Old 11-13-2010, 01:50 PM #1
Big Bore Big Bore is offline
Big Bore is on a distinguished road
Hesitating/surging, loss of power and mileage
98 LTD is having serious loss of power issues. Recently gutted the cat and changed fuel filter when I initially noticed slight loss of power. Soon after a misfire appeared, not sure which cylinder I simply replaced plugs and it went away. However loss of power has continued and become worse. When engine was misfiring it would occasionally throw a CEL which would go away, usually a flicker. Put a scanner on it and no codes and misfire did not show up on scanner even though it was indeed misfiring. Buddy has repair shop and scanner is top end unit. Currently planning to replace both 02 sensors and cat. Also going to check fuel pressure possibly do compression test. My current theory is a lean condition brought on by either bad sensors/false readings from post cat sensor or weak fuel pump. Any other ideas what would cause a hesitating/surging loss of power?
Symptom is is a very rhythmic hesitation/surging with low power and engine accelerating in short rhythmic surges.
Thanks for any advice or help.
Big Bore is offline   Reply With QuoteReply With Quote
Old 11-14-2010, 12:55 AM #2
JohnsD90's Avatar
JohnsD90 JohnsD90 is offline
JohnsD90 will become famous soon enough
JohnsD90's Avatar
Change the Wires, they are probably original and prolly causing the misfire, the gutted CAT is prolly what's causing part of your lack of power, Gas 4runners dont have turbo's and therefore don't produce enough backpressure to sustain full power with a gutted CAT so you end up losing power and making it louder.
JohnsD90 is offline   Reply With QuoteReply With Quote
Old 11-16-2010, 09:26 AM #3
I guess I wasn't clear in original post, sorry. The miss went away with the new plugs. Now it's just the lack of power and surging and poor mileage. The more I research the more I'm convinced the problem was a bad 02 sensor to start with, causing lean fuel condition. Old plugs were very white. New 02 sensors and cat on the way. Read on here somewhere Amazon was best price for Denso 02 sensors, good info it's true.
Old 11-16-2010, 09:37 AM #4
creatix's Avatar
creatix creatix is offline
creatix is on a distinguished road
creatix's Avatar
I would second John's opinion that the slight power loss you're experiencing comes from the gutted cat. As explained above when you gutted the cat you've reduced back pressure AND "low end" torque in favor of higher RPM power output. This would have been a good mod for the supercharged engine but not stock.
1996 Toyota 4R-SR5, Original Owner
182K/miles+, Original, unrestored engine/tranny
Tough work horse that survived big battles!
creatix is offline   Reply With QuoteReply With Quote
Old 11-16-2010, 12:24 PM #5
It's not slight, and it occurred before I gutted the cat. In any event I'm putting new cat and 02 sensors in because it ran fine with that equipment before. Plenty of power and great mileage. Once that is replaced if problem continues I'll begin investigating. As I stated earlier I am pretty well convinced the original problem was faulty 02 sensor.
98 4Runner LTD w/rear diff lock stock for now
99 F250 Super Duty 4x4 daily driver runs high 12's and gets 15mpg passing everything in sight
06 Jetta TDI
08 Hyundai Vera Cruz
69 J2000 Gladiator stepside built 350/T18 mild lift
Old 08-05-2017, 09:43 PM #6
Atomhurst's Avatar
Atomhurst Atomhurst is offline
Real Name: Atom hurst
Atomhurst is on a distinguished road
Atomhurst's Avatar
My brother is having the same problem with his 2002
My brother had both cats replaced, maf, ignition coil, fuel filter, and air filter. Inspected plugs, wires, fuel pressure, and fuel trims. Every thing looks good and is within spec. Also it has a very delayed shift. Trans fluid level and quality is fair. Whatever it is, it's not throwing any codes and we are both pulling our hair out. Any other advice is appreciated. Also noticed this thread is from 2010. Any fixes?
Atomhurst is offline   Reply With QuoteReply With Quote
Old 08-07-2017, 06:25 PM #7
Atomhurst's Avatar
Atomhurst's Avatar
Update on my brothers runner
So my brother too his truck to get smogged and they said that the rear cat is illegal for the state of California. So he went and got the correct cat put on. When they were cutting the rear cat off they must have broken loose some debris from the front cat. After a couple days of driving that debris must have come loose and clogged the rear cat. He ended up replacing the front cat with no change in performance. He took it back to the muffler shop a couple times and they told him it was a mechanical issue and that he needed a tune up. So I told him to get a second opinion from the exhaust shop next to my work and he did. They showed him the brand new rear cat was clogged from debris from the front cat. They put a straight pipe on it temporarily and this restored all his power.
Old 08-07-2017, 06:33 PM #8
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
I had the issue you described along with a CEL, was a bad ignition coil, but I did suspect the fuel pump/injectors.
I started checking/replacing the easiest things that probably needed it:clean the MAF sensor, replace plugs and wires, replace fuel filter, then coil and fixed.
Good luck!
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Power loss toybox Problems & Warranty Issues 21 08-12-2011 12:22 PM
Power Problem 4runnerGA Classic T4Rs 4 03-28-2010 05:26 PM
would EVAP codes = bad gas mileage?? 01t4rnr 3rd gen T4Rs 3 02-03-2010 06:35 PM
Loss of power, poor mileage 4Runner92 General Discussions 1 11-10-2009 12:58 PM
Gas & Mileage in the Rockies - Better? TeryT 4th Gen T4Rs 7 09-05-2006 02:39 PM
