Originally Posted by Maxil
I have recently purchased a small Travel trailer that weighs about 3000lbs. I have thus far changed out tranny fluid to synthetic amsoil for lower temps and about to hook up tranny cooler. I wanted to bypass the stock cooler but I fear I need that extra cooling power in the stock one.
The suspension didn't seem to sag all that much when towing it home, about 250 miles. I could sure feel the weight but it pulled better than I figured it would.
I also added a brake controller and all hookups that the factory towing package lacked.
Is there any easy/not so expensive upgrades that I could do to assist pulling such a load,or possibly a heavier one in the future?
Thanks a bunch!
A lot of people have done the Tundra Brake mod. (If you search for it, there are some step by step write-ups.) It will give you more stopping power and prevent the thinner stock rotors from warping under heavy heat. I would say if done yourself it is a relatively cheap way to make towing safer and easier on your rig.
