11-22-2010, 11:38 AM
Big Brake Kits?
I recently purchased a 98T4r that is completely stock. I came from a highly modified subaru impreza. My previous car weighed 2800lbs and had 6 piston calipers and 332mm rotors. That car stopped on a dime. Recently someone slammed there brakes on in front of me. I stomped the 4runner brake pedal at about 30mph and the 4runner began to slowly roll into a stop. I had to swerve to avoid the car, this freaked me out a little bit.
This experience has motivated me to start researching what the BBK options are on the 4runner. The 4runner weighs in at about 5,300lbs so making it stop quickly is going to be a challenge. Is there anybody out there that has tried various larger caliper/rotor combinations on these trucks yet?
1998 4Runner SR5
11-22-2010, 11:44 AM
Search for "Tundra brakes". There are two sizes . Some fit with some wheels and the other will fit with others.
I think someone here has done a rear disk conversion also.
2000 4runner Sport, SAS/4wheel Underground 3 link, Diamond axle, 14" Radflo coilovers, double locked, Custom rear 3 link, 12" Fox shocks, full armor Gerdo's Build Thread
Real Fuel Tank Skidplates for sale Lil' Skip's OffRoad
Rear control arm mount skids and Hi-Lift adapter for sale Lotus Development
ya 4runners dont have the best brakes look up tundra brakes lots of info
98 4runner sr5 3.4L 5spd 4x4 e-locker sold 10/2/11
07 tundra 5.7L 4x4 limited dc was my moms r.i.p 3/19/11
Oregon Toyota Owners Club
11-22-2010, 09:16 PM
Look no further. Tundra brakes will stop your heavy pig on a dime.
I attached the link to my build thread. Page 5 includes pics of the swap.
Mr. Leary's 3rd gen 4runner - Page 5 - Expedition Portal Forum
It should take a few hours. Very easy swap. Justcheck to make sure the brakes will fit under your rims.
11-22-2010, 09:46 PM
Just know your 4runner will never stop like that Scooby did (I'm sure you knew that) unless you put on MASSIVE truck brakes which will likely require 20"+ rims...
edit: And as others have said, search "tundra brakes" here for the most economical way to upgrade your brakes. I just put on the "smaller" of the two upgrades; 199mm S13WE Tundra calipers with Brembo Tundra rotors (Model #25534) and the rig now stops beautifully.
“Engineers don’t idle well.”
'99 Limited 4WD
Upgrades: BFG AT T/A KO 265/75/16, Husky floor liners, WeatherTech window deflectors, Silverstar Ultra headlights, TaskLED Dome lights, Red & White LED maplights, LED tails & 3rd brake light, 35% tinted front windows, TrueFlow air fliter, hardwired V1, Scion T1807 HU w/ Aux input, Masterflow MF1052 in rear side storage
Mods: Deckplate/ISR, independent fog light control, rear diff breather, constant hot 12v outlets, seat-mounted LED Maglite
Reason: added info
11-23-2010, 10:06 AM
A 98 4Runner does not weigh anywhere near 5300 pounds, you are referring to the GVWR, which is the vehicle plus its maximum interior load carrying capacity combined. 3rd gens weigh about 4,000 lbs., and I would agree the Tundra 232mm swap is the way to go, I swapped out the rubber lines for stainless while I was in there.
2002 4Runner Sport
PP/H&R 1" lift springs
Bilstein HD's TRD Cat Back Exhaust
231mm Tundra Brakes
Stainless Brake Lines
11-23-2010, 06:46 PM
Real Name: Justin
Real Name: Justin
I just had my brakes switched to the Tundra rotors and Tundra 199mm calipers too. The difference is noticeable, and at least no more worries about warping rotors!
Just as an FYI, if you go with the smaller 199mm calipers, you will still need to trim the calipers or put wheel spacers on, if you have the same setup as me. I have a 98 with the 16 inch six spoke rims.
Check out my Instagram! @808_hiker
1998 4Runner Limited Desert Dune 3.4 V6 Auto 4x4 ToyTec Ultimate/Superflex 3” Lift ~83k miles
2008 Tacoma Regular Cab Desert Sand 2.7 4banger 5MT 4x4 Bilstein 5100/AAL/Block 3” lift ~101k miles
2010 Tacoma Access Cab Black Sand Pearl 4.0 V6 Auto 4x4 TRD Off Road ToyTec Ultimate/Dakar 3” lift ~22k miles
2018 Tacoma DCSB Quicksand 3.5 V6 6MT 4x4 TRD Sport ToyTec Boss/Dakar HD 3” lift ~6k miles
11-23-2010, 09:08 PM
As another FYI, the S13WE 199mm Tundra calipers fit fine under my factory 5 spoke wheels.
'99 Limited 4WD
