Old 11-16-2010, 12:21 PM #1
billkmiami billkmiami is offline
billkmiami is on a distinguished road
Question low brake pedal
How do I improve my brake pedal feel in my 1997 4runner? I have new pads front and back- drums are adjusted properly- no fluid leaks what so ever- the pedal almost goes to the floor before the brakes grab- they still work fine- if I pump the pedal it will improve but then after I release and reapply, the pedal seems to "lose pressure" and the pedal will sink to the floor- The truck has 161K on it (2wd) - I adjusted the pedal under the dash but this did not help at all- any suggestions?
billkmiami is offline   Reply With QuoteReply With Quote
Old 11-16-2010, 01:21 PM #2
BTO's Avatar
BTO BTO is offline
BTO is on a distinguished road
BTO BTO is offline
BTO's Avatar
Probably a bad master cylinder.
BTO is offline   Reply With QuoteReply With Quote
Old 11-16-2010, 03:46 PM #3
CO_FlyFisher's Avatar
CO_FlyFisher CO_FlyFisher is offline
CO_FlyFisher is on a distinguished road
Symptoms of a failing master cylinder. Don't drive it like this for too long!!! You don't want to LOSE your brakes when you need them!!!
“Engineers don’t idle well.”
'99 Limited 4WD
Upgrades: BFG AT T/A KO 265/75/16, Husky floor liners, WeatherTech window deflectors, Silverstar Ultra headlights, TaskLED Dome lights, Red & White LED maplights, LED tails & 3rd brake light, 35% tinted front windows, TrueFlow air fliter, hardwired V1, Scion T1807 HU w/ Aux input, Masterflow MF1052 in rear side storage
Mods: Deckplate/ISR, independent fog light control, rear diff breather, constant hot 12v outlets, seat-mounted LED Maglite
CO_FlyFisher is offline   Reply With QuoteReply With Quote
Old 11-16-2010, 06:31 PM #4
rjaudi rjaudi is offline
rjaudi is on a distinguished road
Could be a bad master cylinder, but first I would bleed the brakes really well. I had this first time I bleed the brakes. Then I redid the bleeding and they are perfect.
1997 4runner Limited 4wd- Purchased new by family 12/96
Factory 4.30 e-locker conversion, 265/75 BFG AT, FX-R Hid Retrofit, Kenwood Nav, 231mm Tundra brakes, Grey FJZ80 Wheels, Deckplate mod, ARB Bumper, Hella 4000 compacts, Sonoran Steel 7.2a, Scangauge 2, Extended Diff Breather, Custom Sway Bar Endlinks, Black No Rust Rear Bumper
rjaudi is offline   Reply With QuoteReply With Quote
Old 11-17-2010, 10:43 AM #5
I am leaning towards the bad master cylinder- 161K on the original part- may try the bleeding first though to see if this helps! most of the mileage is city type driving so it makes sense the master cylinder is just worn out! thanks!
Old 11-17-2010, 11:15 AM #6
cfranck1's Avatar
cfranck1 cfranck1 is offline
cfranck1 is on a distinguished road
cfranck1's Avatar
When stopped at a light or something, pump the pedal a few times to build a little pressure, then hold the pedal down. It should start dropping slowly if it's a bad Master Cyl. It would be leaking past the seals inside the cylinder.
01 SR5 - 187k+/- 285 BFG A/T KO2 - 99 talls & front Trekmasters / Rear KYB - Hella fogs - Taco Mod - Fixed gaping hole in frame {SOLD}
02 Taco - 197k +/- BFG A/T KO2 285s + rims from 4Runner - saving up for suspension - House gets priority over Taco (for now)
cfranck1 is offline   Reply With QuoteReply With Quote
Old 11-19-2010, 09:38 AM #7
if I pump the brake pedal at a stop and after pumping it keeps the pressure than what else could it be?
Old 11-19-2010, 06:13 PM #8
That could be air in the system (a fair amount).
