Originally Posted by Qyota
Thought I'd start a new thread, since I can't modify the title of this related thread:
Freakshow: Alarm sounds when unlocked using key fob - Toyota 4Runner Forum - Largest 4Runner Forum
My master key (with transponder) will not turn the driver door lock. The lock just resists any motion to the left or right. I've tried alcohol (lock de-icer), electronics cleaner, and graphite with no success. I'm starting to think this is an electronic problem, as the door lock is actually what Toyota calls an "electromagnetic" system.
Anyone had this happen before? Luckily, my fob still unlocks the doors, and the inside door lock switch works...but I want to be able to use the key if necessary.
Important to note - the key does work in the passenger door lock and the rear hatch lock.
I’m having similar problems. I notice that
- driver door yours right to unlock and not left to lock
-passenger front turns both ways and will lock and unlock the whole car including the liftgate.
-liftgate works fine
- intermittent issues with locking using the button on the drivers side door, most but not all doors lock (usually the passenger front door and sometimes the passenger back door don’t lock all the way)
- I do not have a fob even though I believe the 99 Ltd came with one.
If anyone has any other advice let me know!
