Old 01-28-2020, 09:48 PM #31
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Originally Posted by Smithedenise View Post
No, everything is neutral. I thought I had drive, and I may have the other day, but today I only have park and neutral.
Check the FSM [ Factory Service Manual] and see if your solenoids are working. Verify your Park Neutral switch is functioning properly.
Old 09-01-2020, 07:36 AM #32
shorehunter shorehunter is offline
shorehunter is on a distinguished road
Transmission WAS stuck in neutral
nevermind started a new thread
shorehunter is offline   Reply With QuoteReply With Quote
Old 10-29-2020, 04:16 PM #33
prad64 prad64 is offline
prad64 is on a distinguished road
Similar Issue
Just towed my 2002 4unner to the shop today. When I was wheeling something pulled a rubber hose out of the bottom of the radiator driver side. Traced it and it goes back to the transmission. Didn't leak to much but when it ripped the hose out it pulled the brass pipe that was part of the connection between the hose and radiator. Not close to home so had to take to shop to reconnect.
The only thing I'm worried about is the fact that when this happened, car stopped dead in the water. Engine running fine with no lights, but when in drive, reverse, or any gear it just revs up like its in neutral with no movement. Would this hose being disconnected cause the issue? Or am I looking at a whole new tranny?
prad64 is offline   Reply With QuoteReply With Quote
Old 10-29-2020, 04:31 PM #34
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Lack of transmission fluid will cause the transmission to stop moving. That hose is for the transmission to transmission cooler. With that hose disconnected you lost a lot of transmission fluid. It either went all over the place or it got mixed in with the coolant.
If you haven't already you need to replace the radiator if it's old or the fitting came out of the radiator, check your coolant for sludgy residue, and check your transmission fluid level and condition.
If you have sludgy coolant then you'll need to replace the radiator and flush the cooling system a few times.
If the transmission fluid is milky then you can try flushing the old fluid and replacing the filter or just go ahead and kiss that transmission goodbye.
Old 10-29-2020, 05:47 PM #35
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
That's the main transmission line to the cooler. Like mentioned above, all your transmission fluid drained out. Just hope that it survives with just new coolant and a new radiator (the barb is not repairable).
326WHP 347TQ
Old 10-29-2020, 06:43 PM #36
Wasn't a huge issue. Just had to get that connection fixed and put in new tranny cooler. Flushed the transmission so its going with all new fluid and its running like new. Thank you for the help guys!
Old 05-25-2022, 08:34 PM #37
Biggle Biggle is offline
Biggle is on a distinguished road
Angry I have a 1993 manual transmission it won't move until I'm at 5500 rpms.
My 1993 Toyota 4runner manual trans won't move until I'm a 5500 rpms in first gear it just started to do this today may 25 2022. It has a weird smell when it goes some one told me I smell your clutch when I pulled into the gas station. Anyone know what's going on
Biggle is offline   Reply With QuoteReply With Quote
Old 05-25-2022, 09:16 PM #38
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
1993 is a 2nd gen 4 runner. This is the 3rd gen 4 runner group. You will need a new clutch pressure plate. And possibly flywheel as your clutch is gone. Sounding like your pressure plate failed.
Ordering 4.56 gears for f&r diffs. Expat Off-Roading 5 02-14-2007 11:16 PM
truck stuck wont move. brakes .trans.gear box?? bobby515 4th Gen T4Rs 4 02-07-2007 06:16 PM
Read something in Truck Trend mag. Falls 4th Gen T4Rs 6 01-27-2007 04:22 PM
HELP!!!! Head Gasket & Relay Rod Recall Problems Gtrain Classic T4Rs 11 01-08-2006 03:45 AM
Toyota Tacoma Selected as 2005 Motor Trend Truck of the Year GatorGreg 4th Gen T4Rs 0 12-16-2004 05:48 PM
