Old 04-30-2011, 01:28 PM #1
FoneRunner's Avatar
FoneRunner FoneRunner is offline
FoneRunner is on a distinguished road
FoneRunner's Avatar
Misfiring on 3 cylinders
A friend of mine let her 99 4Runner V6 run out of gas and now it runs like garbage. The codes its throwing are for misfire on cylinders 1, 2, and 3. I changed out the fuel filter and put a bottle of lucas fuel treatment in the tank, but so far no improvement. I'm guessing it sucked some garbage out of the tank and fouled the plugs or clogged the injectors....what do you guys think?
'98 4Runner Limited Desert Dune 4WD lifted, locked, TJM'd, OME'd, LC'd, LED'd, ACC'd, CB'd, Gobi, Hilux'd, JDM'd, etc...
'98 Tacoma SR5 slightly built, '15 4Runner TEP
FoneRunner is offline   Reply With QuoteReply With Quote
Old 04-30-2011, 02:24 PM #2
athlon450 athlon450 is offline
athlon450 is on a distinguished road
I would check the plugs they maybe fouled out or injectors might have gone out. could have also messed up the fuel pump. Also check the fuel pressure regulator. Could be any # of things.
athlon450 is offline   Reply With QuoteReply With Quote
Old 04-30-2011, 02:25 PM #3
Shawn5800's Avatar
Shawn5800 Shawn5800 is offline
Shawn5800 is on a distinguished road
Shawn5800's Avatar
Your most likely right... You could try changing the plugs and running a bottle of seafoam through it. Might clear up some issues.
"I'm just getting started. I'm gonna pull the whole thing down. Im gonna bring the whole ****in' diseased corrupt temple down on your heads. It's gonna be Biblical."
Shawn5800 is offline   Reply With QuoteReply With Quote
Old 04-30-2011, 02:58 PM #4
FoneRunner's Avatar
FoneRunner's Avatar
Seafoam doesn't help the injectors though right?
Old 04-30-2011, 04:28 PM #5
MAD 69's Avatar
MAD 69 MAD 69 is offline
MAD 69 is on a distinguished road
MAD 69's Avatar
The fuel hose doesn't sit at the bottom of the tank so it prob didn't suck up any junk. When you run out of gas it sometimes fouls up the injectors, get them cleaned out at a shop or possibly be prepared to get new injectors.
98 T4R SR5 V6 4x4
23 T4R TRD OR Premium
MAD 69 is offline   Reply With QuoteReply With Quote
Old 04-30-2011, 05:44 PM #6
FoneRunner's Avatar
FoneRunner's Avatar
She took it to a shop and had the injectors cleaned and turns out she had a shorted out spark plug wire too. If the pump or hose doesn't sit in the bottom of the tank, how does it cause these issues when you run it out of gas? Or was it just a coincidence?
Old 05-01-2011, 07:31 PM #7
the great him's Avatar
the great him the great him is offline
Real Name: Isaac
the great him is a name known to all the great him is a name known to all the great him is a name known to all the great him is a name known to all the great him is a name known to all the great him is a name known to all
Real Name: Isaac
ran it too lean, no fuel... but the plugs kept firing so they probably got too hot and one of them cracked... the plugs were probably needed to be replaced anyways along with the wires.
if a*sholes could fly this place would be an airport -2004 GX470 spm -97 SR5 3.4, SCS Stealth 6's w/305 70 17s MTRs, Icon 2.5" RR w/700#coils, OME861s w/Icon tacoma 2.0 RR, ARBs w/nitro 4.88, PIAA LED lights, 170amp CS144, ARB snorkel, ARB bumper w/xd9000ce, CBI swingout loaded, BudBuilt skids, lil skip tank skid, sliders, LCE 231s(d&s), first gen roll bar mod, LED interior/dash lighting, B&M 70624+perma cool w/electric fan, dual electric fanshttp://www.toyota-4runner.org/3rd-ge...ld-thread.html
http://www.metaltech4x4.com/
the great him is offline   Reply With QuoteReply With Quote
Old 05-01-2011, 09:49 PM #8
Gerdo's Avatar
Gerdo Gerdo is offline
Gerdo will become famous soon enough
Gerdo's Avatar
It does if you use it in the gas tank.
A friend had an injector that was not flowing. I dumped a bottle of Lucas fuel treatment in the tank and after a 70 mile drive on the highway the injector was fine. Lucas treatment, Mmmm, good stuff!
2000 4runner Sport, SAS/4wheel Underground 3 link, Diamond axle, 14" Radflo coilovers, double locked, Custom rear 3 link, 12" Fox shocks, full armor Gerdo's Build Thread
Real Fuel Tank Skidplates for sale Lil' Skip's OffRoad
Rear control arm mount skids and Hi-Lift adapter for sale Lotus Development
Gerdo is offline   Reply With QuoteReply With Quote
Old 05-02-2011, 08:53 AM #9
FoneRunner's Avatar
FoneRunner's Avatar
I don't think I knew you could put seafoam in your gas tank...learn something every day!
I did have her put a bottle of Lucas in, but it didn't help. I put a bottle in every other oil change these days myself...maybe it'll keep mine running good!
Old 05-02-2011, 01:38 PM #10
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
When the tank runs low, the first fill can stir up crud from the bottom that just sits there when there is more gas in the tank. Then the pump sucks it in.
My Backyard Frame Swap
cylinder #3 misfiring blackberrius 3rd gen T4Rs 7 08-26-2013 07:12 PM
91 4runner v6 misfiring ???? vergotex3 Classic T4Rs 5 01-30-2011 11:52 PM
Are 4 cylinders selling? 03_4x4Runner 5th gen T4Rs 1 07-02-2010 10:06 PM
22RE Possibly Misfiring? thommooney Classic T4Rs 7 01-06-2010 02:30 AM
Misfiring but don't know why dolezal83 Classic T4Rs 5 01-14-2009 10:26 PM
