02-15-2011, 01:16 PM
Electrical Problem (No power at all)
Hi guys, new here with a 99 4runner v6 auto 4wd.
On occasion when I then turn they key I get no dash lights, no headlights, no radio, absolutely nothing will work, not even a click from the starter. It's completely dead.
After a few minutes of turning the key back and forth dash lights will come back on and then I know it will start and it fires right up.
So am I losing power to the actual computer or is it a ground? Any suggestions what to check because I'm not familiar with electrical issues!
Thanks in advance!
01-02-2012, 10:41 PM
Same
I am having the same problem currently ever figure it out?
01-20-2012, 12:10 AM
Bump.
I think my issue might be related.
Check out my garage.
01-20-2012, 01:17 AM
Banned
Banned
I doubt its ECU related, most definitely sounds like a bad connection somewhere. Does your keyless entry always work? If so I'd start with the steering column back thru the firewall, then the main wiring harness.
07-10-2012, 08:43 AM
You should try fuse link wire....its connected to 80A fuse (fuse box by the hood) from the positive terminal from the battery. I had the same problem with my 90 4runner.
07-10-2012, 10:03 AM
I know this sounds obvious, but maybe try getting your battery tested.
Its free and easy and will at least eliminate any concerns.
2005 Limited V8 4x4 4Runner
2005 SR5 V8 4Runner
1997 40th Anniversary FZJ80
2001 Ford F350 w/ FWC Hawk
07-10-2012, 11:58 AM
Try all suggestions above, and also check all major grounds. I had the same issue and it ended up being my main battery ground.
-Dirt Dawg
1999 SR5 "Highlander" 4WD Lifted, Locker, Sliders, and More
2000 LX470 Expedition Rig
07-10-2012, 12:30 PM
Dirtdog brought up a good point. There are 3 ground points. Check them. One is right next to battery to body, next is on top of Plenum, and then the 3rd is to block near oil filter .
2005 SR5 V8 4Runner
07-12-2012, 12:24 AM
Real Name: Instagram: briansd_97r
FWIW - It was probably a loose or corroded battery terminal.
Singtoe called it! This just happened to me last weekend.
I put the key in and the dash lights up like normal. As soon as I turned the key all the power seemed to be completely gone the dash went dark. So I take the battery out and put it on the charger but it is at 98% charge .... ? I talked with my neighbor and he told me I probably had a corroded battery terminal. I cleaned both completely and it started right up.
Those he commands move only in command, Nothing in love. Now does he feel his title, Hang loose about him, like a giant’s robe, Upon a dwarfish treasonous thief.
04-02-2014, 09:12 AM
1994 Toyota 4Runner
I just recently bought a 1994 Toyota 4runner, when we bought it we were told that the alternator was bad in, since then, I have replaced the battery, the alternator and the starter. The alternator I have replaced 3 different times, the last time I got it tested and the alternator is good, and the starter is good. But somehow it is losing power while its running. Someone recently said that there could be a short in the alternator that when u get it tested it won't show up. But before I go getting another one, does anyone have ANY suggestions as to what could be going on? We have had it for 2 months, and its been sitting for 2 months! Its a great truck ONCE its running. But within 45 mins to a hour of it running its losing power! HELP!!!
04-03-2014, 10:39 AM
Don't buy anything! Yet
You should search for the big 3 mod on this forum. Basically better ground and charging. But please clarify when you say it is losing power, what exactly do you mean? Does the engine shut off, lights dim? Or do you stop and then it won't restart? I don't know what your actual problem is.
You can also learn a lot here at this post!
http://www.toyota-4runner.org/3rd-ge...unner-how.html
1989 FJ62 5.3 Chevy, FZJ80 Axles, 4.88's with ARB.
2000 2wd runner, 4 cylinders, yes it IS slow.
1999 4WD SR5 Desert Dune 3.4 351K and counting.
2000 4WD sport 3.4 Elocker <--My son's but I still end up paying.
2001 2WD SR5 3.4 <-- My daughter's...see preceding line.
10-16-2015, 03:24 PM
my 97 Runner has a simular issue, I turn key on and only the airbag light lights up, it starts just fine and runs just fine, no guages work and when i disconnect positive while running it dies, replaced alternator and still the same.....any ideas and thanks in advance.
97 SR5 3" lift front,2" lift rear, 1" body lift, Bilstien 5100s, 20x35 rubbers, K-N lungs, magnaflow 2.75" exhaust...for now...Kenwood deck, two Zapco 1000 and 550 Watts amps Polk Audio crossover system for the mids and highs and two 12" JL Subs seperate ported boxes.410k miles and still runs like new.
10-16-2015, 04:57 PM
Really need more info.
Check voltage at battery with engine running and off.
Do headlights work? Do they get brighter when you accelerate?
How about radio and windows and all that stuff?
In any case, check and clean your battery terminals and inspect cables for any pimpling that might indicate corrosion under the insulation. Check your GAUGE fuse with a test light or swapping in a known good fuse. Don't waste my time by just looking at it.
My Backyard Frame Swap
10-16-2015, 08:41 PM
Banned
Banned
Originally Posted by TheDurk
In any case, check and clean your battery terminals and inspect cables for any pimpling that might indicate corrosion under the insulation. .
All good points, but if I had to place a bet, it would be on the battery terminal connections.
OP, does your truck have the original Toyota battery terminals, or have they been replaced? The original ones don't hold up very well, but personally I think they're better than most of the aftermarket stuff you get at the auto parts stores.
