05-01-2011, 01:44 PM
Re-Gearing???
How much does it cost to get my 02 runner re-geared, what all exactly has to be changed...the gearing in the diffs?, i take it you have to take it to a shop to do it right? i was thinking about doing 4.88s cuz im only running 295/70/17 and would like to get a little more gearing power, also if i did a SC would it helped to be re geared or would the SC help me to not have to be re-gear. Sorry for so many questions, Thanks!
1999 4-runner, 4wd, K&N Intake, King Coilovers, 34' Nitto Trail Grappler MT's, LC 8 Wraps, 6000k 55w Bi-xenon HID's, 1.5" BL
Future Mod list: Aussie Locker, Possible Re-gear or SC.
05-01-2011, 05:15 PM
The supercharger will help get the power back that you lost with the larger tires. I have a similar setup to yours where I went from stock to lifted and 285/70/17's and felt like I lost a bit of "pep." I got the supercharger and it feels the same as stock now if not a little quicker. I'm thinking about a regear to 4.88's as well to move that powerband back to normal. If I were to do it again, I would have gone with gears first, but I found an unbelievable deal on the supercharger that I couldn't pass it up. I've debated getting a used 4.88 third for the rear just to see how it feels and then have the front regeared to match. Let me know what you decide with yours.
05-01-2011, 08:11 PM
The parts alone are probably around $500 and you're probably looking at around a grand for labor. Look into East Coast Gears, I don't have any expirience with them but people on here seem to like them.
1997 3.4l SR5 5spd 4WD E-locked. Blue wire mod, 99 tall springs, 32" Duratracs, Satoshi Grill, Tundra 231 brakes, 99 center console.
1988 3.0l 5spd Pickup SAS on 35s with 5.29's, welded 8.4 rear, custom flat bed, on board air, XRC8 winch, homemade sliders.
05-01-2011, 08:14 PM
dang 1500 to just re-gear i might just have to go with the supercharger, throw in the 7th injector and shift kit and what not and call it good
05-01-2011, 10:22 PM
you can set diffs up in a garage, but you need to know exactly what your doing. You could get by with just the gears and a pinion seal, so for about $350 -$400 but thats doing it your self. You probably dont have a press and the gauge to test the backlash. SO you should pay to have it done. I think F&R open diffs are about $1100 from ecgs
check out my build thread My Build
05-01-2011, 11:14 PM
Thats a good point too. I would replace the pinion bearings too though. All you have to do is re-use the pinion shim for the pinion depth and the rear carrier bearings are adjustable so the back lash is really easy to set. The front just uses shims for the back lash. It's really easy to do but you do have to have some patience and a press.
05-02-2011, 12:54 AM
Not trying to be a ****, but this subject has been beat to death in multiple threads. A quick search would have turned up about a dozen threads containing exhaustive information and debate. Rather then relying on all the information to resurface on this thread, you should search. There are also threads that cover the SC and 7th injector.
05-02-2011, 01:34 AM
Real Name: Isaac
Real Name: Isaac
^x2
the SC will get you back some power that the weight of your larger tires and some of your other mods have stolen from you, but they wont make up for the lack of gearing. while yes you will be able to accelerate probably just as fast as a stock rig, the added stress on your auto trans or clutch depending on what you have will soon show itself. regear its worth it, id dump the $$$ into regearing and lockers long before id buy an SC it will be cheaper too
if a*sholes could fly this place would be an airport -2004 GX470 spm -97 SR5 3.4, SCS Stealth 6's w/305 70 17s MTRs, Icon 2.5" RR w/700#coils, OME861s w/Icon tacoma 2.0 RR, ARBs w/nitro 4.88, PIAA LED lights, 170amp CS144, ARB snorkel, ARB bumper w/xd9000ce, CBI swingout loaded, BudBuilt skids, lil skip tank skid, sliders, LCE 231s(d&s), first gen roll bar mod, LED interior/dash lighting, B&M 70624+perma cool w/electric fan, dual electric fanshttp://www.toyota-4runner.org/3rd-ge...ld-thread.html
http://www.metaltech4x4.com/
