Originally Posted by puckoach
Thanks for the reponses to date !
Was with a friend last night that is a Toyota Dealer Tech.
He asked about noticing leaks. But, I haven't.
Given the duration of time I have been hearing the gurgling, he is guessing a real small/slow leak. Is providing me some coolant to add. Supposed to get it later today.
So, will add, and report back, probably top of week.
Got flu, and waited till it was warm here. Inspected all the lines I could see, no obvious leaks. Except, when I went to take the cap off the radiator, I was only paying about 50% attention. It could be that it was not on right, or is worn out. The hose to the overflow tank was loose, and covered with "stuff". Cleaned them up, and re-clamped the overflow hose.
It took about 9/10's of a gallon to top off the coolant. Heat came right up, and check engine light went out.
Ran for 10 minutes in driveway, then a ten minute ride around town. No visible leaks.
Will look at it this morning again.
