Old 11-30-2010, 08:01 PM #1
hardtime hardtime is offline
hardtime is on a distinguished road
98 4r with bad hesitation under acceleration
Greetings, we have a 1998 4r with 3.4L 6 with 5 speed manual, 220,000 miles
The hesitation started over the summer and I replaced the fuel filter under the drivers side frame rail. The problem went away for a month or so. Now it is back and even worse. When accelerating it hesitates between 2k and 3k rpms like it is starving for fuel.
Anybody have experience with this or know what direction to send me in would be great!
hardtime is offline   Reply With QuoteReply With Quote
Old 11-30-2010, 08:14 PM #2
brian2sun's Avatar
brian2sun brian2sun is offline
brian2sun has a spectacular aura about brian2sun has a spectacular aura about
brian2sun's Avatar
When was the last time you did plugs and wires and are you using dual electrode NGK or Denso plugs? If those are good check the coil packs, then injectors. If all that checks out, I would test cylinder compression.
1997 4Runner 4x4 SR5 - Geared, Locked & Armored
**CLICK FOR '97 BUILD THREAD**
2021 Tacoma 4x4 TRD Off Road Double Cab Short Bed (my DD)
2017 4Runner 4x4 Limited (the wife’s)
brian2sun is offline   Reply With QuoteReply With Quote
Old 11-30-2010, 08:40 PM #3
trailmix's Avatar
trailmix trailmix is offline
trailmix is on a distinguished road
trailmix's Avatar
I had a tundra that would do this, felt like the darn thing was coming apart if you gave it anything more then about 50% throttle, replaced the fuel filter and it was back to normal. I know you said you replaced it, did you use a toyota fuel filter assembly and is there any possibility that it could be clogged again. Sounds like its running out of fuel.
1985 4runner 22re solid axle 5 speed 5.29's
1996 4runner Limited E-Locker, Boosted, OME, KM2's, 4x Sliders, ARB Prado Bar, Warn M8000
trailmix is offline   Reply With QuoteReply With Quote
Old 12-01-2010, 11:35 PM #4
OHFIRERUNNER's Avatar
OHFIRERUNNER OHFIRERUNNER is offline
OHFIRERUNNER is on a distinguished road
Had the same problems. Changed out the fuel injectors got refurbed ones off ebay that work awesome now. But like brian said check the coil and plug as they cost alot less than doin injectors. I ended up having two plugged injectors and 1 bad coil. Now the rig runs like no tomorrow
98 4RNR 3.4L SR5, Magnaflow Exhaust
OHFIRERUNNER is offline   Reply With QuoteReply With Quote
Old 12-02-2010, 12:09 AM #5
notrayray's Avatar
notrayray notrayray is offline
notrayray is on a distinguished road
notrayray's Avatar
Is there a reason to think your fuel tank is rusty/etc?
Did it sit for an extended period of time?
Are the symptoms the exact same?
2001 M. Silver 4WD SR5 5VZ Love Machine
3rd Gen FAQ Here
notrayray is offline   Reply With QuoteReply With Quote
Old 12-02-2010, 04:16 AM #6
pitpatt pitpatt is offline
pitpatt is an unknown quantity at this point
i have a 98 4runner with around 205k miles on it and mine was doing the exact same thing. Drove it hard enough one day to throw a code and it read as a misfire in cyl. 6.
Went to autozone and picked up new ngk wires (TE66) and ngk plugs... feels like a new truck and havent had a problem since.
That is where i would start just my thoughts
pitpatt is offline   Reply With QuoteReply With Quote
Old 06-01-2011, 03:14 PM #7
3.5inmag 3.5inmag is offline
3.5inmag is on a distinguished road
BUMP!! Same problem here with mine. 98 4Runner Limited (5VZ-FE) 4x4 Auto. 267,000 miles and due for a tune up ASAP. Already replaced the TPS. Bucks and jumps like the dang rear end is about to go. It does this in 4th gear only. Horrible acceleration with lots of hesitation in every gear.
3.5inmag is offline   Reply With QuoteReply With Quote
Old 06-01-2011, 03:16 PM #8
A.Wilson013's Avatar
A.Wilson013 A.Wilson013 is offline
Real Name: Alex
A.Wilson013 will become famous soon enough
Real Name: Alex
I do not mean for this to be rude at all, curse the internet for making it look that way.
DO THE DANG TUNE UP!!!!
