01-24-2012, 05:34 PM
1999 T4R Rear Hatch Hinge
I recently purchased a 1999 4runner for my wife. I noticed that when she goes to lift the back hitch, it seems to be grinding metal with metal. I looked at the hinges and noticed there is what looks like a pin that literally holds the door in place. It looks as if the pin itself goes thru what I can describe at best would be a bearing of some sort. I dont know what else it could be but that is what seems to have worn completly down. Does anybody know where or what I am talking about? Any help would be greatly appreciated. Thanks
01-24-2012, 06:50 PM
Can you post a pic? Do the shocks hold the door up properly, so the only issue is with the hinge?
2000 4Runner SR5 2wd | 3.4L V6 Auto | Millenium Silver Metallic | 218,000 miles, 1 owner | Sonoran Steel 3.0 ('99 coils) | Tundra 199mm brake upgrade - Brembo blanks & Akebono pads | Koyo 1998 radiator | Bridgestone Dueler A/T 265/75/16 tires | Hella MicroDE fogs | Rear-facing aux lights | Deckplate mod | Fiamm Freeway Blaster horns | Curt Class III receiver | SilverStar Ultra bulbs
01-25-2012, 12:06 PM
The shocks hold up the door pretty decent. I mean I can push it up another 3 to 4 inches but it does the job. I will post a pic soon
01-25-2012, 12:32 PM
New hinge assemblies aren't that expensive fro man online dealer, so perhaps you could replace the whole hinge.
2000 SR5 3.4L V6 Automatic 4x4, e-locker, 175k Miles, Rust
Imp. Jade Mica with Oak Leather Interior, Field Monitor Unit - B&M Tranny Cooler - SG2 - New (to me) rear axle assembly - Goodyear Duratrac 265/75-16 - 1.8" Ironman Front Lift, OME 906/Procomp 9000 Shocks
http://www.toyota-4runner.org/3rd-ge...ld-thread.html
01-25-2012, 01:18 PM
The part numbers for the hinges are
68810-35010 for the right side
68820-35010 for the left side
They are $29.48 each at Toyota Parts - Genuine OEM Toyota Auto Parts and Accessories, $29.74 at ToyotaPartSales.com
They're body-colored so you'd just have to make sure to get the right color.
01-26-2012, 11:32 AM
Pics of the left hinge, u will see wear it is rubbing metal with metal, the pin that runs thru the hing seems to be running thru a washer/bushing/bearing that has worn out
01-26-2012, 11:35 AM
Also, can anybody give me pointers on how to improve the gas mileage!! This thing can swallow up some gas. Will a K&N filter help some? I have the 3.4 V6
01-26-2012, 11:40 AM
Sorry, I just realized i was saying hinge. I sincerly appologize, but i meant where the pumps and the door hook up
01-26-2012, 11:42 AM
There are literally hundreds of threads about this. Not being a forum police, but you will get more from doing a search in the google search bar than anyone here can post. Will be a better use of your time.
Also, I get 17 mpg. People getting 21 is few and far between, I think the consensus is most people get around the same as I do.
01-26-2012, 11:45 AM
01-26-2012, 11:47 AM
Sometimes, improving gas mileage is as simple as replacing: plugs/wires, fuel filter, even an oem air filter as you don't really want to use an air filter that requires oiling them which is not great for your MAF. Unless of course you oil sparingly so this doesn't happen.
'04 GGM 4Runner SE-V8 4x4/XREAS/Auto Dim-Compass rear view/homelink/RSCA curtain system/Pioneer deh-x8500bs/Grabber AT2/Gibson CBE/HCF Delete/Gobi Ladder/yellow HID Fogs.. awdjunkies build thread
Shout out to Stuck_CAPS For this GEM: http://www.toyota-4runner.org/4th-ge...iy-videos.html
01-26-2012, 12:06 PM
If you can get at least 295 miles (with 265 75 16 tires) to the tank, You're doing pretty good. I get all happy when I hit the 300 mark before a fill up. There's only so much you can do with a square box on wheels.
01-26-2012, 12:15 PM
Okay, I see what you mean now. Click here to see a diagram:
1999 TOYOTA 4RUNNER Parts - ToyotaPartSales.com
Looks like this is all part of the shock assembly, which is not cheap, so I don't know if you'd be able to find just the part in your picture unless you could pull one from a wrecked 4runner.
01-26-2012, 12:41 PM
Thanks to everybody for your responses. I have picked up alot of info from this thread. Thanks again for your help, I will see if i can find a wrecked 4 runner somewhere around town...
01-26-2012, 12:49 PM
Something else you might want to try in the interim, is slathering a bunch of white lithium grease in there. After numerous times of open close open close, the grind will eventual go away.
