Originally Posted by J-money$$$
the bottom 3 on that list you can do in a couple hours... and save some cash.
x2
Though if it's your first time working on a 4runner, it will take a bit longer than that. Oil filter can be a PITA if it's stuck on and you don't have a filter wrench.
Once you do it though, everytime afterwards will be a breeze, and save you even more time and money.
I'd say the only real maintenance you can't pull off yourself with a bit of work and patience is the water pump and timing belt. Though some might argue that point.
Don't forget to either bypass the tranny cooler with an aftermarket one, or replace the radiator. Pink milkshake will ruin any tranny regardless of how well you take care of it.
Disregard the milkshake problem if you're running a 5spd
