Thread Tools Rating: Thread Rating: 5 votes, 5.00 average. Display Modes
Old 05-09-2021, 02:39 PM #166
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
so the 98 referenced above did not work out...
so looking at a 99 limited today....now if I am correct, the 99 limeted with multi mode have a "J" shift style compared to the straight line of like my 2001
1) both will have the push button on side of shifter
2) however my 2001 has a button on dash to lock the diff, but if I understand. where as the 99 will lock when put into a shift postion like 4HL is 4 high locked ? So no other button to push to lock the 99 limited
Also I assume that the 99 "J" shift style is more mechanical and less electrical....whic to me means more reliable and less expensive to repair as I read of one thread where the actuator on a all electrical 2001 transfer case is over $2000 new.
so basically if I do get a chance to drive this 99 I should not see a button on dash to lock the center diff, true ?
of course if it does have a button also....maybe thats a rear locker
Old 05-09-2021, 07:51 PM #167
HiluxSurf SSR-G's Avatar
HiluxSurf SSR-G HiluxSurf SSR-G is offline
HiluxSurf SSR-G will become famous soon enough HiluxSurf SSR-G will become famous soon enough
The 1999-2000 Limited J-shift transfer case will lock the center diff when the transfer lever is in the H4L or L4L position, no switch to be pushed like the 2001-2002 center diff switch.
AWD will be engaged via the 4WD button on the transfer lever as long as the transfer lever is in H2 or H4 position.
HiluxSurf SSR-G is offline   Reply With QuoteReply With Quote
Old 05-10-2021, 04:28 PM #168
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
1) With a 99-00 multimode transfer case it does use a shift pattern, but the only physical shift that the lever does is high/neutral/low range. When you put the shift lever in 4HL it closes a switch in the transfer case and the transfer case actuator shifts the 4wd motor/actuator on the transfer case as required.
2) Correct. A 99-00 will not have any transfer case switches on the dash. The only switch it should have is the button on the side of transfer case selector for 4HI.
Old 01-06-2022, 02:11 PM #169
IronYuppy's Avatar
IronYuppy IronYuppy is offline
IronYuppy is on a distinguished road
IronYuppy's Avatar
Hi, all. Resurrecting this thread for my first post.
I'm in the process of retrofitting a multimode case into my '97 SR-5 (auto). Donor is a 2000 Limited. Both trucks have the e-locker rear. The donor is already picked clean and headed to the crusher, so I don't have a history on it. The t-case is freshly rebuilt, so here we go....
Anyone who has done an auto-to-auto swap like this, any surprises coming my way?
So far it seems pretty straightforward. Details to follow....
(edit: I am using the 2000 4x4 ECU and harness)
IronYuppy is offline   Reply With QuoteReply With Quote
Old 01-06-2022, 07:41 PM #170
Team_Jake's Avatar
Team_Jake Team_Jake is offline
Team_Jake is just really nice Team_Jake is just really nice Team_Jake is just really nice Team_Jake is just really nice
Team_Jake's Avatar
The multimode case is 3" longer than the standard t-case, so you'll have to change out your driveshafts. The front driveshaft is 3" longer, the rear is 3" shorter. Hopefully you got those before that 4Runner went to the crusher.
1999 4Runner Limited - 5VZ, 4wd, Factory E-Locker, Multi-Mode, 5-speed swap, Armored, Icons, 295s (thread)
2001 Tacoma Xtracab - 3RZ, 4wd, 5-speed (Daily Driver)
Team_Jake is offline   Reply With QuoteReply With Quote
Old 01-07-2022, 12:21 AM #171
IronYuppy's Avatar
IronYuppy's Avatar
oof, good to know. I didn't get them, but I know where I can get a set.
Old 01-07-2022, 12:47 AM #172
Real Name: Patrick
Real Name: Patrick
Did you get the 4wd control module and wiring for the multimode transfer case?
Old 01-07-2022, 01:15 AM #173
IronYuppy's Avatar
IronYuppy's Avatar
yes, that I have.
Old 01-07-2022, 08:16 PM #174
IronYuppy's Avatar
IronYuppy's Avatar
found a matched pair of shafts. Project continues.....
