01-02-2011, 07:11 PM
35 x 12.5 R15
I really want to get some 35s but all I have are 3 inch lift in the front and a 2 inch BL. Will I be able to run with these for road use at the least? How bad will the rubbing be before trimming?
01-02-2011, 08:03 PM
Tons of rubbing. Poor power. Poor braking. They are not going to fit the stock wheels.
2000 4runner Sport, SAS/4wheel Underground 3 link, Diamond axle, 14" Radflo coilovers, double locked, Custom rear 3 link, 12" Fox shocks, full armor Gerdo's Build Thread
Real Fuel Tank Skidplates for sale Lil' Skip's OffRoad
Rear control arm mount skids and Hi-Lift adapter for sale Lotus Development
01-02-2011, 08:09 PM
Wait, so you are at 5" total lift? a 2" body lift and a 3" suspension lift should clear 35s just fine??
01-02-2011, 08:18 PM
So what would be the best route for 35s
01-02-2011, 08:23 PM
Gerdo is right about the loss of power and and braking, what are you geared at?
I would check with Kregg or MillerPKA, someone that has 35s
you may have to do a little trimming and pounding, but there are several here running 35s,
01-02-2011, 09:27 PM
Moderator
Real Name: James
Moderator
Real Name: James
LOL are you aware what your username means in Arabic?
IG: @jimharb | YouTube | '99 Limited 2WD |
'99 4Runner - 2.7L 3RZ-FE - TRD S/C - 4WD Conversion + R150F 5-Speed Swap - Imperial Jade Mica on Oak
'87 4Runner Turbo - 2.4L 22R-TE - CT-26 Supra Turbo - W56 5-Speed Swap - Red on Red
'90 4Runner 2-Door - 3.0L 3VZ-E - Auto to R150F 5-Speed Swap - Red on Gray
'94 Supra Turbo Targa - 3.0L 2JZ-GTE - Marlin Crawler R154 - Imperial Jade Mica on Black
'89 Supra Turbo Targa - 3.0L 7M-GTE - Marlin Crawler R154 - White Package on Blue
'89 Pickup DLX 2WD - 2.4L 22R-E - W55 5-Speed - White on Blue
01-02-2011, 10:09 PM
Real Name: Rob
Real Name: Rob
12.5 is way too wide, just get some 315/75/16's and some wheel spacers.... I'm about to post some pics from today....check out my build thread in a little bit
01-03-2011, 12:30 AM
I've got 315/75/16's and I still rub after hammering the pinch weld and i'm only running a 3" lift.
‘14 SR5 in white
Front: King ext travel 2.5 w/ adjusters, TC UCA/LCA
Rear: King 2.5 shocks w/ adjusters, Dobinson’s 3” Icon Billet lowers, Icon tubular uppers, PCK
Wheels/Tires: SCS SR8’s w/ Toyo MT 35x12.50x17
Full RCI skids
01-03-2011, 01:09 AM
yeah, the OP said he had a 2" body lift too though,
do you run spacers 05ltd???
01-03-2011, 01:15 AM
Real Name: Rob
Real Name: Rob
his sig says spidertrax, with the OEM wheels you have to run spacers, or else those tires will be squeezed against the UCA. My MTZs are 11.8" wide and I'm reaally close to the UCA and my wheel has a 4" bs. So, to the OP, with a 12.5" wide tire you will need some thick spacers if you want to use them on an OEM 15" wheel.
01-03-2011, 01:19 AM
ah, didnt even think about the rub on the UCA... was just thinking pinch weld... good catch there downpour!
01-03-2011, 01:24 AM
Real Name: Rob
Real Name: Rob
yeah the pinch weld isn't really the problem since you can beat the sh!t out of it with a hammer, and cut if necessary. It's that UCA, if he put 12.5" wide tires on that stock wheel with 4.5" bs he would be squeezing the tire against it as he tightened the lugs. He would be driving down the road rubbing the whole way. ewww lol
01-03-2011, 02:39 AM
Re-Gearing chart
should give you a good idea of the new gearing recommendations if you decide. Our T4R's usually run 4.11 gears at stock.
1997 | SR5 - 3.4L - 4x4 | 265/75/R16 Kumho Road Venture MT's | ToyTec Coilovers/891's | 20% Tint | Velocity Stack Mod | Satoshi Grille |
01-03-2011, 02:45 AM
yeah I think 12.50's are too wide. You'd need like a 2" spacer. Highly doubt the wheels are worth the trouble.
And yeah I'm running the spidertrax. I like them so far. Wish I didn't need a spacer but I like the stock OEM wheels. Haven't found a set that I like enough to dish out $5-600 for.
‘14 SR5 in white
Full RCI skids
