Old 01-22-2011, 05:20 PM #1
jpontius jpontius is offline
jpontius is on a distinguished road
P0171 Code - Lean Bank 1... Help?
Hey Guys. I searched around, but couldn't find exactly what I'm having trouble with.
I have a recurring CEL popping up for P0171 - Fuel Trim System Lean - Bank 1.
When I hook up my bluetooth OBDII scanner, I notice the following:
O2 sensor 1 - acts normal
02 sensor 2 - acts normal
MAF - acts normal
Fuel trim bank 1, sensor 1 - Normal
Fuel trim bank 1, sensor 2 - ALWAYS READS 99.2%
The CEL light stays off until I am under heavy load (going up a steep hill)
Any idea what could be causing the constant high reading on Fuel Trim sensor 2?
2000 SR5 Sport 4x4 3.4L 5-speed
Deckplate/ISR Mod
All-Pro Offroad 1.5" Spacers
265/75/16 Toyo Open Country A/T
jpontius is offline   Reply With QuoteReply With Quote
Old 01-23-2011, 10:58 AM #2
FoneRunner's Avatar
FoneRunner FoneRunner is offline
FoneRunner is on a distinguished road
FoneRunner's Avatar
Last time I saw that code it was a broken hose from the PCV valve back to the throttle body. Vacuum leaks will cause that code.
'98 4Runner Limited Desert Dune 4WD lifted, locked, TJM'd, OME'd, LC'd, LED'd, ACC'd, CB'd, Gobi, Hilux'd, JDM'd, etc...
'98 Tacoma SR5 slightly built, '15 4Runner TEP
FoneRunner is offline   Reply With QuoteReply With Quote
Old 01-23-2011, 09:48 PM #3
but I don't understand why the fuel trim 2 would read 99.2% when the O2 sensors are reading normally. anybody?
Deckplate/ISR Mod
Old 01-24-2011, 10:42 AM #4
I think I may have figured out part of my problem...
My downstream O2 sensor (bank 1 sensor 2, right?) is oscillating between .07 and .9 volts. From what I've read, this indicates that my catalytic converter is bad. Does that sound correct? If so, I'm still a little bit confused, because it seems to me that if the catalytic converter isn't working, the rear O2 sensor would see unburned fuel, indicating a RICH mixture. But in my case, it is detecting a LEAN mixture, and attempting to richen it with the fuel trim. Can somebody please help me try to make sense of this?
Other info:
First O2 sensor (Bank 1, sensor 1) oscillates between 0 and .9 volts, which I believe is normal.
Deckplate/ISR Mod
Old 02-17-2013, 09:54 AM #5
CitadelBlue's Avatar
CitadelBlue CitadelBlue is offline
CitadelBlue is on a distinguished road
I assume that ALL of the vacuum hoses can be seen on TOP of the engine? (I'm an old 70's Ford guy am an use to one vacuum hose to the PCV valve to carb and maybe one more ....... no use to the spider web of black hoses under the hood.
Ken
2002 4Runner
2004 S2000
CitadelBlue is offline   Reply With QuoteReply With Quote
Old 02-23-2013, 11:00 AM #6
After cleaning the MAF with the store bought spray and then a second time with alcohol ... I purchased a new Denso 197-6020 Mass Air Flow Sensor
and installed a new air filter .. I cleared the CEL and after 50 miles of driving no CEL ..... hope this was the fix .....
Ken
2002 4Runner
2004 S2000
P0171 Lean judoant 3rd gen T4Rs 9 07-05-2012 02:34 PM
Error Code P0170 (First Bank Lean) 3.4L V6 Dirt4dinner 3rd gen T4Rs 1 08-18-2010 10:49 PM
Code P0171 problem need help bigtuna 3rd gen T4Rs 5 09-01-2008 08:54 PM
p0171 code bank 1 Which side? JTs99SR5 Maintenance/Detailing 5 08-08-2005 06:41 AM
99, 4Runner P0171 code Jheera_blade Problems & Warranty Issues 1 03-27-2005 01:50 AM
