Old 01-25-2011, 01:25 PM #1
Qyota's Avatar
Qyota Qyota is offline
Qyota is on a distinguished road
Qyota's Avatar
Key won't turn driver door lock
Thought I'd start a new thread, since I can't modify the title of this related thread:
Freakshow: Alarm sounds when unlocked using key fob
My master key (with transponder) will not turn the driver door lock. The lock just resists any motion to the left or right. I've tried alcohol (lock de-icer), electronics cleaner, and graphite with no success. I'm starting to think this is an electronic problem, as the door lock is actually what Toyota calls an "electromagnetic" system.
Anyone had this happen before? Luckily, my fob still unlocks the doors, and the inside door lock switch works...but I want to be able to use the key if necessary.
Important to note - the key does work in the passenger door lock and the rear hatch lock.
Qyota is offline   Reply With QuoteReply With Quote
Old 01-25-2011, 04:18 PM #2
footdoc's Avatar
footdoc footdoc is offline
footdoc is on a distinguished road
footdoc's Avatar
same thing. I have a spare which unlocks it just fine, and i can get in through the passenger side without a hitch.
footdoc is offline   Reply With QuoteReply With Quote
Old 01-25-2011, 05:38 PM #3
Qyota's Avatar
Qyota's Avatar
Oo - so your spare key works when the master doesn't? I have two masters that don't work...haven't tried the valet key (no transponder in that one).
Old 01-25-2011, 09:43 PM #4
GX4SEVEND's Avatar
GX4SEVEND GX4SEVEND is offline
GX4SEVEND has a spectacular aura about GX4SEVEND has a spectacular aura about
GX4SEVEND's Avatar
I have the same issue but its either key, but it doesn't happen all the time. Just once in a while
‘14 SR5 in white
Front: King ext travel 2.5 w/ adjusters, TC UCA/LCA
Rear: King 2.5 shocks w/ adjusters, Dobinson’s 3” Icon Billet lowers, Icon tubular uppers, PCK
Wheels/Tires: SCS SR8’s w/ Toyo MT 35x12.50x17
Full RCI skids
GX4SEVEND is offline   Reply With QuoteReply With Quote
Old 01-25-2011, 10:31 PM #5
nacho's Avatar
nacho nacho is offline
nacho is on a distinguished road
nacho's Avatar
Shoot some spray silicone in there using the red straw that came with the can. Mine was doing that. It's smooth as silk now.
2000 SR5 4x4 auto 3.4L SC'd on 265/75/R16 tires.
nacho is offline   Reply With QuoteReply With Quote
Old 01-25-2011, 10:50 PM #6
Blitzkrieg Blitzkrieg is offline
Real Name: Bob/Buckwheat
Blitzkrieg is on a distinguished road
I've never once used my key to unlock my 4Runner. LOL
"I speak three languages and liberal ain't one of them."
Blitzkrieg is offline   Reply With QuoteReply With Quote
Old 01-25-2011, 11:50 PM #7
Jamacee's Avatar
Jamacee Jamacee is offline
Jamacee is on a distinguished road
Jamacee's Avatar
I can't help you but I can say I am dealing with the same.
Mine is actually doing the same thing. Of course it is random. Sometimes it unlocks the door on the drivers side and or pass side. My key doesn't work in the tailgate either. I don't know if it is supposed to roll the back glass down or just unlock the hatch.
Now my fancy clicker (1st time I have ever owned a vehicle with a lock/unlock doohickey) will only unlock my Drivers door but not all the doors. I also have to dbl click the unlock for it to work. same for locking it.
the rear window rolldown button doesn't work either.
