Old 05-19-2021, 06:55 PM #46
Fyrmanbruce Fyrmanbruce is offline
Fyrmanbruce is on a distinguished road
Any cooling problems with this set up?
When cutting the fan shroud, it alters the airflow. Did you notice any changes in how it cools?
Fyrmanbruce is offline   Reply With QuoteReply With Quote
Old 05-20-2021, 08:50 AM #47
JohnMc JohnMc is offline
JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all
My wife notched the corner of her shroud when she put in her dual full-sized batteries on her '96. No issues with overheating, even when driving in UT in the summer with the A/C on full blast and 105 degrees outside.
I did something a bit different when I did mine more recently - used a tiny start battery and a full sized deep cycle house battery in the usual spot:
No moving, no cutting, and very little added weight.
JohnMc is offline   Reply With QuoteReply With Quote
Old 05-20-2021, 11:26 AM #48
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Do remember what CCA's those batteries were? I really like the idea
Old 05-21-2021, 09:48 PM #49
I think they're rated at something like 300 - 360? Certainly a bit low for a single battery and year-round use. But with a two-battery setup - if the little battery isn't quite enough, just link and crank with the big deep cycle one.
I finished this up in late Feb this year, so it didn't see any deep winter cold yet.
Works perfectly fine in normal weather, though.
Old 10-21-2021, 06:17 PM #50
zacharyallott zacharyallott is offline
zacharyallott is on a distinguished road
Is this the setup you used?
Braille B2015 AGM 425 CCA Lightweight Battery Master Install Kit
zacharyallott is offline   Reply With QuoteReply With Quote
Old 10-21-2021, 09:15 PM #51
I used a B14115 battery, and a Blue Sea 7622 automatic charging relay. It has a remote switch for inside to manually connect and disconnect as needed, but normally you don't need to touch it.
I've been using that setup ever since early March. No issues so far, but I have run the start battery down a couple of times when I left something on overnight. It will certainly run down faster than a full sized battery. But then I just hit the manual connect on the dash switch, it connects to the yellow-top, and it starts normally, then switch it back to automatic.
Old 10-22-2021, 06:08 PM #52
RotaryDreamz's Avatar
RotaryDreamz RotaryDreamz is offline
Real Name: Sean
RotaryDreamz will become famous soon enough
Real Name: Sean
I really like your idea. Curious what you are running to make you want to go dual setup, if you don't mind sharing. I mainly need it for when I'm camping or hunting, so I don't have to keep bringing my Honda generator and extra gas with me everytime. Would save me alot more space this way. Thanks.
RotaryDreamz is offline   Reply With QuoteReply With Quote
Old 10-23-2021, 07:14 PM #53
Not all that much for now, but I'll keep adding things. Currently I have the air compressor and winch and some of the added lighting running off the house circuit.
Also just as a fail safe if I'm out in the back country and leave something on over night.
1997 4runner , dual battery setup , optima
dual battery set up CSL 3rd gen T4Rs 50 07-06-2019 10:55 AM
Dual battery kit 5th gen Dlak 5th gen T4Rs 78 08-21-2016 08:39 PM
Poorman's dual battery setup ryani 3rd gen T4Rs 3 01-13-2013 07:45 PM
My Dual Battery Setup airbur Engines / Suspension / Wheels / Tires / Audio / Accessories 22 09-04-2011 03:52 AM
1999 Toyota 4Runner Ltd - Dual Battery 67siia 3rd gen T4Rs 23 11-01-2008 11:05 AM
