Originally Posted by CanukRunner
spun bearing? Which one?
I am pretty sure its exhaust.. I've heard manifold leaks before... sounds like a chugging tractor... not hearing any mechanical hitting noises.
Rod bearing would be the most likely if it was a bearing. Getting a little water into the engine, and then into the oil...that's a good way to spin bearings. Which is why I mentioned it...since you were stuck in it pretty deep by the sounds of things.
I couldn't tell if you were describing it as a "clatter" or a "chug". You're the one listening to it, so if you think exhaust, then that's where to start.
