 3.5": TRD coils & Bilstein 5125 shocks -1" diff drop - Silver skid plate - Rear: 4.5": FJ80 coils & 5125 shocks. - Pan/track bar by Sonoran - K&N CAI - ProComp X-treme AT 285/75/16 - Shrockworks Front Bumper - CBI Rear Bumper w/swing away - Shrockworks Rock Sliders - Flowmaster 40 & 2.5" catback - Alpine Type S - All Pro 1.5" spacers - Yakima Loadwarrior & two viper bike attachments - Tinted front windows to match - Sylvania HID fronts - Custom 'hulk' shift knobs - TRD shift knob - Powder coated 5 Star wheels - Energy Suspension Poly Steering Rack Bushings - Black Tacoma Whip - Uniden PRO520XL w/4' Firefly and PA
06-25-2011, 11:40 AM
#53
Real Name: Jim
Real Name: Jim
Thanks. Its a Uniden Pro 520 XL. Yes it has a audio jack in the back for PA and another for an external speaker. I just have a PA hooked up, no speaker because the built in one works fine.
It is only that far in because of the Coax L-Fitting I bought. They cost like $3 though.
I have a little write up for the install on page 1 of my build. Link in sig.
06-25-2011, 06:17 PM
#54
Antennae
I have been reading up on the Uniden PRO520XL, and the Cobra 19. I think I am sold on the Uniden since it is 0.25" shorter and should fit a bit more flush if I get the 90* coax adapter.
According to some things I have read, there are certain antennaes that work better with specific radios. What antennae do you guys recommend for the 520XL? I do not want to drill holes, and would prefer it to be the 36" whip since primarily I will use it for communication with buddies while wheeling and of course the PA.
Also, where did you wire the power? I read the PRO520 manual and it says it is important to know whether the power source is positively or negatively grounded. In line fuse? Direct to battery?
Thanks in advance.
06-26-2011, 01:12 AM
#55
Thanks in advance.
I've got a 510XL (same diff) and I use a 48" SS whip. Didn't research it, I just had it kicking around, so on it went. I'm no expert on antennas but in my experience as long as you set your SWR properly, it should be fine. I wired the power in parallel with one of the lighter plugs in the dash and put an inline fuse on it. Simple and easy. The truck is negatively grounded. You typically only see positive grounding on older British cars.
06-30-2011, 11:44 PM
#56
Ripcord,
Can you walk me through the wiring of your CB? I understand there is a positive, negative and then the microphone. Microphone is simple. My question is about the positive and negative...likely not to be run straight to the battery. Did you install a fuse/relay? You use an 'ad-a-fuse' on the fuse box...tie it into the ignition somehow??
Any help would be appreciated! Wiring is NOT my cup of tea....
Thanks
07-01-2011, 12:06 AM
#57
Real Name: Jim
Real Name: Jim
I had a shop do it, but what they did was tap the ignition fuse under the driver kick panel. The wire to the CB had an inline fuse already built-in. Then just ground it somewhere behind the dash.
07-01-2011, 12:14 AM
#58
So what wire goes to the fuse? Isnt there a positive and a negative wire for the CB? Or is it a power wire, and a ground?
Like I said I am not good with wiring...I have never 'tapped' a fuse before, what does that entail? Maybe you can send a photo??
Thanks
07-01-2011, 12:19 AM
#59
Real Name: Jim
Real Name: Jim
Red is power, black is ground. Once you get the radio and look at it, it should make sense. For the record, I hate wiring too. haha
07-01-2011, 09:07 AM
#60
Thank you Ripcord. I am still a bit unsure on how to tap it into the ignition fuse. Can anybody offer a description and a photo on how to do this? Also, what ground did everybody use?
Thanks!
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
