Originally Posted by Pyral
I just removed my skid plate and realized that my oil pan leak keeps getting worse. Now I add a quart of oil every 4k miles.
The price to fix this leak is expensive since it requires the removal of the front differential. Is there anything else that I should have replaced when I do eventually get it fixed?
If you haven’t done so already, it may be worth a shot. But you could try gently tightening the pan bolts in the event that they are loose. Which reminds me, I need to check mine. I had my pan replaced in February 2015 and there seems to be a little bit of dampness from the driver side, right beneath the oil filter.
