12-04-2010, 03:13 AM
I need some help from some stock 5-star wheel peeps.
Hey... anyone with stock 16" 5 star wheels wanna measure the inside diameter for me? I ask because I want to do a 231mm Tundra brake upgrade and I have Cragar soft 8s. I know the 5 stars will clear those brakes so a measurement will give me reference to know if they will fit with my Cragars or not. Otherwise I'll go with 199mms. 231s would be better though since my truck is heavy. I'm looking for the measurement from the inner edge to inner edge. Gracias.
2021 Tacoma 4x4 TRD Off Road Double Cab Short Bed (my DD)
2017 4Runner 4x4 Limited (the wife’s)
12-04-2010, 04:01 AM
Real Name: Ervin
Real Name: Ervin
97 4Runner SR5 TRDSC URD Yukon Camburg Toytec Trekmaster 4Crawler SonoranSteel Level8 Nitto SavageOff-Road ARB Smittybilt MasterPull Powertank SpiderTrax B&M Jaos Gobi Flowmaster Cobra Firestik Alpine CompuStar Hella PIAA RigidIndustries WeatherTech
my build http://www.toyota-4runner.org/3rd-ge...formation.html July 2012 T4RoTM / 2012 T4RoTY
12-04-2010, 04:23 AM
You should check with the locals like James. See if you can try to put one of your wheels on his runner that already has the tundra breaks. Or maybe there is someone with tundra brakes that is willing to go and have a test fit done. You need also to keep in mind the width of the new brakes. It might clear the diameter, and rub on the inside of the face of the wheel.
2000 4RUNNER SR5 TRD Supercharger, OME 882's w/ topout's and n91sport strut up front.OME 851's w/ cones and trekmaster LC shocks in the rear. R.I. LED lighting, retrofit E locker, 1" diff drop, 315/75/16 cooper discoverer STT, 2" R.B. body lift, rear disc brake conversion, Ingen intake, Spectre cone filter, Fitch fuel cat, Cobra LTD29 CB, custom front, and rear bumper, smittybuilt 8000 # winch, 66" 4xinovations rock sliders w/kickout, lil skip's gas tank skid. Custom skid plates. My build thread is @ http://www.toyota-4runner.org/3rd-ge...ld-thread.html
12-04-2010, 04:26 AM
That's perfect, thank you!!
12-04-2010, 04:58 AM
I cant find it now but someone had posted a pic where the calliper was hitting the face of the rim.
12-04-2010, 02:53 PM
Its not the diameter that is the problem. Its how much room you have from the hub to backside of the spokes. If you see the back of a a 3 spoke and a 5 spoke you will see what I mean.
1997 4runner Limited 4wd- Purchased new by family 12/96
Factory 4.30 e-locker conversion, 265/75 BFG AT, FX-R Hid Retrofit, Kenwood Nav, 231mm Tundra brakes, Grey FJZ80 Wheels, Deckplate mod, ARB Bumper, Hella 4000 compacts, Sonoran Steel 7.2a, Scangauge 2, Extended Diff Breather, Custom Sway Bar Endlinks, Black No Rust Rear Bumper
12-04-2010, 03:16 PM
Ok, I get it. I should be fine then since I have 1" wheel spacers, yeah?
12-04-2010, 03:52 PM
I would imagine so because with the 97 wheels I believe a 5mm wheel spacer would make them work from what I heard. My spare is a stock 97 wheel that I had to grind down about 1 inch outside of the lug nut holes to make it rotate around the caliper. So if you appear to have room there like the 5 spoke wheel pictured you will be fine.
12-04-2010, 10:54 PM
Thanks man, it looks like I'll have more than enough clearance. Hopefully Santa will bring me some 231mm calipers and rotors!
12-04-2010, 11:08 PM
hmmm, you think that I could do the 231s on mine?
Xtreme Alloys Series 7089 Black Finish
16x8, 6 on 5.5 Bolt Pattern
Backspace = 4.5 in.
Max Load = 2200lbs
Finish = Flat Black
Hub Centric = No
Offset = 0mm
12-04-2010, 11:17 PM
I don't know. The Cragars wouldn't quite fit even with my stock brakes so I'm running the 1" spacers anyways. They were only about 1/8" too close to the stock brakes so as long as the 231s are <7/8" wider from center to edge, I should be ok. How close are your calipers to the wheels now?
12-05-2010, 12:22 AM
Im not sure, I guess Ill have to measure, I kinda wanted to get the brakes upgraded before my trip in April. I thought for sure I had to do the 199, but would love the extra stopping power of the 231s...
is it just out that I need? Cuz Ill get wheel spacers if I can make the 231s fit...
12-05-2010, 12:48 AM
Yeah, as far as everybody is saying it's just the inside face of the wheel that's the issue so wheel spacers will take care of it.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