2006 Lexus GX 470 Sport- RR Diff Lock, Metal Tech Sliders, RCI Aluminum Skids, Front Runner Slimline II Rack, SCS F5s, 255/80R17 ST Maxx , OME BP-51s, Dirt King UCAs, Metal Tech RR Lower Links
2016 Lexus IS300 F Sport- F-Sport Air Filter RR Racing tuner
A.Wilson013 is offline   Reply With QuoteReply With Quote
Old 06-01-2011, 04:07 PM #9
CharlotteFire's Avatar
CharlotteFire CharlotteFire is offline
CharlotteFire is on a distinguished road
Had the exact same problem, did a wire and plugs change and shes running perfect!
96' SR5 4x4 Surco roof rack, Bike rack, Blackout badges and wheels, 2.5in Lift, Kelly AT's
CharlotteFire is offline   Reply With QuoteReply With Quote
Old 06-01-2011, 04:57 PM #10
jeeper1 jeeper1 is offline
jeeper1 is on a distinguished road
Like what Brian said, plugs and wires should do the trick especially at 267k. Keep us posted and let us know what happens on the outcome.
- 99 SR5 4wd 3.4 - Camburg Coilovers and Upper Control Arms - OME rear coils - 33" BFG KM2's - 17" Raceline Wheels Black - Lockrite Locker in the rear - All-Pro Sliders - Cobra CB Radio - Sport Hood -
jeeper1 is offline   Reply With QuoteReply With Quote
Old 06-01-2011, 05:28 PM #11
LCPLHumiston LCPLHumiston is offline
LCPLHumiston is on a distinguished road
Had the same exact problem like 2 days ago. Except the mechanic gave me an o2 sesnor and the 02 had no sensor. He replaced it with a sensor and it worked perfect. But my car wouldnt even go past 2k rpms.
1999 4Runner SR5 4wd 265/70/16 General Grabber AT2's
LCPLHumiston is offline   Reply With QuoteReply With Quote
Old 06-01-2011, 08:29 PM #12
Dang man, take a chill pill!!!! I was just seeing if it was what I thought it was. Plug wires are being changed right now... Well, not exactly right now because I'm on my laptop. Plugs are coming after this paycheck. Sucks being a broke college kid.
Old 06-13-2011, 12:48 PM #13
Imagine that. The plugs were wore slap out. I hopped in, enjoyed my hesitation-free acceleration, and an armadillo. It accelerates 100x better. FWIW, I asked about the hesitation deal on yotatech and they were some d*cks about my question. Thanks for not flaming guys. Oh yeah, buying plugs at the dealer is the cheapest/best way to go. 6 OEM Denso's for $20!
Old 07-28-2014, 02:47 AM #14
gwlgis gwlgis is offline
gwlgis is an unknown quantity at this point
Resurecting this thread in hopes of it helping me.
Had similar problem, replaced plugs (they needed it, as evidenced by what the old ones looked like) but didn't do the wires.
Problem was 'solved' for a week or so, but now it's back to the same hesitation.
I'm thinking new wires. Should i get these at toyota?
Keep in mind... I am NOT a mechanic, I work more with computers. My neighbor helped me do the plugs (he IS a mechanic (diesel, but he knows what he's doing).
Suggestions for particular parts?
Thanks in advance for the assistance.
Greg
GWLGIS
-97 Dirty/rusty (white) 4Runner w/ 282K (and counting).
Stock except: Magnaflow
-97 Green Limited 4Runner w/130K (and counting)
Stock
gwlgis is offline   Reply With QuoteReply With Quote
Old 05-06-2017, 01:32 AM #15
trdsport's Avatar
trdsport trdsport is offline
trdsport is on a distinguished road
trdsport's Avatar
Mine is doing the same hesitation right now with 360k kms..slowing and picking up..it does. when i let go of gas pedal push again it works fine. i think i will start with plugs n wires. Weird thing is it didnt do this until i changed the O2 sensor. Did some of you change the O2 sensor and end up here with this problem.?
2008 4Runner Limited 4.7 V8 Limited, XREAS & Rear Air bag, Nautical blue metallic
2005 4Runner Limited - 4.7L V8 Sold
trdsport is offline   Reply With QuoteReply With Quote
sputtering under full acceleration < 2k rpms denverunner Problems & Warranty Issues 9 12-10-2021 05:48 PM
Rear 02 sensor Bad? 03 v8 tdewitt34 4th Gen T4Rs 0 09-29-2010 10:29 PM
Vibration in steering wheel/column on acceleration rlamb 5th gen T4Rs 1 03-16-2010 09:47 PM
Split Second Hesitation at Specific RPM wlmbusiness 3rd gen T4Rs 2 01-25-2009 08:25 AM
