Old 03-13-2011, 10:48 AM #1
WSLN 6 WSLN 6 is offline
WSLN 6 is on a distinguished road
Installed new Bilsteins, now ride height is all over the place!
I Recently installed a set of the Bilsteins (yellow/blue non adjustables) in my 98 4runner with weird results....
Pre install, my front ride height was 34" from the floor to the flare, and 34.5" in the rear.
Now I have 37.5" front drivers side, and 36" rear drivers side. The passenger side is 36.5" front, 35" rear.
It looks rather silly.
I removed the drivers side shock and coil again and can not get it to sit perfectly on the bottom coil mount on the shock like the passenger side but that shouldn't make that big of a difference height wise.
All experts please chime in, truck has 347,000km's on it. (easy highway/city life)
WSLN 6 is offline   Reply With QuoteReply With Quote
Old 03-13-2011, 11:49 AM #2
Baja Runner's Avatar
Baja Runner Baja Runner is offline
Baja Runner is on a distinguished road
Did you install the coils on the shocks correctly? As in, are the bottom of the front coils aligned with the grove on the coil seat? Also, the coil seat on the shocks seated on the flange correctly?
Sounds to me you just need to get everything settled down. How many miles did you drive after you installed?
Shocks themselves shouldn't add/remove ride height, so its something to do with the coils, or how they are seated.
2005 Limited V8 4x4 4Runner
2005 SR5 V8 4Runner
1997 40th Anniversary FZJ80
2001 Ford F350 w/ FWC Hawk
Baja Runner is offline   Reply With QuoteReply With Quote
Old 03-13-2011, 12:29 PM #3
Gerdo's Avatar
Gerdo Gerdo is offline
Gerdo will become famous soon enough
Gerdo's Avatar
I know that they have gone to a stamped steel lower mount but this should give you an idea what it should look like. Most of the mount is up inside of the coil. Reversing it is a fairly common mistake.
2000 4runner Sport, SAS/4wheel Underground 3 link, Diamond axle, 14" Radflo coilovers, double locked, Custom rear 3 link, 12" Fox shocks, full armor Gerdo's Build Thread
Real Fuel Tank Skidplates for sale Lil' Skip's OffRoad
Rear control arm mount skids and Hi-Lift adapter for sale Lotus Development
Gerdo is offline   Reply With QuoteReply With Quote
Old 03-13-2011, 12:47 PM #4
Singtoe's Avatar
Singtoe Singtoe is offline
Singtoe will become famous soon enough
Singtoe's Avatar
All that salt makes it look tasty.
Singtoe is offline   Reply With QuoteReply With Quote
Old 03-13-2011, 12:56 PM #5
The passenger shock fits perfectly and sits nice on the bottom shock spring support. The driver one I have removed completely, taken it apart and assembled again and it still doesn't want to sit straight on the support. The shock is not really centered in the coil and will not follow the curve of the lower shock support. The top of the spring fits fine, and in the same small groove that the stocker sat in.
It seems to drive and ride ok.
Keep the ideas coming.....thanks!!
Here are some pics, the passenger side first then 2 drivers side pics.
Old 03-13-2011, 03:15 PM #6
1985taylor1925's Avatar
1985taylor1925 1985taylor1925 is offline
Real Name: Phil
1985taylor1925 is on a distinguished road
Real Name: Phil
This is correct. Its a misconception that shocks lift or lower the vehicle (unless or course they are adjustable). But if the shock seat on the bilsteins sits higher than on the original shocks, then your coils would be more compressed which would lift it. Is there any chance you got the wrong shocks?
98 - SR5 - 3.4L - 4x4 - Auto - 4:10 gears
http://www.toyota-4runner.org/3rd-ge...my-runner.html
267/75/17 Cooper ATs - Level 8ZX wheels matte black - EBC rotors/ pads - 99 coils/ Bilstein 5100s - deckplate - Sotashi/custom emblem - Hella micro DE fogs - Kenwood/Alpine/Infinity system - sound deadened interior - color matched bumpers - LED tails - Safari LTD rack - Husky floor liners - clear corners
1985taylor1925 is offline   Reply With QuoteReply With Quote
Old 03-13-2011, 06:21 PM #7
Gerdo's Avatar
Gerdo's Avatar
The first picture shows the seat correct.
The second and third picture show the seat in the incorrect position. Flip the black steel seat and everything should be good.
Old 03-13-2011, 06:48 PM #8
awpsome's Avatar
awpsome awpsome is offline
awpsome is on a distinguished road
awpsome's Avatar
I just did this install yesterday. Your 2nd and 3rd picture show the coil seat upside down.
That changes the stuff roughly around 1.5"
It's also not recommended mounted like that and can ruin the shock and spring.
Fix that back and match it to the same as the 1st picture, drive around the block and everything should even out.
Same for me, after i put it on the front was about 1" higher then rear but drove around the block and all settled even.
Good shocks huge difference from blown stock
2016 Toyota 4Runner Trail Edition
awpsome is offline   Reply With QuoteReply With Quote
Old 03-13-2011, 08:30 PM #9
OMG am I dumb.....lol I did them one side at a time and never noticed this! Thanks a lot guys, pardon my brain fart!
98 Limited
Desert Dune/Silver
Bilsteins
Alpine x305
More to come....
Leaking now :( jmrwd3 3rd gen T4Rs 11 04-18-2017 07:58 PM
Daystar 2.5/1.5 Can't be installed on 2006 Sport Edition? NYRT4RSPG Engines / Suspension / Wheels / Tires / Audio / Accessories 7 11-11-2010 01:30 PM
best place to buy shocks? which ones for ride quality? 03dfw4runner 4th Gen T4Rs 3 05-01-2010 10:12 AM
2003-up Range Rover (RR3) Thai Comparisons & Reviews 50 06-09-2006 08:32 AM
Ride height of the 4th gen chunderboy 4th Gen T4Rs 3 02-11-2005 07:25 PM
