07-30-2014, 07:12 PM
Sway bar end links compared
I received my order from Rock Auto. Unfortunately I was not advised that they are sold individually so now I have only one of each. Also one of them arrived opened with no hardware. After reading what was posted here I thought I'd provide some evidence.
At the right is Moog K80565 "1995 4runner front." Note that it has a zerk at and also does not narrow at the bottom like what I pulled off the truck (middle). K80565 is 1-1/2in shorter than 2002 stock.
At the left is Moog K80380 "1995 rear". Note that it is thinner throughout (3/8in vs 1/2in for 2002 stock). It is 3/4in longer.
Since I have only one of each I'll have to hit Pep and Advanced to see what they have. Worse case I just do the steering rack this weekend and the sway bar later. I don't really need the disconnects but I may wind up having to buy the ones mentioned in previous posts on this topic.
07-30-2014, 08:11 PM
official vendor
official vendor
I'm your hook up for disconnects.
07-30-2014, 11:49 PM
We're you intentionally buying Gen 2 links for your Gen 3? I have a pair of K90681 arriving tomorrow which are sold as Gen 3 front links. I believe the front is longer than the rear so I think you have your front/rear reversed in the description. I'll post a pic w/measurements when I get them to see how they compare to your lineup.
So did you pull the OE link in your pic from the front or rear?
MStudt does have some nice links if you plan on keeping the sway bar. I have a feeling I might be ditching it if I don't get the desired result from the longer fronts I ordered for the rear.
2000 Highlander - 3" OME 883F 890R - ARB F&R Lockers - AOR Bumper - Savage Armor - WARN M8000 - RIGID LED Floods - TRD Wheels - TBU - HID - BFG KM2
07-31-2014, 01:20 AM
Real Name: Shane
Real Name: Shane
So I JUST did my rear sway links to correct the steep angle I had after swapping to the 8 wraps. I was going to go with O.E. 3rd gen fronts but said FACK that after I priced them at one and a half bills. I ended up going with AutoZone brand(Duralast) end links. From what I was told, they are manufactured by the same company that makes Mogg links as well. They were double the girth of my O.E. ones. I used 3rd gen fronts for the rear. They are EXACTLY the correct length to bring the sway back to correct geometry. Bolted up nicely and are beefy and well made. Came with all the new bushings and hardware as well. I'd suggest going with AZ FTW. Unfortunately I didn't take any pics of the comparison, but if anyone is seriously curious I can hold my O.E. one up to snap a pic for comparison. The model number I used is SL3560 or DSL3560. Here is a direct link to exactly what I used.
Duralast/Sway Bar Repair Kit (SL3560) | AutoZone.com
And here's a picture of my passenger one installed.
07-31-2014, 09:18 AM
Sorry if I can't read right, but what did you use for your fronts?
2001 Toyota 4Runner SR5 Sport
Imperial Jade Mica
231mm Tundra Brakes
5100 Bilstein / TRD / OME 890 3" Lift
285/75/16 BFG KO2s
07-31-2014, 09:56 PM
Here is the Moog K90681 I will be replacing the OE rear with. Feels pretty solid and looks like it should be the right length.
07-31-2014, 10:23 PM
Real Name: Shane
Real Name: Shane
I actually didn't have to do anything in front. I used the fronts though for the rear. I don't think I need to do anything in front. Do I?
07-31-2014, 10:28 PM
official vendor
official vendor
If you went longer on the back. Why wouldn't you go longer on the front? Same concept of getting the sway bar back in line.
08-01-2014, 02:15 PM
Real Name: Shane
Real Name: Shane
@ MStudt
It's very logical that the front needs an extended link as well, however I chose not to do one yet because I didn't notice nearly the change in the front as I did in the rear with my axel dropping and pulling the sway out of alignment. I will probably do the fronts when I finally get UCA's and get it dialed in 100%. Till then, I haven't noticed any issues with droop or binding.
08-02-2014, 01:20 AM
So can you feel any difference yet with the longer links? I was going to do mine tonight but the Moog morons gave me the wrong size top nut in both boxes. The links look pretty nice for the money and I like the zerk so I'll just keep them and find the right size hardware for it I guess.
How did you get the bottom off where it connects to the bar? I was able to get a socket on there but it seems to keep spinning but not fully extracting. I don't see anything on the other end that needs to be held while loosening.
08-02-2014, 07:42 AM
Real Name: John
Real Name: John
Should either have a place on the boot side where its round with two flat spots or the stud has a hex shaped hole
SILVER 2000 4runner Limited TOTALED
WHITE/SILVER 1999 4runner Limited l Rear Locker l Tundra/890 coils | 5100 Bilsteins all around | Sonoran Steel Bumpstops l 199 mm Tundra brake upgrade | SCS Matte Gray Ray10 Rims | 275 70 17 BFG KO2 tires | LR UCAs | EIMKEITH panhard brackets | LED interior upgrade l Rear LED tailights l Pioneer AVH-X5700BHS Alpine Type "R" speakers NVX JAD800.4 Class D Amp Kenwood Under seat Subwoofer l Front window tint 20% l Weathertech window visors and floormats l OutGear Solutions Full Length roofrack l Morimoto 40" LED lightbar
08-09-2014, 12:46 PM
FWIW - I was all ready to replace the rear sway bar links and bushings, but took it for a spin down my local test trail after removing it and really liked the way it felt without it so decided to take the front off as well.
Could definitely feel the rig conforming to the trail much better in the real undulated sections and definitely mellowed out the harshness of the OME's. I really like it so far and plan on keeping it sway-free for now.
08-09-2014, 02:02 PM
It's not necessary in the front because there isn't extreme articulation (IFS) like in the rear (Solid Axle). If you don't change them out in the rear they can actually hit your shock body on the passenger side. Also because I have no idea what links you would use, lol.
Current Equipment: 2001, Multi-Mode 4WD, Coilovers, LC8's, Pro Comp ES9000s, Custom Sliders, Yakima Control Towers and Mega Warrior w/ Spare and Hi Lift Mounts on 255/85R16 KM2s.
08-10-2014, 01:11 PM
official vendor
official vendor
It's still necessary on the front. Just because it's IFS doesn't mean that you don't need to adjust the sway bar back to its ideal location. The links are more to help control body roll which 85% of comes from the rear. That's way most people keep the rears and remove the fronts. With the weight of the front end along with the coil-overs. The front contributes very little to the body roll factor. IMO, extend the front or remove them all together, and replace the rears with longer ones.
08-10-2014, 04:42 PM
I think GOOD and WANT are more appropriate substitutes. I'm not saying you're wrong because I agree that ideally you would want to have it returned to factory geometry. However, you could get away with it in the front, wherein the rear will actually damage your shock. I removed my front and used the front links in the rear... I like the balance now, especially with a spare on top of the roof rack.
