12-16-2010, 04:01 PM
#16
Originally Posted by brian2sun
Thanks guys, good suggestions. I updated the original post with this info.
No problem, thank you for taking the time to do that. That's a great summary for people new to both 4Runners and 4WD transfer cases.
12-16-2010, 04:08 PM
#17
Yes, well done Brian! Should be a sticky...
12-16-2010, 04:51 PM
#18
Nice job Brian. I thought I knew how they all worked...but no, I learned something new today.
2001 SR5~Thundercloud Metallic~3.4L Auto~4x4~260k miles~TRD 2gen black Supercharger~URD AFR Calibrator~B&M 70264~Bilstein Adjustable w/ tall '99 fronts~ProComp 3" rear springs~Nitto Ridge Grappler 285/70R17's on 17x9 Enduro's~Yakima RailRider w/48" bars~ScanGauge II
12-16-2010, 05:07 PM
#19
Thanks guys. I hope this helps answer people's questions about this stuff.
2021 Tacoma 4x4 TRD Off Road Double Cab Short Bed (my DD)
2017 4Runner 4x4 Limited (the wife’s)
12-30-2010, 07:01 PM
#20
x2 Thanks Brian
12-30-2010, 07:16 PM
#21
Thanks! Glad people are getting some good use out of the thread.
12-30-2010, 07:40 PM
#22
Yeah add a link to this in the faq sticky , good effort man !
'76 FJ40, '87 4runner, '98 LC 100, 99 4runner,'02 Tundra,'02 LX470,'08 Tacoma Dbl cab,'09 LC200, '16 Trail Premium. also 76 super beattle,'06 XR650L,'18 Triumph Scrambler-XE.
12-30-2010, 07:46 PM
#23
I am going to have to save the link to this so when I see the questions pop up I can respond with see this thread, alond with a few other common question threads.
99 SR5 V6 4WD- just started
SOLD1998 T4R SR5 All-Pro CO's, UCA's and Sliders, SS 1.2 rear only DIY rear bumper, Aussie Locker and 1st gen roll bar mod. Outdoor Logic Front bumper, roof rack and Vision X lights.
12-31-2010, 12:29 AM
#24
Again alot of Awesome Info! Thanks for the writeup!
x3 on the sticky would probably help someone out!
'99 SR5 Silver 2WD.
Full LED Conversion. 6000k V-HIDs.
Hella Micro Des.
D-Shackles. LC80 rims.
20% tint front windows. Memphis 15"
12-31-2010, 04:36 AM
#25
Real Name: Justin
Real Name: Justin
Great info!!! As others have said, this should definitely be a sticky!
Check out my Instagram! @808_hiker
1998 4Runner Limited Desert Dune 3.4 V6 Auto 4x4 ToyTec Ultimate/Superflex 3” Lift ~83k miles
2008 Tacoma Regular Cab Desert Sand 2.7 4banger 5MT 4x4 Bilstein 5100/AAL/Block 3” lift ~101k miles
2010 Tacoma Access Cab Black Sand Pearl 4.0 V6 Auto 4x4 TRD Off Road ToyTec Ultimate/Dakar 3” lift ~22k miles
2018 Tacoma DCSB Quicksand 3.5 V6 6MT 4x4 TRD Sport ToyTec Boss/Dakar HD 3” lift ~6k miles
12-31-2010, 02:48 PM
#26
Bump, added to the FAQ on ih8mud. Thanks to all involved.
2001 M. Silver 4WD SR5 5VZ Love Machine
3rd Gen FAQ Here
01-06-2011, 04:42 PM
#27
Yup. And correct me if I'm wrong Bill, but the '01s and '02s can be center unlocked in 4lo too, right? (where you'd use that and why is beyond me, haha)
Wouldn't the 4Lo Unlocked be optimal for towing applications? Or would that just be too slow for getting anywhere in a reasonable amount of time?
Speaking of which, what is the gear ratio change between high range and low range? Also, can the transmission be driven through all gears in 4Lo?
'96 4Runner SR5 2WD Auto, 30x9.5x15 Treadwright Puma, ISR mod, B&M Trans Cooler (Rad. & Trans. Separate), Magnefine (Transtar) Inline Trans Filter, 255K miles
01-06-2011, 04:49 PM
#28
4 low is too low for towing. And yes you can use all gears in 4 low. I would say the fastest you can go in 4 low is 25-30 mph. given your in over drive.
and as far as gear ratios. 2wd, and 4wd high are 1:1. 4 low is 2.28:1
check out my build thread My Build
01-06-2011, 05:00 PM
#29
I see. Thanks for the info!
Killer thread!
01-06-2011, 05:42 PM
#30
sorry for my noobishness in the last 3 years i have had my 4runner on rainy days i drive in 4hi on the freeway and once a month i drive 20 miles in 4hi on the freeway to lubricate the gears in the front differential.i usually shift on the fly when i enter the freeway on ramp at about 40mph. i have never put it in neutral or 4low. any i damaging the J transfer case or front diff maybe the tranny by doing this? Brian, Bruce? your thoughts on this? i rarely go off road now a days with my busy life.
99 4runner W/01-02 conversion
JDM Headlight Retrofit w/ custom LS460 bi xenon projectors,ODL Bumper,japan spec conversion ,Hella Twin Supertone horns,Kings 2.5" External Resi Compression Valved front and rear, Camburg UCA's,Addcco Sway bars,TRD supercharged,AFE Intake,Custom apexi catback,TRD Trans Cooler,Lots of Jaos Goodies,16x8 Volk Racing TE37X's BFG KO2 265/75/16 Stoptech Big Brake Kit
