The magnetic clutch can fail and thus instantly your AC pump will not work..
Possible your high or low pressure safety switches fail and not engaging the magnetic clutch on the compressor.
Relay possible but very rare.
All this takes is a small rock to pinhole your condenser and all your freon gone and you may not see it.
Snap a set of gauges on to verify you have correct pressure in the system as it rules that out.
Build Thread:
https://www.toyota-4runner.org/3rd-g...os-builds.html
Brillo's Bucket Fluid Ex changer:
https://www.toyota-4runner.org/3rd-g...ml#post3358086
Sparks Plugs Wire and Coil Information:
https://www.toyota-4runner.org/3rd-g...on-5vz-fe.html
