01-15-2013, 10:07 PM
#16
Any luck solving the problem? My 01' 4runner is doing the same thing. Doesn't matter what I do or where I go. Maybe it could be a clogged breather tube or something.
01-15-2013, 10:13 PM
#17
Originally Posted by 98'4runnerSR5
The trick is flipping the handle/nozzle upside down and fueling it that way. Sounds crazy but used to work on my buddies QX4 when he had that problem.
That's more of a professional technique though!
01-15-2013, 10:50 PM
#18
same topic, off subject, went to the gas station/mcds today to fill up on my way out of town, turned on the pump, went and ordered, came back out, 10 gallons had filled shut off the pump for 10 seconds, sat in my truck and ate, 2 mins later it finally was full.. 32.5 gallons.
and yes turning the handle upsidedown on some pumps helps
guess im just a sucker for forced induction
01-15-2013, 11:10 PM
#19
Originally Posted by that$pit
. 32.5 gallons
What?
01-15-2013, 11:32 PM
#20
Originally Posted by PitbullRescuer
What?
O yea, custom built a tank for it.
Kiddin work truck 08 f550
01-16-2013, 12:24 AM
#21
Moderator
Real Name: Waldo
Moderator
Real Name: Waldo
Old thread but I guess I'll give my .02... I think the problem is the station pumps the gas so fast sometimes the gas gets clogged in filler neck and backs up, which then the sensor on the nozzle tells it to shut off. It just doesn't get a chance to smoothly flow through. Sometimes it does it, sometimes it doesn't. I find it helpful that when I start filling up a gradually make it go faster instead if immediately pulling the handle all the way back.
'99 Toyota 4Runner LTD - Dual Locked | Geared | Mid-Travel | 35s | Armored
01-16-2013, 11:04 AM
#22
Healed itself
You know. It only happens in one town. Blanco Texas... so I'm wondering if it has to do with the local stations and their equipment? I just use the Shell by my house and never have an issue. I don't think, at least for me, that it's a problem with my 4runner.
Cheers
2002 SR5, 102K+, Gobi Stealth rack, NGK wires - Otherwise all factory.
01-16-2013, 04:01 PM
#23
I also experience this from time to time across many different vehicles and seems to vary by gas pump - but my 13 T4R seems more susceptible.
I also seem to observe that pulling out the nozzle an inch or so seems to alleviate the issue. Seems like the pump is sensing too much fuel vapor and thinks the tank is already full - pulling out the nozzle seems to allow fresh air to dilute the vapor and prevents pre-mature pump shut-off (better than the opposite of returning to your truck with gas pouring out of the filler neck!). Go figure...
Randy V
2013 4Runner * SR5 * 4x4 * Leather * Convenience Package * Black-on-Black *
* BFG KO LT265/70R17/C * SR5 Wheels + SpiderTrax * 5100's @ .85" * GrillCraft Grill Mods & TOYOTA Emblem * H9 & H9011 Headlight Swap *
* Alpine W910 DVD/NAV + H800 DSP * ARC Audio * JBL * JL * Morel * DieHard Platinum 31M * Total system power = 4,048 Watts RMS ! *
12-22-2013, 03:49 PM
#24
My 2002 4runner started the same thing. I tried different position with the nozzle and tried different gas stations. Still the same thing. I looking for answeres.
12-23-2013, 02:32 AM
#25
I had kind of the same problem with my 02. When filling up it would just fill the filler neck and then shut off the pump. Wait a few seconds and fluid level would drop. The issue I had with mine is that the inner lining on my filler neck melted shut some how and wouldn't allow fluid thru the filler neck very fast. I ended up having to replace my filler neck, no more issues two years later.
Here is a picture of the where the lining melted shut on me.
2002 SR5 4Runner
Auto, 4x4, Camburg Long Travel, Relocated Dual Batteries, 34" KM2, Custom Armor
01-04-2014, 09:47 AM
#26
I took mine to the car wash. I sprawed underneath the fenders and body. Problem solved. Takes gas like it should.
01-27-2014, 08:16 PM
#27
I actually took my 4 runner to the dealer to try fixing this problem, so far they can't find anything.
01-13-2019, 02:44 PM
#28
hi Again Must solve this one
Hi. This is getting to the point where I have to fix it. I've been reading a few other threads.
Question: Is there anywhere that the Vapor Canister or any part of the fuel/emissions control system vents to the outside air? That could get clogged by dirt/bugs/anything?
Someone made a comment that washing underneath the car dislodged something and it worked again.
Thanks
01-14-2019, 09:36 AM
#29
I have thoroughly read about, and experienced the same issue. We found that the issue was with the vapor canister, and what led to the issue was topping off the tank after the pump shut itself off. The overflowing fuel will find it's way down to the canister through the vent line. I learned my lesson on my '02. I always topped it off, and started having the issue around 120,000 miles. My '00 is now sitting at just over 280,000 miles, and is just fine.
2000 4Runner Limited 4x4, 3" OME lift, 2nd Gen TRD supercharger. 282,000 miles - SOLD
2010 Jeep SRT8, 7.2 Arrington 440 stroker, 550 whp! - FOR SALE
2007 Jeep Wrangler Sahara...too much to list!!
2015 Ford F-250 Platinum Powerstroke 4X4
01-14-2019, 10:44 AM
#30
That's it!!!!
Now that makes the most sense of anything I've heard. I started topping off because I wanted to squeeze every mile out of my range when towing. So the fix is the replace the Vapor Canister and then don't top off in the future?
