05-27-2011, 07:42 PM
Black out emblems
I am thinking I want to turn the chrome emblems on my 4R black. I have seen on a couple of the build threads some different ways of doing it, but cannot seem to remember which builds they were and the search was of no help.
Would anybody like to share how they did this to their truck? I would prefer to not remove them, but am not 100% opposed to doing so. If you do remove, I presume it would be with a hair dryer and some floss or something...but then what is best to use for re-applying?
Thanks in advance!
2000 SR5 Sport 4x4 5 Speed - Sonoran Steel Lift Kit System 1.2 - Front: 3.5": TRD coils & Bilstein 5125 shocks -1" diff drop - Silver skid plate - Rear: 4.5": FJ80 coils & 5125 shocks. - Pan/track bar by Sonoran - K&N CAI - ProComp X-treme AT 285/75/16 - Shrockworks Front Bumper - CBI Rear Bumper w/swing away - Shrockworks Rock Sliders - Flowmaster 40 & 2.5" catback - Alpine Type S - All Pro 1.5" spacers - Yakima Loadwarrior & two viper bike attachments - Tinted front windows to match - Sylvania HID fronts - Custom 'hulk' shift knobs - TRD shift knob - Powder coated 5 Star wheels - Energy Suspension Poly Steering Rack Bushings - Black Tacoma Whip - Uniden PRO520XL w/4' Firefly and PA
05-27-2011, 07:49 PM
Moderator
Real Name: Waldo
Moderator
Real Name: Waldo
a lot of people seem to be going with the plasti-dip method. Search 'plasti-dip' and see what you come up with.
not 100% sure if thats the correct way of spelling it but it's something of that nature.
'99 Toyota 4Runner LTD - Dual Locked | Geared | Mid-Travel | 35s | Armored
05-27-2011, 07:50 PM
I chose to remove them because I did not want the plastic dip to go on the paint.
1. Hairdryer + floss = removes all emblems within 15 mins
2. Front grille- pop hood, pop grille out, screws hold the front emblem
Plastic Dip + Newspaper
05-27-2011, 08:06 PM
Leave the emblems on.
Tape them off as so(maybe better)
Then do a light coat. Let it set for 5-10 minutes.
Then do a heavier coat. Let it set for 30 or so minutes.
Then do a decently thick coat(Dont go crazy). Let it set for about an hour.
Remove the tape.
You will be left with a square of plasti dip. Start to peel it off from on corner.
Then get some toothpicks(they dont scratch the paint) and tweezers(to get the plasti dip out of the letters once you get it off the paint with the toothpick).
And you're done
1999 4Runner SR5 3.4L, 6000K HIDS, 2 12" JVC Subs w/ 460W amp, Sport skid plate, OEM fog lights, Rola roof rack w/ extension.
Sitting in my room: B&M 70268
Many mods yet to come
05-27-2011, 08:42 PM
Doing mine for my build tommorow! Went out and got 2 bottles!
1999 4Runner SR5 4wd 265/70/16 General Grabber AT2's
05-27-2011, 09:10 PM
05-27-2011, 09:23 PM
Yep Plasti-Dip right over the paint. I used a toothpick to get into the areas between the letters. Super simple and NO effect on the factory paint.
Aloha to HI_LIFE808!
99 Limited
05-27-2011, 09:27 PM
Originally Posted by HI_LIFE808
Dude that looks sick on the license plate part!
05-27-2011, 10:07 PM
Thank you
Thank you all for the good replies and also the photos to back up the stories.
I will do this as soon as I get off work. My questions:
1.) Why exactly does it not stick to the paint?
2.) Would it peel off the emblem if you tried, you just don't peel it off?
3.) What is the durability, withstand a pressure wash?
Thanks!
05-28-2011, 01:56 AM
Moderator
Real Name: James
Moderator
Real Name: James
I personally find Plastidip a little too... temporary. It's really not very durable... at all. I've done a lot of Plastidip work, most of it get's screwed up pretty fast. My fender flares were Plastidipped, and a pressure washer at my work's car wash ripped it clean off (5 coats worth).
I took mine off and painted them with ordinary spray paint, primer, clear, etc. They held up for a long time until I took a buffer to the truck.
If I had to do it again, though, I'd use some Testors spray enamel and clear on all of them.
I found myself a set of black pearl rear emblems off a truck at the yard. Too bad the front emblem was gone (crashed), but I painted the front with Testors #1813 Black Pearl Spray Enamel and #1814 High Gloss Clear Coat.
So here's a breakdown:
Flat Black Krylon:
How they looked by the time I took them off (chipped from buffing):
Black Pearl Emblems:
And front:
IG: @jimharb | YouTube | '99 Limited 2WD |
'99 4Runner - 2.7L 3RZ-FE - TRD S/C - 4WD Conversion + R150F 5-Speed Swap - Imperial Jade Mica on Oak
'87 4Runner Turbo - 2.4L 22R-TE - CT-26 Supra Turbo - W56 5-Speed Swap - Red on Red
'90 4Runner 2-Door - 3.0L 3VZ-E - Auto to R150F 5-Speed Swap - Red on Gray
'94 Supra Turbo Targa - 3.0L 2JZ-GTE - Marlin Crawler R154 - Imperial Jade Mica on Black
'89 Supra Turbo Targa - 3.0L 7M-GTE - Marlin Crawler R154 - White Package on Blue
'89 Pickup DLX 2WD - 2.4L 22R-E - W55 5-Speed - White on Blue
05-28-2011, 03:40 AM
Adhesive
I think I agree if the plastic comes off at a car wash, I do not think it will make it through the tougher winters. I will still make my decision when I get back.
Will somebody help me with the adhesive that should be used to put everything back on if the emblems are taken off?
Thanks!
A
05-28-2011, 02:37 PM
I have my rims, emblems, rear tailgate over, and front grill all done with Plasti-dip and have had no problems with power washing it (at a commercial car wash). If you have some crazy gas powered pressure washer that shouldn't be used on vehicles anyway you might have issues.
Your standard car washing bay isn't going to give you problems.
99 Limited
05-28-2011, 02:38 PM
3M makes some good adhessive......just go to your local Auto-parts store....there should be some there.....if not....try an Auto-paint supply store.
1998 4Runner SR5, ISR and Deckplate Mods, Painted Intake Manifold, TRD Tundra Struts, Diff Drop, LC 8 Wraps w/ Skyjacker shocks, Panhard Drop Bracket, Rear Tire Carrier, Maxxis Bighorns, Procomp Wheels, Custom Front Valance, Sport Edition Skidplate, Upgraded Exterior lighting
05-28-2011, 03:38 PM
Did my emblems yesterday. Don't worry about getting it on the paint because it peels right off. I've never heard of anyone having issues with it peeling off in the wash or during winter, but I don't know for sure.
1999 T4R SR5 V6 2wd
