Old 01-10-2011, 07:10 PM #16
FoneRunner's Avatar
FoneRunner FoneRunner is offline
FoneRunner is on a distinguished road
FoneRunner's Avatar
Originally Posted by brian2sun View Post
Well, you could do a lunchbox locker (aka Aussie or Lockright) in the front and they are ok to drive on pavement in 2wd. They won't lock up if there isn't any power going to the ring and pinion. But once you put it in 4wd, it will try to lock up whenever you give it gas so steering in 4x4 will suck whenever you're on the gas.
Thats why I ruled those out. I really have to be able to use the 4wd in the snow or ice so a lunchbox locker wouldn't work. Thats why I mean ARB or LSD are the only real choices...
'98 4Runner Limited Desert Dune 4WD lifted, locked, TJM'd, OME'd, LC'd, LED'd, ACC'd, CB'd, Gobi, Hilux'd, JDM'd, etc...
'98 Tacoma SR5 slightly built, '15 4Runner TEP
FoneRunner is offline   Reply With QuoteReply With Quote
Old 01-10-2011, 07:38 PM #17
AddictedOffroad's Avatar
AddictedOffroad AddictedOffroad is offline
AddictedOffroad is on a distinguished road
Yukon should have a Zip Locker available for the 7.5 in a few more months. Its basically an ARB knockoff that is $150 cheaper. I have installed several 8" versions into customer's rigs to date with good results.
AddictedOffroad is offline   Reply With QuoteReply With Quote
Old 01-10-2011, 09:27 PM #18
brian2sun's Avatar
brian2sun brian2sun is offline
brian2sun has a spectacular aura about brian2sun has a spectacular aura about
brian2sun's Avatar
I felt the same way, snow handling was the important issue for me too. I don't think the LSD would be so bad, but I like open/open on packed snow and ice.
1997 4Runner 4x4 SR5 - Geared, Locked & Armored
**CLICK FOR '97 BUILD THREAD**
2021 Tacoma 4x4 TRD Off Road Double Cab Short Bed (my DD)
2017 4Runner 4x4 Limited (the wife’s)
brian2sun is offline   Reply With QuoteReply With Quote
Old 01-10-2011, 10:38 PM #19
FoneRunner's Avatar
FoneRunner's Avatar
I've never heard of Yukon...are they an air locker like ARB?
Old 01-10-2011, 11:18 PM #20
maclean216's Avatar
maclean216 maclean216 is offline
maclean216 is on a distinguished road
maclean216's Avatar
One thing I considered when deciding between the ARB and the Trutrac was the stress they put on the components. While it's true that a an ARB fully locks the diff (becomes a spool) and that is harder on the CVs and everything, it's really only that 1% of the time, in those really sticky situations that it's in the "danger zone". The other 99% of the time, it's fully open so no different than stock.
What hasn't been mentioned and why I chose the ARB over the Trutrac is that the Trutrac doesn't fully lock so you run less of a risk of snapping a CV or other damage when your in those 1% of the time, hairy situations (like mentioned above). What wasn't mentioned was whenever you're in 4x4, the Trutrac has more resistance and puts more stress on the components. Yesterday for instance I was in 4LO for ~6 hours straight, but My front diff was open the entire time because I didn't need it locked for the wheeling I was doing. However, if I had a Trutrac up front, I would have been putting more stress on my components the entire time. Whether it's enough to break a CV in a day or 2 of off roading, I don't think so. But the stress it creates, especially in 4LO, over time can't be as good as running your diffs open.
One big problem I have recently noticed is climbing large ledges. The Trutrac won't lock up leading you to have to use more skinny pedal, to try and bump up. Which can lead to snapping CVs.
I don't think the Trutrac is really creating any more stress on the front drivetrain. You can drive with it on dry pavement and you won't feel any feedback from it. Unlike a locker. At least with the multi-mode transfer case you can.
2001 4Runner 3.4V-6 SR5
Camburg UCA W/ limit straps
6112 Front/5160 rear
ARB front/Detroit rear 4.88 / 35s
TRD supercharger w/ URD 7th injector
maclean216 is offline   Reply With QuoteReply With Quote
Old 01-10-2011, 11:20 PM #21
maclean216's Avatar
maclean216's Avatar
And an open front will never beat a Trutrac up front in sand, snow, ice, or any other slick flat surface.
