12-14-2010, 09:39 AM
Real Name: Johnny
Real Name: Johnny
just bought a winch yesterday . . . BATTERY QUESTION. 4runner wouldnt start
i bought myself a birthday/christmas pres yest Amazon.com: Smittybilt 98281 XRC 8 Comp Series Black Winch with Synthetic Rope and Aluminum Fairlead: Automotive
its odd how things happen sometimes. Ive had the current battery in my 4r for less than 5 months and it wouldnt crank this morn. and it has only done it when its reallly cold (like 25 deg in Charleston,SC). what kind of battery should i get since ill have the winch. I dont want to be left stranded; on or off the road.
2000 4Runner SR5, 5vz-fe, 5speed, 246k miles, bfg 35's on stock 1985 4runner wheels
12-14-2010, 10:27 AM
I have the same winch and it was 19 this morning, I've had no problems starting or operating the winch with my Optima Yellow Top. I also have a large system and no need for a capacitor. I've used these batts in all my cars including my high compression motors with high torque starters, fuel pumps and e-fans. They've always performed well for me and are worth the price.
(SOLD and missed) TRD S/C'd/5spd trans swap/locked w/4.88s/on board air/Toytec 3.5"front/Superfex springst+1.5" spacers rear/35x12.50R17 Pitbull Rockers/AOR tube bumper/XRC8 Winch/custom snorkel/6000K HID Heads/18" LED light bar/Herculined floors and lots of stickers for added horse power
Build Thread
12-14-2010, 10:54 AM
Optima Yellow Top(even though some feel they aren't the same quality as before)
Sears Die Hard Platinum(their high end Gel Cell)
Odyssey Gel Cell
Since you are going to be running a winch you will want something that can Deep Cycle. Although I have a Red Top and figure I should be fine.
99 SR5 V6 4WD- just started
SOLD1998 T4R SR5 All-Pro CO's, UCA's and Sliders, SS 1.2 rear only DIY rear bumper, Aussie Locker and 1st gen roll bar mod. Outdoor Logic Front bumper, roof rack and Vision X lights.
12-14-2010, 10:57 AM
Moderator
Real Name: Waldo
Moderator
Real Name: Waldo
Have you checked all your connections? Is it making any noise when you crank it over? A few more details about whats going on could help us out a little better. Might be an alternator issue. Take your battery to get checked out, if it's done for then you know the reason. If it is your battery, get a new one obviously.. however, I think optimas are over rated unless you can find one for cheap.
'99 Toyota 4Runner LTD - Dual Locked | Geared | Mid-Travel | 35s | Armored
12-14-2010, 11:03 AM
Did you install the winch already? It sounds like you somehow drained the battery. Like ARK said, check your connections.
If you have already installed the winch, check the draw when it is off to make sure it isn't defective.
2000 SR5 3.4L V6 Automatic 4x4, e-locker, 175k Miles, Rust
Imp. Jade Mica with Oak Leather Interior, Field Monitor Unit - B&M Tranny Cooler - SG2 - New (to me) rear axle assembly - Goodyear Duratrac 265/75-16 - 1.8" Ironman Front Lift, OME 906/Procomp 9000 Shocks
http://www.toyota-4runner.org/3rd-ge...ld-thread.html
12-14-2010, 11:47 AM
Real Name: Johnny
Real Name: Johnny
this is without the winch installed.
it clicks once when the key is turned. the lights dont dim at all, and there are no signs that the batt is dead. i didnt have time to pull ou the multi-meter this morning to test what was working with. gonna do that when i get home. i havent touched my connections since the battery was put in (i let the guy at advance do it cause its right next to my office). so maybe i will just check/tighten up the connecs and test the voltage of the battery before starting up the vehicle. crappy batts suck. i needed one quick-like, so i didnt spend an arm and a leg. i think it was about 100$.
12-14-2010, 12:12 PM
If it is a loud click and the lights don't dim then it really sounds like the Starter Contacts are going bad instead of the battery.
12-14-2010, 12:18 PM
Real Name: Johnny
Real Name: Johnny
Hmmm. Well that is somethin that I haven't had to do yet. I have 187k miles on my rig, and i bought it w about 92k. Guess I'll start doin some research. I know I've seen some write-ups.
Thanks pikeman.