1999 4runner 4x4 SR5 AT bone stock - possible build for expo/DD
Jamacee is offline   Reply With QuoteReply With Quote
Old 01-26-2011, 05:32 PM #8
coffeeguy coffeeguy is offline
coffeeguy is on a distinguished road
Try a product like 5 in 1 oil(Or any seeping penatrating oil). Worked really well with the ignition in an 05 Volvo that suddenly decided it didn't want to turn(to start)
coffeeguy is offline   Reply With QuoteReply With Quote
Old 01-26-2011, 06:05 PM #9
Qyota's Avatar
Qyota's Avatar
I've tried a few things. I'd rather not gunk it up, though. It really seems like the electronics behind the lock aren't letting it go. Or, the wafers/tumblers in the cylinder aren't responding to the cleaning and lubricating agents I've used. I'm going to take it out someday and see if I can take it apart.
Old 01-26-2011, 06:08 PM #10
nacho's Avatar
nacho's Avatar
SILICONE spray is the way to go.
Old 01-27-2011, 10:37 AM #11
kball's Avatar
kball kball is offline
kball is on a distinguished road
kball's Avatar
If your key is old and worn you can try having the dealer make a new one off the VIN. If that doesn't work, (which it didn't for me on my 96) the lock is probably broken. I just posted a write up about fixing my lock a few weeks back.
Door lock replacement 96 runner
1996 SR5 4Runner V6 4WD Auto
Toytec Ultimate w/ OME 890's plus 1.5" daystar spacer
60028 OME shocks, Goodyear Duratracs 265/75 -16
B&M 70268 with Magnefine filter, 199mm TBU
236K miles
kball is offline   Reply With QuoteReply With Quote
Old 01-27-2011, 10:41 AM #12
Qyota's Avatar
Qyota's Avatar
Great write-up! The only thing that's different is that my lock cylinder has an electrical component to it. It has 4 wires running from the lock to the actuator, and then into the main door harness. So, I'm not convinced it's not an electrical issue, since my alarm goes off when I hit the unlock button on my fob (yes, that problem is back...or never went away).
I have a new key, and it works fine in the passenger door (all my keys do), and the rear hatch. Something is up with that driver door lock cylinder or actuator.
Old 03-23-2012, 12:23 PM #13
RoyR RoyR is offline
RoyR is on a distinguished road
Awesome...last night after a scuba dive session (COLD), I tried to unlock both the driver's side door and the tailgate with no success using the key...had to call AAA to open the truck (2005 4Runner)...WTF????
RoyR is offline   Reply With QuoteReply With Quote
Old 03-23-2012, 12:55 PM #14
flappn flappn is offline
flappn is on a distinguished road
I would try getting a new key cut at the dealer..you'll need your VIN#. I had issues with some locks and the ignition....had a new key cut...and everything worked again. I tried having one cut at a local HW store and it was crap.
flappn is offline   Reply With QuoteReply With Quote
Old 10-08-2013, 08:55 PM #15
cyclops13 cyclops13 is offline
cyclops13 is on a distinguished road
Damn. Even I am facing this issue on my 1997 SR5. I do not have keyless entry (remote controlled).
The key works fine for unlocking the drivers door and works fine for locking/unlocking all other doors. But the key just would not turn anticlockwise (to lock) on the drivers side door. If I use the door lock switch from the inside or use the key to lock on passenger side door, it works fine.
What could be wrong here?
P.S. Sorry for reviving an old thread.
cyclops13 is offline   Reply With QuoteReply With Quote
One cause & fix for "VSC TRAC" & "VSC OFF" lights, Zero Point Calibration MicaBlue03 Problems & Warranty Issues 299 06-05-2023 01:23 PM
My key won't turn in the ignition Tanner Maintenance/Detailing 18 02-05-2020 01:33 PM
Can you install a Lexus (or anyone elses) key fob system on a T4R? streetbranch 4th Gen T4Rs 8 02-14-2010 01:35 PM
PG001R-06 11/28/2006 Electrical - Battery Maintenance and Testing CBR_GUY_IA TSB 0 07-12-2009 09:40 PM
Check out the NEW Avalon! Koz Comparisons & Reviews 9 03-30-2005 04:00 PM