'99 Limited 4WD
Old 11-19-2010, 10:41 PM #9
Jon's Avatar
Jon Jon is offline
Jon is on a distinguished road
Jon Jon is offline
Jon's Avatar
You say properly adjusted, but have you tried tightening the rears again and again? I had the same problem. From under the truck on jack stands, tighten the rears till the wheels spin with a little brake rub then tub on the parking brake cable and try spinning again, bet the noise is gone. tighten again repeatedly like that and the pedal will come back. Reasoning behind this is there is so much fluid loss going to the rear that the pedal has to compensate b going to the floor before adequate pressure is applied to the front which are your main stopping power.
(SOLD and missed) TRD S/C'd/5spd trans swap/locked w/4.88s/on board air/Toytec 3.5"front/Superfex springst+1.5" spacers rear/35x12.50R17 Pitbull Rockers/AOR tube bumper/XRC8 Winch/custom snorkel/6000K HID Heads/18" LED light bar/Herculined floors and lots of stickers for added horse power
Build Thread
Jon is offline   Reply With QuoteReply With Quote
Old 11-20-2010, 10:57 PM #10
assman assman is offline
assman is on a distinguished road
i had this issue also. my front calipers were bad
assman is offline   Reply With QuoteReply With Quote
Old 11-29-2010, 04:02 PM #11
replaced the master cylinder this past weekend, bled each brake cylinder/caliper at each wheel- very easy! this solved the problem- brakes still grab a little too low compared to my Taco but they do work excellent- big difference for my 161000 + miles 4-Runner! worth the $300 bucks- bought an original (Japan made) from the dealer vs paying $150 for a Chinese no name brand..........no issues with the install at all!
Old 10-10-2017, 05:45 PM #12
stever1000 stever1000 is offline
stever1000 is on a distinguished road
I'm having the same issue, but replacing the master cylinder did not cure the problem - anyother suggestions?
stever1000 is offline   Reply With QuoteReply With Quote
Old 10-10-2017, 05:58 PM #13
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has a spectacular aura about octanejunkie has a spectacular aura about
If your MC hold pressure after pumping it then the seals are probably good. Brake fluid is caustic stuff and eats everything, including the rubber hoses eventually. I would do a full bleed of each circuit until you get clean/clear fluid out of each bleeder - there's probably air or other fluids/crap in one of the circuits.
Do this with a friend and make sure to never let the reservoir on the MC run out or you will be starting the bleed over.
Also, never fill your brakes from the caliper/cylinder up to the MC unless the system is new. You don't want to flush junk in the lines up to the MC.
For all the "I have this problem too" as well as the OP
Brakes are one of the easiest and most overlooked systems on a car, yet we trust our lives to them without thinking twice
Inspect your brake hardware regularly!
Address uneven wear!
Address uneven stopping, pulsing, pulling, noise and vibration!
Balance and install your wheels correctly
Make sure you bed new brakes properly
And most important, don't drive from gas to brake; allow a safe distance between the car in front of you and let off the gas and coast in gear to slow down/shift to lower gear.
1999 Toyota 4Runner SR5 Sport 2WD, V6 Auto ->My 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 10-10-2017, 06:00 PM #14
phattyduck is a splendid one to behold phattyduck is a splendid one to behold phattyduck is a splendid one to behold phattyduck is a splendid one to behold phattyduck is a splendid one to behold phattyduck is a splendid one to behold phattyduck is a splendid one to behold
Is the pedal sinking, or just engaging too low?
I would suspect issues with rear brake adjustment or air remaining in the lines.
'16 Honda Odyssey
Dynamic Rear Proportioning (aka EBD) Thai 4th Gen T4Rs 1 06-20-2011 09:24 PM
diagnosing Brake Master Cylinder soundstudio315 Problems & Warranty Issues 2 05-05-2009 11:44 PM
Brake feels mush only at low speed(local driving) pwu 3rd gen T4Rs 1 03-26-2006 10:35 PM
Unsightly Brake Dust (and what you can do about it) Thai Maintenance/Detailing 0 01-16-2003 01:15 PM
