Old 11-30-2010, 12:30 PM #1
stro908 stro908 is offline
stro908 is on a distinguished road
Picked up a 2000 Sr5 Sport...
...with 180 k on the clock. In "decent" shape I think the color is called "mica jade" (green). Runs strong.
Needs valve cover gasket, front rotors (only 6 months old) are warpped, going to put the Brembos on. Have had good luck in the past with them.
and CEL is on.
Picked it up for $4500! I think I got a great deal.
Thoughts?
also, where should I pick up an external tranny cooler?
Thanks!
stro908 is offline   Reply With QuoteReply With Quote
Old 11-30-2010, 12:38 PM #2
cbrew325 cbrew325 is offline
cbrew325 is on a distinguished road
You might try tightening the valve cover bolts before replacing the gaskets. On small leaks that's sometimes all it takes. Also, look into the Tundra brake upgrades before going Brembo. And third, the most common CEL is an o2 sensor failure but check the codes to be sure. If so, replace with a Denso.
Is it 4wd or 2wd? $4500 seems like a deal if it's 4wd.
cbrew325 is offline   Reply With QuoteReply With Quote
Old 11-30-2010, 01:15 PM #3
Thumbs up
its 4x4.
I was thinking of cranking down the VC bolts a bit, and o2sensor was also what I had in mind.
can I do the Tundra brake upgrade on the Sport? Its my understanding that the sport has 13" rotors...
thanks for the imput!
im pretty sure I got a sweet deal
also to clarify, I have used the Brembo rotors, not the entire brake upgrade.
I am pretty sure the Brembo rotors have a thicker brakeing surface.
SR5 sport pkg. or base 4 cyl. stick stro908 3rd gen T4Rs 6 11-29-2010 09:57 PM
SR5 to SPORT Conversion nk13 4th Gen T4Rs 22 10-25-2010 09:30 AM
2000 4Runner SR5 HVAC controls brian4runner 3rd gen T4Rs 4 01-20-2008 12:03 PM
Fuel tank capacity for 2000 6cyl SR5? SCKodiak 3rd gen T4Rs 9 07-25-2005 09:21 AM
2000 SR5 with a 4cyl? Niitehawkxe 3rd gen T4Rs 3 03-30-2005 11:21 PM