Old 01-10-2011, 11:21 PM #22
FoneRunner's Avatar
FoneRunner's Avatar
So maclean216 you have the trutrac too? Would you happen to remember the part number? Or perhaps where you purchased it?
Old 01-10-2011, 11:33 PM #23
maclean216's Avatar
maclean216's Avatar
part number or code - 911A342 -FRONT
MIT in El Cajon, CA did the install.
Old 01-10-2011, 11:37 PM #24
FoneRunner's Avatar
FoneRunner's Avatar
I'm sorry I forgot to ask if you have the push button 4WD or not...I was reading thru the application guide and there seemed to be two part numbers...one for shift on the fly trucks and one for without...do you have that button on the shifter for 4WD?
Old 01-10-2011, 11:58 PM #25
maclean216's Avatar
maclean216's Avatar
I think its for manual hubs vs ADD. But I have push button multi-mode transfer case. ***EDIT*** That was the part number off the invoice in 2006. Not sure how accurate it really is. I would call the tech line if you had a question.
Old 01-11-2011, 12:16 AM #26
LINY4Runner's Avatar
LINY4Runner LINY4Runner is offline
Real Name: Bryan
LINY4Runner will become famous soon enough
Real Name: Bryan
This can be overcome with light application of the brake pedal (which is pretty standard for anyone who wheels rocks in an automatic) tricking the LSD into thinking that both wheels still have traction, and sending power to both.
Millennium Silver 2001 4Runner SportR5lander
Photo Timeline - Solid Axle Club
All-Pro, Fox, Eibach, OME, Goodyear, Trail Gear, Yukon, Solo Fabworks, Marlin, TJM, Smittybilt, Front Range Offroad, Inchworm, Addco, Savage Offroad, B&M, Borla, Pioneer, Cobra
Northeast 4Runner Owners Association
LINY4Runner is offline   Reply With QuoteReply With Quote
Old 01-11-2011, 12:27 AM #27
maclean216's Avatar
maclean216's Avatar
I am aware of that and maybe its my tires, but I am having a problem climbing steep rock ledges.
Old 01-11-2011, 07:52 AM #28
Real Name: Bryan
Real Name: Bryan
It might be the weight of the truck...there's been a few steep climbs where my buddy's XJ ran right up it, but me and my friend Mike's 4Runners has trouble.
Try airing down a little more?
Old 01-11-2011, 12:51 PM #29
FoneRunner's Avatar
FoneRunner's Avatar
Looks like I'm not the only one that has different names on different forums...hahaha! Thanks for the help. It's really confusing is all. I spoke to Summit Racing who only have the 445 part number and insist its the right one, but everybody I know who has this LSD has the 342. When I finally get the current info I'll post up! Thanks!
Old 01-11-2011, 08:18 PM #30
FoneRunner's Avatar
FoneRunner's Avatar
Today I spoke with a very informative individual at Eaton Performance, the makers of the Detroit TruTrac LSD. He says they make two TruTracs for our rigs...part numbers 911A644(which replaced part 911A342) and 911A445.
The 644 is for axle shafts that are 1.3 inches in diameter and 445 is for axles that are 1.1 inches in diameter.
So thats why I had such a hard time finding info on the 342 part number...its been discontinued, or as the man at Eaton said, superceded by 644.
Now, which axle shaft does a 4Runner use? According to Gus at Summit Racing, it uses a 1.1 inch because he says the correct part number is 911A445. Thats a good thing because it is less expensive.
So there you have it!
P.S. I also took care of the user name thing over on YT...hahaha
3rd Gen 4Runner Lift Information and FAQ's steezemcqueen 3rd gen T4Rs 1123 04-18-2024 10:08 PM
What size socket do I need for my front spindle nuts on an 88 4Runner IFS WoodsRunner88 Classic T4Rs 4 05-28-2010 10:12 AM
Why do so many people jack up the front? chiplee 4th Gen T4Rs 35 06-04-2007 01:09 PM
Missing front Skid plate? Hit a deer. DiskDoctr 4th Gen T4Rs 1 12-11-2006 02:22 PM
Front receiver mount? SHINTON Off-Roading 3 11-15-2006 09:40 AM