Old 01-21-2022, 12:37 AM #175
IronYuppy's Avatar
IronYuppy's Avatar
Done deal. 2000 MM case in my '97 SR-5 auto. Glad I took it to a shop for the wiring, because it was a spicy meatball. In principle not too difficult but it involved relocating the 2000 4x4 module to the DS kick panel, doing a lot of splicing, etc.
Definitely a big improvement over the "locked" 4x4 on unstable paved conditions. As it happens I had a chance to try out the MM on a section of highway with both flooded and icy patches between long stretches of dry pavement. Felt very sure-footed! I can see why Toyota moved to this system. Before this 4Runner I had a '97 FZJ80 with the viscous coupling between driveshafts. That was good for daily driving, but I think multi-mode is even better.
Old 03-09-2022, 03:31 PM #176
Scottyboi88 Scottyboi88 is offline
Real Name: Scott
Scottyboi88 is on a distinguished road
Real Name: Scott
2000 limited 4 runner
I just bought a 2000 limited 4 runner with e locker. And i cant get it to go in 4-high only lo-4 works someone recently told me my previous owner must have changed shifters mine doesn’t have the ‘j’ shifter its just the 3 selections with the push button. By the pictures in this thread its showing to be the one for the 01-02 models. Any info on what i can do or if there were 2000 models made with these shifters thanks
Scottyboi88 is offline   Reply With QuoteReply With Quote
Old 03-10-2022, 01:09 AM #177
Real Name: Patrick
Real Name: Patrick
Does your “e-locker” button have an “x” in the middle of the vehicle or where the rear axle would be? Send me your VIN or post it here and I can tell you what year it actually is.
Old 09-09-2023, 01:35 PM #178
ColoMtnMan ColoMtnMan is offline
ColoMtnMan is on a distinguished road
99' SR5 Manual T-case same as Auto? No MM. J-shift pattern
I've had a bad drive shaft vibration for a while and was saving $$ to get work done on the t-case. I waited too long and the t-case went buh-bye! Had some play in the output shaft of the T-case to the rear drive shaft. Maybe easier to swap out the T-case than get rebuilt anyways?
Looking to get a used one. Is there a difference between a auto and a manual SR5 T-case? I know there is a difference between the Limited and SR5, multi-mode vs not.
I've got a J-shift with no multimode and the rear-lock push button on the dash. It's a manual transmission.
Part #36110-35271 is what I'm looking to purchase? I think?
Read through the thread and as long as it's a SR5 99-00 seems I should be gtg?
T-case Differences (all years of 3rd gens).. transfer case, AWD, multi-mode-pxl_20230907_034806859-jpg
___________________________
1999 4Runner SR5| Bilstein 5100 | OME 819 rear springs | SPC Upper control arms | Spiker hood lifters | Magnaflow Overland exhaust | 3rd timing chain | custom DIY bed and drawer camping setup
ColoMtnMan is offline   Reply With QuoteReply With Quote
Old 09-10-2023, 09:09 AM #179
Real Name: Patrick
Real Name: Patrick
96-00 j shift transfer case will interchange. The automatic transfer cases have a sensor or two more than the manual transfer cases, but they’re simple to swap out. If you get one from a non abs 4Runner it will have a speed sensor in the transfer case as well.
Old 03-05-2024, 09:06 AM #180
1000X 1000X is offline
1000X is on a distinguished road
Lots of good info but haven't figured out all my questions. 2002 4runner vf3am. L N H shifter. Has a flat 6 pin connector on the tcase actuator. It is shifting intermittently. When I shift from 2wd to 4wd its showing the center diff locked. Should you normally have to push the dash center diff lock button to UNlock it once in 4wd or should it go from 2hi to 4x4 unlocked with the shifter button?
1000X is offline   Reply With QuoteReply With Quote
transfer case replacement, what years? njccmd2002 4th Gen T4Rs 2 07-16-2010 10:05 PM
Different transfer case levers in 2nd gens nighthawk Classic T4Rs 2 02-25-2010 08:56 PM
What are the main differences between the 2nd and 3rd Gen's? armybass 3rd gen T4Rs 14 09-03-2009 11:03 AM
92 tranny fluid leaking into transfer case s_to_the_g Problems & Warranty Issues 1 09-07-2005 09:08 PM
transfer case and tranny. What years fit? 85runner Classic T4Rs 2 11-29-2004 02:49 PM
