Originally Posted by SCRunner12
So I just bought my 00 and I want to start my ownership right. I like the idea of replacing all the fluids, but how often should it be done? The last owner had the gear oil and transfer case oil changed in Oct 2009, which was about 14k ago.
I might just check to see if it is black in the gears, but for future reference how often do you guys change them? Also are there any other fluids that should be changed? Transmission, brake or radiator?
Yep, everything you just listed. If it was mine, I'd do the trans fluid, brake fluid and coolant. Every 30k-35k miles I do my trans and coolant. Brake fluid I usually do every 50K. For the diff's and t-case, every 50k is a very safe interval.
