Old 04-02-2011, 09:15 PM #1
ryankmasuda's Avatar
ryankmasuda ryankmasuda is offline
ryankmasuda is on a distinguished road
For you guys running 33's on 16x7's
So after I installed my lift I've been looking for new tires. I'm running 31's right now and from what I'm finding 33's and 35's need at least a 16x7.5 or wider rim. So how are some of you guys running stock toyota rim without having problems running 33's? I love the stock toyota rims but it looks like the FJ cruiser rim is the only 17x8. If there are any other stock toyota rims with at least a 7.5" width please let me know. Or let me know of a 33" tire that can fit a 16x7 rim. Thanks
1999 T4R SR5 4WD [Nitro 4.88 Gears][Aussie Lockers Front & Rear][ARB Snorkel][231mm Tundra Brakes][Light Racing Adjustable UCA][Tacoma Manual Locking Hubs][Bilstein 5100/Toytec 650lb Coils][Tokiko FJ80 Shocks/OME 2861 Coils][JDM Field Monitor][AOR Hybrid Rear Bumper][HNC Hybrid Front Bumper][Treadwright 315/70R17 Guard Dog]
My Build Thread
ryankmasuda is offline   Reply With QuoteReply With Quote
Old 04-02-2011, 09:20 PM #2
Presta24's Avatar
Presta24 Presta24 is offline
Presta24 is on a distinguished road
Presta24's Avatar
I run 285/75r16 mt's (32.8) on my stock rims, no issues. They wont be quite as tall on a 7in rim as they would be on a 8" rim.
2003 4Runner SR5 V8 AWD + Daystar 2.5/1.5 + FJ Swap + Definity Dakota 285/75r16 MT's
2014 Taco 6spd TRD OR billies/dakar HD pack/33's
Presta24 is offline   Reply With QuoteReply With Quote
Old 04-02-2011, 09:24 PM #3
Do you have any problems with the front tires rubbing the UCA's?
My Build Thread
Old 04-02-2011, 09:24 PM #4
Viking97SR5's Avatar
Viking97SR5 Viking97SR5 is offline
Viking97SR5 is on a distinguished road
Uuum
I am a little nervous now.. I was planning on running some 285/75 duratracs on some oem fivestars (16").. I just assumed that would work...
'97 SR5 Rusting board removal.+Deckplate Mod. +clear corners.+LED tails.+pinstripe removal+Toytec Ultimate Lift.+285/75 Goodyear Wrangler Duratracs on OEM Limited 5 Stars.+1" Wheel Spacers+new bumper+1" Body Lift+Sonoran Steel adjustable Panhard/trac bar **SOLD 7-7-13**
Viking97SR5 is offline   Reply With QuoteReply With Quote
Old 04-02-2011, 09:41 PM #5
Antpwr's Avatar
Antpwr Antpwr is offline
Antpwr is on a distinguished road
Antpwr's Avatar
just because it say "recommended wheel width" does not mean it will not your 7" rim, just a greater chance under certain circumstances, that it will be prone to popping off the bead, not only that but Presta24 is right it will not be as tall, if you put the same size tire on a 7" and 8" rim the 7" will be shorter because it has to suck inwards to the bead on the rim making it shorter, but it the actual tire brand does have a little to do with the fitment, plus it would void any warranties on the tire if not put on the approved rim. But i guess what i am trying to say is that yes it will fit the 16x7" yota rims
Antpwr is offline   Reply With QuoteReply With Quote
Old 04-02-2011, 10:04 PM #6
Presta24's Avatar
Presta24's Avatar
Ya, I have a little rubbing on the UCA's and a little rubbing on the front fender liner. Very drivable though. I m just waiting to get the $$ for spacers, and haven't gotten around to moving the liners forward. A lot of guys on here run 33's on stock rims. I haven't heard of any probs.
Old 04-03-2011, 02:12 AM #7
brian2sun's Avatar
brian2sun brian2sun is offline
brian2sun has a spectacular aura about brian2sun has a spectacular aura about
brian2sun's Avatar
The only problem you might run into is some shops (usually chain stores) won't mount a 285 or bigger to a 7" rim. As far as safety, I know people who have mounted 315/75 (35s) to stock 16x7s without problems and I have personally ran 285s on stock 7" wheels so you'll be fine. Another option is to run 255/85/16s which are ~33.5x10s. I like my 255s a lot and highly recommend them.
1997 4Runner 4x4 SR5 - Geared, Locked & Armored
**CLICK FOR '97 BUILD THREAD**
2021 Tacoma 4x4 TRD Off Road Double Cab Short Bed (my DD)
2017 4Runner 4x4 Limited (the wife’s)
brian2sun is offline   Reply With QuoteReply With Quote
Old 04-03-2011, 08:52 AM #8
Presta24's Avatar
Presta24's Avatar
yep, i almost went the 255 route, but found a great deal on my 285's
Old 04-03-2011, 12:02 PM #9
88xtraSR5 88xtraSR5 is offline
88xtraSR5 is on a distinguished road
255/85 R16's here, articulate it a little bit at full lock and bingo you got rub. Ofcoarse I haven't modified any pinch welds or plastic or nothing to that sort yet and I just have a 3 inch spacer lift up front. Maxxis website claims 33.3 inches in diameter, 10.30 inches wide... all on a 7 inch wide wheel with 19/32
of tread depth?
For you guys running 33's on 16x7's-img_1911-jpg
Quicksand TRD Pro Runner, Dobinsons C59-300 coils & IMS59-50700 front, stock coils & IMS59-50705 rear. C4Fab Hybrid front bumper, Baja Designs XL Sport & Squadron Sport Lights, Badlands Apex 12k winch, Mamba18x9 -12 wheels, BFG KO2 285/65R18's, East Coast Gear clamshell bushing, off-brand power steering cooler.
SOLD -2000 SR5 4Runner 4x4 3.4 V-6 Auto, 3" toytec spacers, OME 891's, 285/75R16 w/1.5" spidertrax's,DP mod, Hayden 679 cooler
88xtraSR5 is offline   Reply With QuoteReply With Quote
Old 04-03-2011, 12:14 PM #10
Presta24's Avatar
Presta24's Avatar
of tread depth?
Looks good man. **** ton o ground clearance for spacers and tire. Looks a lot higher than my 4th gen with DS 2.5/1.5 and 285/75r16's...........
Old 04-03-2011, 02:20 PM #11
I'm going to go look at tires today, It sounds like I may go the 255/85R16 route. Thanks for the information.
My Build Thread
Old 04-03-2011, 02:37 PM #12
Presta24's Avatar
Presta24's Avatar
Good choice, I would go with Maxxix Bighorns. several guys run em on here and like them. BF makes em too but they are more $$ and arent as wide as the BigHorns. I think I got a quote of like $175 a tire for the Big Horns, plus $120 for mount, balance, and alignment. There are also a few other companies that make that size in an at, or mt if you got the dough.
Old 04-03-2011, 02:46 PM #13
Thanks presta, nice rig you have yourself... Paid around $780 for my tires with free mounting and balancing. Second set of Bighorns I have purchased over the years and very pleased with them. On that ground clearance, I can clear a 5 gallon bucket with about 4 inches to spare in the center up front. Only if the rear end had that much clearance...
Old 04-03-2011, 02:57 PM #14
cj80cruiser's Avatar
cj80cruiser cj80cruiser is offline
cj80cruiser is on a distinguished road
Not to split hairs but from what I understand the opposite is true...running the smaller width rim is called "the poor mans beadlock".
戦争イーグル
Cory J
Wheel converter,
cj80cruiser is offline   Reply With QuoteReply With Quote
Old 04-03-2011, 02:59 PM #15
What tires are those in your pics Presta24?
戦争イーグル
Cory J
Wheel converter,
Best place to get Xenon's. What are you guys running? Rez90 4th Gen T4Rs 4 07-15-2009 12:23 PM
Running Board lights smokey7722 Engines / Suspension / Wheels / Tires / Audio / Accessories 2 07-09-2006 02:11 PM
Running Board Adjustments Atomic 4Runner 4th Gen T4Rs 3 04-29-2006 07:56 PM
Do you guys think this is a good deal, paint running boards standaman 4th Gen T4Rs 15 03-25-2005 05:28 PM
Have a lifted 4th gen running 33s ?? I need your help 4th Gen T4Rs 16 09-27-2004 05:02 PM
